iphone 3gs ( no wifi ) issue
/ iphone 3gs ( no wifi ) issue #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
ok.. Have wifi at the house. use it often with my tablet. KNOW it's working.
iphone.. last night.. went to check weather.. had an issue getting it to update.. so tried to go online.. it kept using 3g.. went to settings, and network.
the wifi line is greyed out and says 'NO WIFI'
It does not say 'NOT CONNECTED'
I cannot tap ont he button and bring up the wifi setings page.
I turned phone off then on.. no change. turned airplane mode on then off.. still nada..
ideas?
/ iphone 3gs ( no wifi ) issue #2
Of all the stupid stuff my iPhone has decided to do, that's a new one to me.
/ iphone 3gs ( no wifi ) issue #3
Is your wifi a 2.4 or 5 GHz? If a 5, your tablet might be compatible but your 3GS definitely isn't.
David Sent from my iPad using TractorByNet
probably 2.4 but don't know for certain.
phone WAS working on it . I did replace my router within the last 2ys.. but the phone always works onthe house wifi.. or has been till last night. ( have had the 3gs for a while obviously due to it's being oldtech now.. :) )
/ iphone 3gs ( no wifi ) issue #5
Cant speak to the Apple, but my wifes Android, did more or less the same thing. I had to go to Customer support with verizon, get an over the air bug fix.. reboot, worked fine before, works fine now.. can't begin to tell you why it puked.. It did it at the Tractor dealership on their WIFI, just stopped working, and I could not get it to work again at any wifi, including mine at home...This was 8 months ago. and it has worked fine every day since.:confused3:
James K0UA
/ iphone 3gs ( no wifi ) issue #6
James K0UA
could be what this has done.. some kind of software glitch in it's programming and it may need a patch.
i'm gonna go read up on that link posted a mssg down.
I'm no apple nut either..
/ iphone 3gs ( no wifi ) issue #10
Sir Soundguy...I tried to duplicate your problem but can't seem to. One thing that comes to mind is do a reset on your phone. Make sure you have a backup on your computer or prior on iCloud.
Just because you can't get wifi signal wouldn't be a reason for the phone to say "no wifi".
/ iphone 3gs ( no wifi ) issue #11
Did you try a two-button reset? Close all apps, then press and hold both buttons until the phone shuts off. If it doesn't turn itself back on in a few seconds after shutting off, just press the top button and let it boot up. This fixes a lot of weird things the iPhone tends to do.
/ iphone 3gs ( no wifi ) issue #12
I would agree, this is a better first step then if that doesn't work try my suggestion. Good luck.
i've never even heard of a 2 button reset?
/ iphone 3gs ( no wifi ) issue #14
The bottom on the side and the button on the front are the two buttons he's referring to. Push both together and hold for 2-3 seconds until in shuts down.
/ iphone 3gs ( no wifi ) issue #15
Got to win settings and forget that network... And then try again....
remember.. it's not even seeing wifi.
it's not saying no network available. it's saying no wifi period...
/ iphone 3gs ( no wifi ) issue #17
Hmmm maybe it is time to do a backup...
Then a wipe... And see what happens....
If I works.... Software at risk....
If it doesn't time for a replacement....
Oh crap... No wifi no backup without iTunes.
yep.. situation is limited here.. i'm holding out on doing the vulcan nerve pinch on it till I can figure out what to do if it doesn't come back to life. schedule is way to busy this week to drop off the grid trying to revive wifi.. :)
/ iphone 3gs ( no wifi ) issue #19
Doing a wipe or perhaps more correctly stating, doing a complete reset is not a big deal. I have done this countless times on different iPhone and iPads without any issues.its actually good to do. If you're not afraid of doing so and have a question or two, ask away.
i'll try it on sunday as I don't have to work...
so more detail on the 2 button please?
PORTA POTTY (A67714)
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
AIR HAMMER (A64553)
AIR HAMMER (A64553)
PAIR OF FRAC TANK STANDS (A68842)
PAIR OF FRAC TANK...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2007 Freightliner M2 112 Tri-Axle Dump Truck (A66736)
2007 Freightliner...
