Homemade quick attach
/ Homemade quick attach #101
Unfortunately, I may have to wait until after the new year to find out about ordering the bushings. Patience is not my strong suit. Today, I got a little done by cutting two side plates to length and drilling pilot holes for what will eventually be the holes for the bushings. I'm very annoyed at my chop saw, which tilts out slightly at the last third of each cut, meaning that it's impossible to get a cut that's square along its entire length. I may use this as my justification for buying a bandsaw.
I was unreasonably happy to be able to tack weld the two side plates together and drill the pilot holes through both at the same time, ensuring that they lined up perfectly. Eventually, welding may become passe to me, but for now, it's a thrill every time I stick two pieces of metal together in some marginally useful way.
I'm pondering the right way to design the "U" shaped channel on the top of the bucket-side of the adapter. It seems like it would be easier to pick up the bucket if it flared a little. But I'm not sure whether I should just angle out one side of the channel a little bit, still leaving the half-round tubing at the bottom, or whether I should make the sides of the channel parallel for some distance and then flare. The image below illustrates what I'm talking about.
Or, the third option: flare not necessary at all and I'm over-thinking it.
/ Homemade quick attach #102
Instinct tells me a flare will make loading easier, and the OCD side of my brain tells me a short section of straight "U" is going to be stronger and less liable to slop out than a one sided "V" like the image on the left. I tend to overbuild things, whether that's part of it or not I don't know. If you DO make the bottom a true "U" shape, as long as it extends up to slightly above the center line of the pin that should be enough.
Sean
/ Homemade quick attach #103
I think a little flair is needed to make connecting up with the pins a bit easier. As long as the saddle for the pin to set in is the correct size I don't think it will really matter much.
I plan on doing something lik this set is, I don't remember where I saved this picture from but it shows how he did it.
/ Homemade quick attach #104
Go with the drawing on the right. You need some flare to help get it started into top pins, otherwise you will need to be in "perfect position" forward & back plus square with the attachment when driving into it. Keep the pin slot parrallel to allow for some variation in vertical measurement of pin center to center distance from 1 attachement versus another.
/ Homemade quick attach #105
And THAT is why we talk about this stuff, to get ideas! Really good point, it reminded me that the last thing you want is to have the holes spaced too close together so the pin won't go in.. slightly too far apart is no problem..
Sean
If you're going to flare one side and keep it parrallel all the way down might as well flare the other side a little bit too if you can and make it easier on yourself later. I flared mine pretty good and after the fact am happy I did it that way as its different latching on the bucket 6 feet behind it with not great visibility and using the tractors hydraulics. Plus you cant really see that front flare too well, you kinda rely more on the rearward part of the ear as thats what you can see. What I also did was I took the front flare that engages the pin first, I tipped both of those in on each side so as to not have a sharp corner that would dig into my bucket ears and turn the bucket out of alignment. I maybe bent them 1/8 inch in each and custom made a filler plate to match. Hard to see in my photos.
Ps- Also keep in mind your depth of the pin throat, if too deep may interefere with your bucket.. What I mean is if you you make it too deep the tips of your adaptor will hit the back of the bucket before the pins really engage the throat of tha adaptor. Again, really depends on your bucket setup. My pins are 1.25 and the bucket ears were shallow so I didnt have a lot of clearance and couldnt make my adaptor throat too deep, especially the front half of the throat as when you hook up its half driving into and half curl/lifting up to get the hookup started. Its nice not to have to worry about binding the adaptor between the pin and back of the bucket. If that makes sense..
/ Homemade quick attach #107
How about something like this?
Extend the back of the U up higher (blue line) to give something to push on the pin when driving into it. That way if one side hits first it just pushes the bucket square with the other.
Taper the side plates at the front to allow better roll into the pin. And as Puckgrinder mentioned taper the leading corners of the flange to give easier alignment coming into it.
