sunandsand
Gold Member
- Joined
- Jan 11, 2020
- Messages
- 377
- Tractor
- Kubota B2601
Copy of Family Handyman arrived today, it has an article which touches on a BX2380. Author says he was having trouble filling the bucket on the FEL, and needed a bit more horsepower. He said when he pressed down hard on the "forward" pedal, it "essentially shifted into a higher gear range" which wasn't what he wanted and bogged the engine down. His solution was to shift to 4WD low and try again, which he said solved the problem (I guess more mechanical advantage from a lower range). He wasn't clear if he was having problems filling the bucket by shoving it into the dirt pile, or filling the bucket by push/curl/lift (which I think is the proper procedure since using the FEL as though it was a bulldozer will bend it).
So . . . I have a B2601 with pallet forks. I have sometimes run into problems lifting "stuff" which I know weighs less than the FEL rating. The engine doesn't bog, but the FEL won't lift. I was unloading freight on pallets out of a tractor-trailer, and the FEL wouldn't lift, but it would curl, and that gave me enough clearance to get the pallet out of the trailer, back away, and lower the pallet to the ground.
My question is this - would I have had more lift capacity if I were in low range (I was in medium, 2WD) or did I just happen to find the lift limit of my FEL? Would the gear range affect the output of the hydraulic pump with drives the FEL? I also think the lift capacity of the FEL varies with the height, and the truck bed is 4' off the ground, maybe a little more.
His explanation might also be apples and oranges - if he was playing bulldozer, that shouldn't affect the hydraulics, and he simply asked more of the BX than it could deliver in high range.
Best Regards,
Mike/Florida
Best Regards,
Mike/Florida
