Hydrostatic quirk or total nonsense?
/ Hydrostatic quirk or total nonsense? #21
It shouldn't, but yet it does, at least on mine. Most noticeable on the backhoe, lifting up a big log with the thumb.
That is my experience too with my BX22. At idle I get no movement with either the loader or backhoe. I believe the newer than my BXs were much better in that regard.
This is absolutely true on open center hydraulics.
The relief valve is the key reason for this.
Equate this to a two lane tunnel handling traffic,, at 2am, the traffic is light, cars go right through the tunnel.
(low engine speed, low oil flow, low force required)
Then, have all of the rush hour traffic come at the tunnel, the tunnel can no longer handle the traffic,,
(high engine speed, high oil flow, high force required)
At high engine speed, the high oil flow causes a "backup" at the relief valve.
The functional pressure the loader cylinders will experience will be based on a combination of the relief valve PLUS the restriction at the relief valve due to the high flow that is being restricted by the valve, hoses, and who knows what else.
This would be the same as clogging the return line,, at some point the pressure would go up high enough to break the gear pump supplying the pressure. (assuming a line did not burst first)
The relief valve would have to be infinite in size for this not to happen.
So,, rev up the engine when you want to lift the maximum load,, take advantage of that restriction caused by the high speed oil.
/ Hydrostatic quirk or total nonsense? #22
Sunandsand - you have some good questions here and have demonstrated a willingness to learn. I think you'll do well with you tractor. The Handyman author on the other hand should not the be writing an advice column about operating tractors. Maybe he's knowledgeable about other things, but not HST tractors. I won't repeat the advice given, all good stuff. I will contradict the FEL bending though. If Handy runs his BX in High gear and rams a pile, he will bend that FEL.
"Sunandsand - you have some good questions here and have demonstrated a willingness to learn."
Thank you. The larger the island of knowledge, the longer the shoreline of ignorance. (Not original, I don't remember who said it.) I am constantly learning new things but my theory is learn about it first before you hit the switch/press the button/turn the throttle/pull the pin, not "hold my beer and watch this!"
Handyman isn't a bad magazine, but I do notice that their solution to everything seems be to advise their readers to spend as much money as possible. Same article advised buying a shiny, new $20K UTV to move a couple of bags of mulch. They did miss the part about buying a $75K Mercedes Sprinter extended van to pick up those bags at Lowes/Home Depot/Menards etc. (Or maybe just have them delivered in a chartered G650 Gulfstream jet, the butler will move them.)
Here on TBN, I get to listen to the knowledge and experience of people who know FAR more about this stuff than I ever will. I know I'm an amateur at this, and I'm not about to say "well, I've got 200 whole hours on my tractor and I know everything there is to know about tractors!" I'm reputed to be an expert in other things (or at least some people hold this delusion), so if I'm going to advise on something, I'm going to make darn sure I know what I'm talking about first.
My goal with "tractors" is to learn enough about them to operate mine safely, efficiently, and reasonably competently. Reading TBN and paying attention to the answers I get to my questions (and questions other people ask, too) has helped me greatly, and I appreciate it.
Best Regards,
Mike/Florida
/ Hydrostatic quirk or total nonsense? #24
When pushing into a pile, you should be in low range. No, low range does not give you more lift capacity.
Your issue is the way they rate their lift capacity and the fact that your weight was 2-3' forward of their rating point.
/ Hydrostatic quirk or total nonsense? #25
I was unloading freight on pallets out of a tractor-trailer, and the FEL wouldn't lift, but it would curl, and that gave me enough clearance to get the pallet out of the trailer, back away, and lower the pallet to the ground. The truck bed is 4' off the ground, maybe a little more.
It is much safer in max lift unloading situations to raise the load an inch, then have the someone drive the truck out from under the load, then lower the load with the tractor stationary.
That initial 60" of tractor movement at max lift is the most dangerous time, when tractor rollovers occur.
kind of hard to do if working from a dock, even if using a pallet puller I wouldn't move the truck, the receiver needs to have the right equipment or order the load palletized by your equipment's max capacity.
/ Hydrostatic quirk or total nonsense? #26
It’s operator error. The HST pedal works differently from a car accelerator. You want more throttle and less pedal when the going gets tough. The tractor should have already been in low range which it sounds like it wasn’t.
Correct. Ease up on the forward pedal to get more force to the wheels. Takes some getting used to.
Hydraulic Pressure is a function of engine/pump RPM. If it won't lift it, It is too heavy or you are low on Hydraulic Fluid.
/ Hydrostatic quirk or total nonsense? #27
This is incorrect. Increasing engine RPMs increases speed of FEL movement in feet-per-second but does not increase lift capacity in pounds.
I disagree. Try lifting a heavy load at idle...
/ Hydrostatic quirk or total nonsense? #28
Clearly the Handyman operator is ignorant. The BX is a single hydraulic pump, which only develops power through RPM. The loader we’ll stall every time if the RPM is not up. The B-Series is a dual pump, and is not affected as nearly. You can idle the B and make the bucket lift and curl. On the BX, you’ll grow old before seeing any movement.
