E85 Fuel
/ E85 Fuel #21
I've run good old mountain regular-85 octane- many times traveling in the west.
Works just fine!
Normally it's not sold within a tankful of lower altitude areas.
/ E85 Fuel
Seems hardly anyone carries it. One downside to my Flex Fuel F250 is it states in the owners manual to not run below 87 octane. This becomes a problem in western states at higher altitudes that have their lowest grade 85. Often the next step is mid-grade 88 which is way higher in cost. From the owners manual:
We recommend regular unleaded gasoline
with a pump (R+M)/2 octane rating of 87.
Some stations offer fuels posted as regular
with an octane rating below 87, particularly
in high altitude areas. We do not
recommend fuels with an octane rating
below 87.
Keep in mind the 85 in E85 fuel refers to it's ethanol content, not it's octane. The octane rating of E85 is usually between 105 - 110
/ E85 Fuel #24
Turbos offset the Colorado altitude. You can get away with 85 octane here for a normally aspirated engine as we lack oxygen. But if you have an ecoboost or other turboed engine, that partially makes up for the altitude. Running 85 with a turbo is a recipe for problems.
/ E85 Fuel #25
Well that's why I made the comment about not many places carry it or I might switch to E85 in the mountains. I tend to get out into really remote areas. Now last year I was in AZ and it seemed everywhere I stopped had 87 octane.
/ E85 Fuel #26
E85 is hard to find around here. Not really looking for it, I've seen at two stations, 1 in Chehalis and another in Olympia WA. I've used it in my Ford Ranger probably 7 times or so. Seat of the pants measurements was slightly better acceleration, better lug ability, slightly worse mileage. Sometimes the price difference is enough to actually be a slightly better deal with the E85.
I forgot to mention almost sea level altitude.
/ E85 Fuel #27
I get it on my way to the farm . It is about a buck a gal cheaper, The truck runs just fine, But i do think i get less MPG,
/ E85 Fuel #28
Does anyone have personal experience with E85 "Flex Fuel"? I did a search which turned up a lot about ethanol production but very little on the subject of engine performance.
I bought gas at Sheetz this morning and noticed E85 (85% ethanol) was around a buck per gallon cheaper than regular E88 unleaded (15% ethanol). E85 has always been cheaper but I've never seen this big a difference before. I suppose it makes sense since the price of ethanol doesn't necessarily keep pace with the price of oil.
My 2012 GMC pickup burns E85 Flex Fuel. I kept careful mileage records and found it almost a wash as to which fuel was more economical. I used the E85 mostly because it was the "green" thing to do or so I thought, but I didn't care for the loss of mileage & performance.
I don't want to start an endless debate on the environmental impact of ethanol. Instead, I'd like to hear from others about how well E85 performs in your equipment. I'm considering a new vehicle and I'm trying to decide if it's worth buying another that uses
I don't want to start an endless debate on the environmental impact of ethanol. Instead, I'd like to hear from others about how well E85 performs in your equipment. I'm considering a new vehicle and I'm trying to decide if it's worth buying another that uses flex fuel.
Ethanol has 76,000 btu/gal while regular non-ethanol gas has 100,000 btu/gal so you get less power out of the gas with the ethanol. When I use the gas with 10% ethanol I see mileage reduction of about 7 - 8% - to be expected. It takes more throttle to get the same horsepower out of the engine.
/ E85 Fuel #29
Did you mean to sayyou get more power out of the gas than with ethanol based on the BTUs being much higher with gas VS ethanol?
Because if you did, you'd be mistaken. ;)
I encourage people to watch this fuel comparison of different octane gasolines, then compared to E85. There is virtually no power gain amongst the different octane gasolines (as expected, because octane doesn't boost power), but a noticeable gain in power when going from gasoline of any octane to E85 ethanol.
Very interesting.
