Building Horse Fence & Run-in shed in the Winter in VA? What to look out for?
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Folks,
Well it seems my local guy finally got some of the Poplar boards I needed and it is time to get off the dime and get back to work on the pasture fences and run-in shed. The lumber might be in stock today...
Last year I built in November and early Dec, and had NO issues really due to weather.
This is upper central or lower northern Virginia, so we typically do NOT get permafrost etc. but we might have a couple REALLY cold weeks and a couple heavy or light snowfalls.
I'm going to start with a 40' x 40' square with a 16' x 16' run-in shed/tack-feed room in the corner. I will have an 8' gate in each side.
Then I will build a ~240' run of fence along the driveway (something like 54' of it is curved too). A single 8' gate will be somewhere on the curved section, near the wye in my driveway where it is wider to make access with a trailer easier.
After those two sections, I will build a straight 280' section at the south end along the "fire road" with a single 8' gate.
When it is all done, I will have over 1000' of wooden horse fence, and who knows how much T-Post & wire fence inside the treeline...
So...
What are the gotchas I need to watch out for building on nights, weekends, and occasional "work from home" ;) days during the winter?
I will likely start another thread specific to the Run-In shed for all of my n00b questions on that aspect of the project.
Any and all advice is greatly appreciated.
Thanks in advance & Be well,
David
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #2
Hey,
I know for a fact if you build at night, you will need light. :)
Gosh, you got a lot of projects. Winter time construct for ME, is 3/4 speed. I run out of light for some odd reason, I usually get into a groove around 2PM and well, there is only three hours left. I have a hard time getting and collecting tools too, so that takes time.
Your an IT guy, serious, have you considered MS Project? I did this for the house renovations and it actually worked out well for tracking tasks. Now I just use it for projects, just to show the SO what we have done over the years.
I'd go with the fencing, t-posts first, then the run-in. Or -IF- you need the shelter, horses, tools and materials, the run-in first.
T-posts you can get the wife and kids to help. Me and the misses did 4 acres in one day. It was a good time too.
Time is the killer on all those projects, good luck with it! :)
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #3
8 foot gates are small for equipment. A lime truck for the pasture will have a hard time getting through. I've got 12 footers and have nearly taken out either side.
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #4
Agreed, 12' is the minimum to get equipment through IMO. I always use 14' or 16' gates in areas where you'll be driving through a lot, and especially if any hay equipment will ever need to get through. Not every gate needs to be that wide, but there should be at least one into every field. I use 8' gates for ATV's, UTV's and lawn equipment.
As for working in the winter, I build fence and barns almost year round here in the mountains of SW VA and I think our weather my be more extreme than yours. A few of the things I try to plan ahead for are frozen ground and snow/rain. I try to pick a nice spell of weather to get all my posts in the ground, then the weather becomes less critical. Once the posts are in (whether it is for a pole barn or a fence), you can work on it even if the ground is frozen or there is snow on the ground. Aside from the bitter cold/wind and short days, it's just business as usual. :thumbsup:
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #5
I'll definitely agree with the minimum of a 12' gate. And if using T-posts, the plastic protective caps on top would be worthwhile. If there is an animal that can hurt themselves on the least expected object, it is a horse. Just having the tendency to put their head over the fence, or scratching on something, then spooking, and pulling their head back. MUCH less expensive than a Vet bill.
OK, a couple points of clarification...
I clear cut an approx 5 acre area to become the horse pasture (There are a number of threads discussing this last summer/fall, etc.). It is not square, one end curves to follow the driveway loop to the house. Think of it as a sloppy triangle, the hypotenuse is along the driveway & fire road, the other two sides are in the forest.
The fence along the driveway MUST be wooden 3 rail and nice to look at according to SWMBO, the T-Posts are only for the back sides where the pasture will be up against the forest. I currently have t-posts (with caps on the ends) and step in plastic and fiberglass posts holding up a double line ElectroBraid fence that runs 1200' now (I doubled it last summer). I cannot run t-post along the driveway, and I cannot hang gates off T-Posts.
Gates: I currently have a 12' gate that is a straight shot up the easement, and through the main gate. I am pretty sure log trucks could use it. My Tractor is only 6' wide, and my largest attachment so far is only 6' wide. There will NOT be haying (too many stumps, etc.) this is strictly horse pasture. At most I will/should only need to get the tractor in to bush-hog, grind stumps, and EVERY spot I plan a gate, I have plenty of room to go straight in. Yes, I know, bigger is always better, but seriously WHY must every gate be 12' minimum? it seems like over kill. My posts are 8' spacing, and there is NO REASON I can think of that I would need more than 8' gates on the 40' x 40' enclosure where the run in shed will be. I can see where the straight line southern extension MIGHT be better as a 12', and MAYBE the North extension would where the wye in my drivway is would be better as a 12' gate... But it still seems overkill to this n00b. BUT I am LISTENING to the advice and considering...