  • Good Post
Reactions: JWR
/ Hydrostatic quirk or total nonsense? #29
The pallet forks weigh about 100 pounds - they're from Everything Attachments. The pallets are "euro" pallets, which are slightly smaller than standard US pallets.
You might check this weight. EA offers no pallet fork setup at 100#. The forks themselves, maybe, but add the frame, and 240# is the lightest setup they offer. In fact, 220# by another brand is possible, and #165 the lighted I’ve found for my SSQA on my BX2380.
/ Hydrostatic quirk or total nonsense? #30
Lift capacity rating is at the pins that attach the bucket or forks on the front. The farther the load moves forward of that point the less you can lift. Its simply a matter of leverage.
/ Hydrostatic quirk or total nonsense? #31
OP, when trying to lift things out of the semi trailer, try this after observing other safety measues. When I want to lift a heavy bunk of freshly sawn 12 ft lumber on my B26TLB, I enter the stack until the back of the forks hit the stack. Fork frame straight up/down. Then raise the fork back up while tipping the tips down. Continue until FEL won't lift an more, then curl back and continue your lift.
I had to do this yesterday stacking a second bunk on the first. Couln't raise forks high enough to get on fully on bottom bunk. But the tips were high enough to set the tips on the bottom bunk. Uncurling while raising the forks allowed me lift lift high enough and then curl back to set the second bunk on top of the bottom one. Jon
/ Hydrostatic quirk or total nonsense? #32
I'm sure most of us have used tactics like this to get "just a little bit more lift". Just be aware that it puts more weight on the loader than the relief valve normally would as the relief is isolated from the lift circuit when using the curl.
/ Hydrostatic quirk or total nonsense? #33
When the loader will lift up but not high enough to load on the deckover trailer, I have also driven up a set of 2x material car ramps. Jon
/ Hydrostatic quirk or total nonsense? #34
Hydraulics a very simple and confusing topic.
Open Center system. Pump = A positive displacement unit that draws oil from a tank and moves oil to a control device, note a pump does not create pressure it only moves fluid at a set rate per the rpm operated. Control Valve = a device that receives oil form a pump and if not directing oil to a cylinder or motor returns it to the tank. If directing oil it directs the oil to the cylinder or motor. Note most contain a relief valve. To this point system has only pressure high enough to move the oil thru the system. Once the valve directs the oil to cylinder the cylinder will move, pressure in the system will increase until it moves the load. If the load is too much, movement will stop, pressure will increase until the relief valve opens. Note if engine speed is increased so will the GPM. Force may be increased due to the volume of oil not able to flow thru the relief valve, or a volume increase due to a worn pump or other leakage in the valve or cylinder. The speed of cylinder movement is directly affected by pump rpm. This type system can use many valves in series as long as a power beyond fitting is used. For operation of a constant flow this system requires lowest pressure and maximum gpm used or you will overheat it.
Closed center system uses a variable displacement pump and a closed center valve otherwise is the same for cylinders and motors as above. When this pump reaches system pressure it shuts down to almost no flow. Pressure is the same with engine idling or wide open but gpm will increase with speed. It needs minimal flow in the system for lubrication, cooling, and leakage. To best describe a closed center system think of the water system in your house. Multiple valves can be used in the system by just adding a T in the main pressure line. for continuous use you must use minimum flow or the system will overheat. These systems usually do not need relief valves due to the pump controls the highest pressure. These pumps can be gravity or pressure fed. Manufactures use then because when the system is not being used it frees up engine power but is more costly than an open center systems,
Hydrostatic A bidirectional variable displacement pump connected by a closed loop to a motor. Usually kept charged by an open center charge pump, this pump can also operate as an implement lift. The charge circuit is set to a specified pressure. The main circuit has relief valves and may contain acceleration control valves. Speed of the motor is affected by engine speed and controlling the displacement of the pump. Also direction of the motor is controlled by the movement of the swashplate in the pump. Most garden tractors and zero turns do not use a transmission, most scuts, cuts, farm tractors, or industrial equipment use a multiple speed transmission, for low speed control high torque or high speed low torque.
/ Hydrostatic quirk or total nonsense? #37
Assuming that Sunandsand was quoting that magazine article verbatim, that magazine should filter its writers :cool:
/ Hydrostatic quirk or total nonsense? #38
Bentrim said:
"Hydraulics a very simple and confusing topic.
Open Center system. Pump = A positive displacement unit that draws oil from a tank and moves oil to a control device, note a pump does not create pressure it only moves fluid at a set rate per the rpm operated."
The inlet to a pump is at negative pressure causing fluid to enter the pump ("draws" it) from the sump which is at neutral pressure. The outlet of the pump is at a positive pressure which goes to a high number varied by things like relief valves and loads. Obviously the pump DOES create pressure and if it did not the fluid would never move. By definition, and normal specs, a pump creates an amount of flow at a pressure.
What is the point of trying to claim the pump does not create pressure?
/ Hydrostatic quirk or total nonsense? #39
There are different types of pumps. Positive displacement pump or a centrifugal type pump. They create pressure in different ways.
/ Hydrostatic quirk or total nonsense? #40
I've too have often wondered why folks make that counter intuitive statement. It would be difficult to have pressure without a pump.
I realize that there also has to be resistance of some kind to create pressure.
