Homemade quick attach
/ Homemade quick attach #141
Rich. Thanks for posting pictures of your adaptors and such. Your receiver hitch adaptor gave me all kinds of ideas. I had the thought of building some sort of an attachment that could be welded on, cut on, butchered and altered to suit any given need as situations arose. But with your setup, I can leave it alone and simply make any adaptor to fit the attachment. Hm, it just so happens that I have an oddball reveiver hitch laying around somewhere, now if you will excuse me,,,,,,,,,,,,,,,,,,,,,,,,
steve
P.S., just looked at the pictures again. Any one else notice that Rich drilled out some large nuts and used them as bushings?
/ Homemade quick attach #142
Nice catch Steve! I had not noticed that but what a great idea! dom tubing ppbbbht!
I also like your hitch Rich! looks good and functions as it should! Kubota didn't make a QH for my LA302l .....so I DID!!
/ Homemade quick attach #143
I also like the hitch idea -- an completely missed the nuts. I've drilled out nuts in the past for other (similar) purposes but never thought of it for this.
Rich, what's that trimmer attachment?
/ Homemade quick attach #144
I got a little more work done. First, I took the DOM tubing to a local machine shop, where they reamed it out to the proper size to receive the 1" pin. It cost $25, which is about as much as a reamer would have cost me, but I decided it was worth the cost to have it done right, versus me hacking away at it. All told, the DOM tubing has been the single most expensive part of this endeavor: $12 for the tubing, another $15 for the shipping, and another $25 to have it reamed out. I guess the factory bushings were also about $50, come to think of it.
I drilled the holes with a hole saw, then put the bandsaw in the vertical position and cut straight in to make the "cup" for the top. I have been drilling my holes 1/8" oversize to allow precise placement of the bushings, but for the top hole, I drilled it exactly to size, so that I could hit the 9-o'clock and 3-o'clock position exactly with the vertical parts of the "cup".
Cutting the DOM tubing in half lengthwise to make the bottom of the "cup" was difficult. I finally ended up just pushing it through the bandsaw in the vertical position. I did this before cutting it to length, to give me an extra few inches of tube to grip onto.
Next, I cut the top of the side plate down. We had previously discussed leaving the back of the bracket longer than the front, to allow pushing on the implement to line up the loader arms with the implement. After thinking about how the bracket will be used, I am thinking that it may make more sense to leave the front of the bracket long, to allow for reaching out and picking up the implement, versus pushing into it. For a three-point hitch, which was the original example, it seems like having the back of the bracket long makes sense, because you can't "reach out" with a three-point. You are just going to push into the implement and then lift. But with loader arms, you can reach out and pick up, and it seems that would give better visibility, since the QA adapter would be going underneath the bucket pins.
Next step is to tack weld the bushings in place and then get some flat plate made up to finish the vertical walls of the "cup". But I can't run the grinder while the kid is taking a nap, so I can't weld at the moment. More to come!
/ Homemade quick attach #145
I've got another question for y'all: what does the factory QA do about grease on the bucket-side? On the loader-side, I can use the factory pins that have zerks, and the loader arms and hydraulics have grease channels. But on the bucket side, none of that is true. And on the top, the pin isn't even fully enclosed. I'm not sure which would be more of a PITA: manually greasing the bucket-side pins, or cutting grease channels and installing zerks.
/ Homemade quick attach #146
The pins on bucket side do not move so they don't really need much grease. You can smear some on the pins but they will just be a mess when you remove the bucket.
/ Homemade quick attach #147
Oh, of course. It's only when the loader arms extend and retract that the pin angle changes, and only on the arm side. Thanks!
/ Homemade quick attach #148
I've got another question. In the video example on Youtube, the guy picks up the bucket with the top pins and it falls into place against the QA bracket such that the holes line up and the bottom pins can be easily inserted. How is this accomplished? What does the bucket butt up against to line up the holes? It can't be that the bracket is flush with the back wall of the bucket. It seems like that would make it too hard to pick the bucket up. Is there maybe a spacer or something?
