First Tank of E85
/ First Tank of E85 #1
crashz
Elite Member
NH
Kubota L2501, JD LT150, DR Field Mower
I bought a new Silverado last year (2500HD, 6.0L gas, 6 speed auto, 4x4, ECSB) that has the option for running flex fuel. In my area, its difficult to find, so I have used regular gas, well E10, since new. Recently a few stations opened up E85 pumps (Mass Turnpike rest areas at Sturbridge) that I frequently pass. So tonight, I pulled off and filled up with E85 just to try it out.
First off, I had a little over 1/4 of a tank of regular gas (E10). I filled up with 22.75 gallons of E85. That makes a mixture of about 58% ethynol and 42% gas, or E58.
I pulled back onto the highway and continued my journey how for another 60 miles or so. What I have noticed is that in general, there is very little difference in performance. The truck has the same power, but I do notice that I need to step on the accelerator more from a stop than normal. Which contradicts its highway behavior because I felt I needed less pedal pressure on the hills than normal. There was no bucking or snorting or anything that indicated that the truck is adjusting to a new fuel.
A big difference is the sound. The truck is noticably quieter at idle and in low speed driving. I also do not hear the regular LS motor injector tick, which is usually very prevelant in this truck.
So far I've only got ~60 miles on this tank. I know I'll lose some mileage with this fuel, but I did some "spirited" driving to test the limits, so I expect miserable mileage. I'll update this thread as I burn through the fuel, but so far I'm pleased.
/ First Tank of E85 #2
You shouldnt have any running troubles at all, it should be a seamless transition. The injector tick may have gone down due to the pulse widths being changed with needing more fuel to keep the A/F ratio near stoichi.
/ First Tank of E85 #3
E85 will make slightly more power but you will get less mileage.
/ First Tank of E85 #4
I ran nothing but E85 in my 2007 F150 4x4 SuperCrew for 6 months, about 8000 miles. It was 2/3rds the price of 87 octane back then. I got 11mpg. When the E85 price nearly caught the price of 87 I switched to regular gas and got 15.5mpg. Quite a difference. My co pilot at the time had a Yukon XL and got similar results.
Long story short, it has to be 2/3rds the price of 87 octane to make it cost effective
Chris
/ First Tank of E85 #5
x2 didnt make money sense to me tried it in my Company van milage dropped from 24 ish to 19 ish wont try it again too frequent fill ups
/ First Tank of E85 #6
My uncle owns some stations. They love E85 because it brings you in more often. Gas is very low overhead but soda, candy, coffee, ect are high profit items.
Chris
/ First Tank of E85 #7
I've always heard that E85 burns cooler than gas (less BTU's), thus making less power and less mpg's.
/ First Tank of E85 #8
The more percentage of alcohol in petroleum fuel equates to less available energy. And, since, we the public, subsidize corn production with Federal programs it does cost us considerably more money in the overall equation. I am not attempting to start a flame war with this statement, rather simply directing the conversation to the actual bottom line. This does not address any any environmental issues, simply the economics.
/ First Tank of E85 #10
It is somewhat popular among guys running forced induction. It does make power mainly because it has a higher octane rating.
E85 Fuel Conversion - Muscle Mustangs & Fast Fords Magazine
I'd becareful with what you mean by "makes more power". The ethanol fuel doesnt make more power than gasoline fuel to fuel. You still need to modify an engine/tune it to take advantage of the higher octane rating of the alcohol fuel to make that power. Its not a dump in and make more power type of fuel. We had a car in the shop the other day where the calculated alcohol content was 66% according to the ECM and the vehicle ran extremely rich thinking it was fueled by a 66% alcohol fuel, turns out after a small fuel sample it wasnt anywhere close to 66%, they dont even sell E85 around here so I have no idea where they would have gotten it either.
/ First Tank of E85
Well the price was $3.29/gallon for E85, $3.53 for regular and near my house I can get regular at $3.34, so if I see any drop in mileage, it won't be economical. With that said, I wouldn't be able to buy E85 on a regular basis since the nearest station with it is at least an hour away.
We don't have much for alternative files available in New England, so this really was a first time that I could try it.
/ First Tank of E85 #12
We use to have enough places around that sold non ethanol regular gas so I could swap back and forth between it and E10. I noticed the same thing, normal driving wasn't really effected but you just needed to give it a little more to do the same speeds. Starting off was where I really noticed it, it's also where you use the most gas. I really needed to use more throttle with e10 where the non ethanol just had more pep. Since there's no e85 pumps around I don't have the option but I kind of thought that it would be more of the same.
/ First Tank of E85 #13
How much different was your fuel economy? I think to get the most performance a vehicle should have a special tune for e10 but the fuel economy will be worse than gas. I think a lot of e10 has more than 10% ethanol.
/ First Tank of E85 #14
E85 drop my average MPG by just over 5 MPG compared to E10 on my 2003 L59 (engine) Tahoe.
/ First Tank of E85 #15
I've heard running E10 as compared to standard gas will drop your mpg by about 5%. Has anyone determined what the actual difference is?
/ First Tank of E85 #16
Thats about right.
Running E85 its roughly 35%. I have tested it in a Ford and Nissan and my co pilot tested it in his GM and all three had better than a 30% drop.
Chris
/ First Tank of E85 #17
Let me correct something someone else said. With E85, most vehicles will not make more power. You can build an engine to make more power with E85 since it has a high octane, but unless you have a high compression engine, most vehicles will not make more power.
/ First Tank of E85 #18
A naturally aspirated street engine will make more power with E85 but the power increase is very minimally in most cases less than 10hp with a proper tune.
/ First Tank of E85 #19
That 5% is very clsoe to what I have seen on my 2011 Silverado 5.3l. When I first got this truck, I checked actual fuel mileage myself to compare with the computer. Computer was dead-on. I tried 2 tanks of non-ethynol and first tank I purposely run tank down so fuel warning light had been on for awhile. With E10 it averages 17.6 mpg. Filled up with non-ethynol and made a run to Little Rock, AR averaged 19.1 (mostly highway @ 80mph). Had to use E10 to get back home. Second time was making trips to Knoxville & Chattanooga (lot of hills) and had similar results. This was runnig with empty truck so not anything saved $ wise with extra cost of non-ethynol, but if I had to make those runs loaded or pulling, I would pay the price for straight gas.
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
2016 John Deere 3039R 38HP 4WD Utility Loader Tractor (A66734)
2016 John Deere...
LINCOLN CLASS 300D WELDER (A67714)
LINCOLN CLASS 300D...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