When it is all said and done, the wire fence in the forest will NOT be electric, and I will use the 2400' of ElectroBraid to divide the pasture in some fashion so I can get grass to grow SOMEWHERE on the 5 acres...
Is there a decent sattelite photo place where I can go get a shot of my property to show you guys to help make it all sense?
Thanks again,
Yes I am listening.
David
Hey,
Gosh, you got a lot of projects...
And that is the TRUTH! PLBBBBT!!!!
:D
David
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #8
Gates: My Tractor is only 6' wide, and my largest attachment so far is only 6' wide. kill. My posts are 8' spacing, and there is NO REASON I can think of that I would need more than 8' gates on the 40' x 40' enclosure where the run in shed will be.
You may want to consider a gate larger the 8' wide if you are taking your tractor in. In theory an 8' gate would leave you 1 foot on either side of your tractor to get in, BUT a gate is actually less then 8' to allow the hinge pin to make up the difference. So now when you open your gate your opening is several inches less then 8'. Also if you make your gate so that it closes up against the post you loose several more inches. I would guess that your 8' opening is now closer to 7' Drive carefully going through that gate with your 6' bush hog on it. Even if you do not go with a 12' gate consider a 10' gate. It will be cheaper to put it in now then when the bush hog sways and hits the gate as you go through it. Just a thought.
Interesting point... I will go measure my current 12' gate, but I'm pretty sure I place the posts just over 12' apart, and that fully open it is at least 11' 9" or so... I use chain around the post to secure the gate.
The 40' x 40' will NOT get bush hogged... Mostly the gates are for moving he horses, but I wanted the tractor to fit... Inside is mostly a small stand of trees and the run-in shed, not much need for the tractor inside after I'm done building it all...
Hmmm...
This will change ALL my calculations if I change anything...
David
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #10
The smallest gate on my property now is 12 foot.
Old age and all I have to do is drive whatever in the middle and not have to worry about what is behind me.... :) :)
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #11
I hope the poplar boards are for the shed and not fence, poplar is a soft wood and is a wood that rots quickly. Easy for the horse to chew as well. Oak would be a much better choice.
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #12
I used 10' gates to match my 10' pipe fence sections. I have a 8' arena drag on the 3PT and it clears OK. What is a little tougher is moving round bales with the FEL. It is hard, especially at night, to see around the bale and hit the open spot until I am right up to the gate. Driving the pickup with the round bale trailer in without pulling in the camper mirrors takes a straight shot also. In the future I will go with a 12' gates.
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #13
I had 2 12'X12' sheds built to match my stables, spent $6000 for both. Metal frame 13' high in front, 10' high in back, metal on the outside, 2"x8" pressure treated T&G on the inside 8' high. In the 2 years since they were built I can count on 1 hand how many times I have seen a horse in one. They would rather stand in the rain and graze. But the wife is happy and that's a good thing.
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #14
Agree. Nothing like going out in a thunderstorm, herding horses to the barn, past the run-in.
Ed,
They are MUCH better looking, they are pressure treated, and solid with very few knots. they are straighter, and more uniform, and in the 13-14months I've had them, flawless.
They also are about $2 per board less cost.
Thanks,
David
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #16
I made 4' walk through gates into my paddock area. I planed down some poplar stock I had, and treated it heavily with Thompson's water seal when new. That was in 2002, and still in good shape, although weathered looking.
Around here, most of the old pin barns had poplar siding, treated with linseed oil. Many are standing in decent shape today.
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #17
Ed,
Thanks,
David
I understand, hope nothing but good, and the treated makes all the differense.
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #18
<snip>
Thanks again,
Yes I am listening.
David
Unless you can get some assets reallocated perhaps your best bet is Bing.
An example of my house and shops in Mississippi.
/ Building Horse Fence & Run-in shed in the Winter in VA? What to look out for? #19
OK, OK, Ok....
Some of the arguement for larger gates makes sense, y'all have pretty much convinced me I need to put 12' gates at the wye and at the far south pasture for access.
I am considering HARD making the 40' x 40' holding pasture where the Run-in shed will be either 42' or 44' square by going to 10'-12' gates in each side...
SO YOU MUST NOW ANSWER THIS QUESTION!!!!!
On my current 12' main gate, I use a wheel at the end of the gate to keep it from sagging. this also requires some levelling of the gate swing area so the wheel touches the ground in most spots, etc. This adds cost to each gate, but it also extends the life of the gate.
SO do you put a wheel on the end of you 12' gates, or do your gates simply not sag, or ????
I'm MUCH less worried about an 8' gate than I am a 12'.
I am leaning towards 10' gates on the run-in pasture and hoping they might not need the wheels...
Those are my current questions.
Thanks again,
Be well,
David
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
