Eco-Boost bog down
/ Eco-Boost bog down #1
deerefan
louisiana
1952 8N, 2005 JD 5103
My friend was putting feed tubs out for his cattle in his F150 2wd with the eb engine. He manage to get off in a little mud, causing the truck to get stuck. Everytime he gave it gas, the engine would bog down. What is this? Is it tourqe management? Can it be tuned to eliminate this? This truck has pulled and hauled heavy loads with no problem and has been very reliable. Please, no Ford bashing. I would like to give him an idea of what is going on.
/ Eco-Boost bog down #2
Traction control likely. Most times there will be a light that flashes on the dash indicating its active, will either cut engine power or apply brakes or both, depends on the manufacturer.
ps- There should be a button somewhere on the dash to disable traction control. This is what it sounds like whats happening. My toyota has it and its a pain in the *** when you're trying to fish tail around a corner and it doesnt allow you to.
Good point. Didnt think of that. My silverado has this (4x4) but i dont recall it bogging down when the light flashes. I will try to pay attention when it does it.
/ Eco-Boost bog down #4
I also think it was traction control.
/ Eco-Boost bog down #5
Like I said they sometimes do it differently between manufacturers where it may be more noticeable than others.
/ Eco-Boost bog down #6
My Ranger will do the same thing, traction control. Can't even do do-nuts in an icy parking lot without turning it off (so they tell me :) )....mike
/ Eco-Boost bog down #7
Yes, traction control. All vehicles have it now day and its just doing what it was supposed to do.
Chris
Thanks guys. I will forward this on to him. He loves this motor and was a little concerned when it did this.
/ Eco-Boost bog down #9
I will give an example for two vehicles we own. We own a Dodge Challenger and a Chrysler 300 C. Both are autos and both have the 5.7 hemi. Both also have traction and stability control. The 300C's traction kicks in at very little wheel spin and it feels like the engine almost dies. The Challenger which is tuned for a little more spirited driving from the factory has to spin the tires pretty hard before the traction kicks in and when it does kick in, its not so abrubt.
/ Eco-Boost bog down #10
All he has to do is push in his traction control button and hold it in for 5 seconds and it will turn off the option. It will automatically turn back on at a certain speed (sorry I forget what that is right now).
/ Eco-Boost bog down #12
Actually a quick push will disable traction control. The long push will disable stability control as well.
/ Eco-Boost bog down #13
You're right. I had the TC, ESC, and RSC all lumped together in my mind. One push turns off the TC as you said. Thanks!
buickanddeere said:
Has you buddy the read the trucks operator's manual from cover to cover? It's all in there.
I highly doubt he read it.
Lockers (A62613)
Lockers (A62613)
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2014 International WorkStar 7500 T/A Dump Truck (A61573)
2014 International...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
1000 GALLON POLY NURSE TANK (A64276)
1000 GALLON POLY...