/ E85 Fuel #30
In my pickup trucks, I see a 3 MPG decrease on E85 fuel. However, the engine runs noticeably smoother and there is more power. Ford motor company specifically rated the increase at 15 horsepower on the 5.0L engine in their press materials, but it sure feels like more.
I do notice that in winter E85 created hard start condition. So I tended to use regular fuel in winter.
All of the guys running high performance street cars around here use E85. It's "poor man's race fuel" to them. Allows much more aggressive engine tuning.
/ E85 Fuel #31
Often a car will feel quicker not based on the total horsepower increase but where the power comes in. For example if the engine bumps up the timing at lower rpm’s because of an octane increase you notice that during normal driving. That was a trick in the day with distributors was to change the springs to softer ones to quicken up the advance.
/ E85 Fuel #32
Watch that video I posted a few posts back. They ran one engine with 3-4 different octane ratings for gasoline and found that the engine called for almost the exact same specs on each grade of gas.
Their analysis of the situation was that octane only helps if your engine is knocking. They got identical HP and Torque curves for each different octane pump gas and racing gas. The only pump fuel that gave them an actual bump in HP and Torque was E85.
Very interesting video.
/ E85 Fuel #33
Yep, I've burned thousands of gallons of the stuff. I live in the Midwest and E85 is less expensive than 87 octane gasoline and at the present time, it's $1.00/gallon less than the 87 octane which has 10% ethanol. My truck can technically run on 87 octane regular but isn't happy doing so, particularly when towing, it will ping pretty noticeably. Most of the pinging when towing goes away with running 91 octane premium that's 90 cents/gallon more than regular unleaded, and E85 makes it completely go away no matter what.
The only issue with E85 is that its vapor pressure is a bit low to reliably fire right off on a cold start when it is below zero. It very rarely gets that cold here but I've been places where it has been that cold. I stuck to no more than 30% ethanol when it got below zero and had no problems starting despite it getting to -40 F during a cold snap.
I learned recently you can get by running lower octane at higher elevations, hence why you only see in it places like Colorado.
That was true for carbureted naturally-aspirated engines that have no ability to change timing or air-fuel ratios at a given throttle position and engine load. There are fewer molecules in the intake air at high elevations and thus there is less cylinder pressure at top dead center, just as if you had a lower compression ratio, and is why you can run less octane. The ASTM figures are that you can decrease octane by about 1.0-1.5 points for every 1000 feet above sea level.
This is less true for closed-loop naturally-aspirated EFI engines that can change timing and air-fuel ratios on the fly, you can run lower octane but it's much smaller of a difference relative to sea level vs. a carbed engine. The SAE's figures are that you can decrease octane about 1 point for every 5000 feet above sea level in a closed-loop EFI naturally-aspirated engine.
It is absolutely NOT true for turbocharged engines where the turbocharger will stuff the same amount of oxygen into the cylinder at higher elevations as at sea level up to at least 10,000 feet or so above sea level, and maybe higher, depending on the specific engine.
I never lived in Colorado but I did live in South Dakota in the past. 85 octane gas was sold in the western part of the state at elevations of roughly 5000 feet above sea level and higher. That old carbed car that was specified to run on 87 at sea level would do fine on the 85 octane stuff as long as you didn't drive below 1500-2000 feet above sea level, which meant you were fine until you drove more than about 250 miles or so to the east. An EFI car specified for 87 at sea level would be below the recommended octane on 85 unless you were 10,000 feet above sea level or higher. A turbocharged engine would be hurting as most today are designed for 91+ octane and are pulling a significant amount of boost and timing to even run on 87 in the first place. Any owners' manual I have ever had for an EFI car has specifically stated to abide by the listed octane requirements regardless of altitude, and that would be why.
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2004 Brenner DOT 407 Insulated T/A Chemical Tanker Trailer (A64194)
2004 Brenner DOT...
TRUCK RAMPS (A64556)
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
2005 JOHN DEERE 4110 TRACTOR (A65054)
2005 JOHN DEERE...