/ Homemade quick attach #108
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=295437"/>
I like that. That's pretty smart.
The back definatly should be higher, if you have staggared pins its even more important because the way you angle the attachment into the bucket ears will be a little easier to get right because you're never picking straight up on the pin, you more or less drive into the pin and just curling the bucket back should make the connection.
/ Homemade quick attach #110
That is exactly what the carter 3pt hitch "quickhitch" looks like
Welcome to CARTER AND SON'S TOOL AND DIE
/ Homemade quick attach #111
I ordered the bushings from Bobcat today. They worked out to about $7 a pair. I need 6 pairs total--four for the loader side and two for the bucket side, so that worked out to just under $50. It's comparable to what DOM tubing would have cost, except zero fabrication on my end and I'm 100% guaranteed that they will be the right diameter.
I still need to fabricate the U-shaped cup at the top of the bucket-side of the adapter. I didn't think that trying to cobble it together from the bushings was the right choice, so I will probably still end up buying a foot of DOM tubing. I wish, wish, wish, I had access to a brake and the right dies to make a U-bend in a piece of 1/4" flat stock instead, but I don't see it happening. I have tried searching for metal fabrication shops near me, but I'm not searching for the right thing, because everything I find is on a way larger scale than what I'm doing. The places I find seem set up for doing huge jobs, not little one-offs like this.
/ Homemade quick attach #112
Try searching for 'Machine shop". They are usually geared to do small one-off jobs.
/ Homemade quick attach #113
Often times, atleast up here, shops like you are looking for won't have a website. The local phone book or word of mouth is about the only way to find them.
/ Homemade quick attach #114
Yeah, phone book is more likely to list your local machine shop. Also, ask at auto parts places or your tractor dealer, they'll know where the local shop is.
I wanted to do the same thing but its a LOT easier to just slice a piece of DOM down the middle, this will make the two halves you need for the project. The DOM is very close tolerance and will fit the pin like a glove.
/ Homemade quick attach #116
If it comes to it, I will do that, but I suspect that I may be able to get the piece fabricated for similar cost to the DOM, and zero labor. On top of that, I am mildly concerned about the fitup of the joint between the DOM and the wall of the U. If that weld is not 100% smooth, then there will be a wear point that will be nigh-impossible to grind out due to the lack of clearance in the U. Flat stock put through a brake won't have that problem.
When I welded the DOM in I did it on the underside only. All heavy welds were on the outside only. The filler pieces i lightly welded in and I did one side, ground it smooth and did other and used a cutoff wheel to get into the mouth of the U to grind the filler piece to DOM joint. That weld was really just cosmetic more than anything, any maybe to keep it from rusting later on. All the welds but that one were accessible to a normal 3 inch die grinder sanding disc. I knew when it was ground out enough as the pin wouldnt fit in the DOM unless the weld wasnt obstructing it, a go no-go gauge as it were.
/ Homemade quick attach #118
I was thinking yesterday as the DOM is a bit expensive for the pin bosses, I think the pin bosses could be made from say 3/8" plate with a 1" hole bored in it and still perform as they should
Where are ya'll getting your prices from? I think I paid 30$ for a 3 foot piece and only used maybe a foot of it. By the time you drill holes and all that your time is worth more than that.
/ Homemade quick attach #120
Not that it is so expensive, but it is more than any other of the components I would need to finish. My local steel supplier only sells 20' sticks so that's not really an option though if I bought a 20' piece of some flat bar and rod for this project I would eventually use it on other projects.
At the online suppliers a 2' piece od DOM is $38 - 42 plus shipping. Not too expensive but I'm just a tightwad...
Grain-O-Vator Silage / Feed Wagon (A66408)
Grain-O-Vator...
PRIEFERT PORTABLE CATTLE SQUEEZE CHUTE (A64277)
PRIEFERT PORTABLE...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
Skid steer Fork Bracket  (A62679)
Skid steer Fork...