I can think of various ways of solving this problem, but I have a sense that there may be a much more clever solution that already exists.
/ Homemade quick attach #149
Usually the top hooks are J shaped to that you can pickup the bucket with them.
Aaron Z
/ Homemade quick attach #150
Joshua, are you going to grind the plates to clean them up before welding? ...after you kid wakes up?
/ Homemade quick attach #151
Aaron: sorry if I'm being obtuse, but I'm not sure how this answers my question. I can see how to design the top-front of the QA adapter so as to allow picking up the implement via the top pins. I'm not sure the best way to ensure that the implement's front-bottom holes line up with the matching holes on the QA when the bucket is picked up by the top pins. The bucket will fall backwards until it hits the bracket, I think. Maybe the right thing to do is to weld offsets onto the bucket so that when it hits the bracket, the holes line up.
Yes, exactly. At least the areas that will be welded. It's surplus steel, so it's pretty rusty even after I've run over it with a wire wheel. I plan to try electrolytic rust removal on the two brackets before welding the rod in between them and then painting. That should be pretty cool!
Thought about that too when building mine. I didnt worry about that so much as I have different attachments and welding a stopper for one may not work with another another attachment. I would get your QA all done first, and then attach your bucket with all pins in place, and then just weld a small 1/4 or 1/2 sliver of metal ( maybe an inch or two tall) where the bucket ear would contact it on the QA. For me it became a moot point as you'll see when you get yours done you'll likely have to move the attachment around slightly to get the lower pins to slide through. Its easy enough and you can mitigate any straining to move the attachment by simply curling the QA down so your attachment more or less is nearly swinging on the top pin. Just a little bit of trial and error thing. My pins slide in pretty nicely, each attachment hooks up slightly different in the sense they all are weight diffrently. The forks for instance i tend to curl down more than a bucket due to the weight hanging out so far.
/ Homemade quick attach #153
As you said Joshua, longer side on the front of the U on the top pins is the way to go. No grease needed on the top pin, it never moves. Messy but I find it does help quite a bit on the bottom pin. A bigger help (which I have yet to do) is to have a loop on the bottom pin big enough to get your hand in to pull/push/twist as you install/remove. My factory ones are impossible to get a hold of when fully seated.
The factory QA has a stop built in to line the pins up for installation. It's not perfect and I usually lift the bucket elbow high that I can give it a bit of a push as needed to perfect the line up. I have to build up the ear on my forks so that they hit the stop but they are light enough that they are easy to push by hand to line up. I'll see what happens in spring when I build a grapple.
/ Homemade quick attach #154
Well, folks, I have hit what, for me, is currently a showstopper. Here's the situation. I realized that, in order to get the bucket side of the adapter narrow enough to fit within the ears, I was going to have to put a plate across the front of the loader-side. If you look at the factory adapter, you'll see they just do a dog-leg bend to bring the bucket side in, but of course that's not an option for me. So I put a plate across the front, making the loader-side of the bracket into a U, and no matter how carefully I did it, the way the weld pulled on the joint when it cooled pulled the bushings out of alignment with each other. It's not very much out of alignment--if I get two big adjustable wrenches and pull hard, the pin just slips right through. But it's far enough that I don't consider it workable.
The way I see it, there are at least three approaches. 1) heat the joint with a torch and bend it. Problem: I don't have a torch. 2) Run a reamer through the bushings to open them up and put them back in alignment. Problem: I don't have a reamer and I'm concerned that the amount I would have to open them up to bring them back into alignment would make the pins too sloppy. 3) drive the pins in with a hammer and never take the QA adapter off the tractor again. Hmmm... tempting, but obviously unacceptable. I tried going hot and welding up the outside of the joint, to try to pull the pieces back into alignment, and it made a tiny bit of difference, but not enough.
Any thoughts? I wish I could just get a great long lever and bend the thing, but it's got enough flex that it always pops back the way it was. At the moment, I'm at a dead stop until I solve this.
I had the same issues. I had a torch though and was able to bend what i needed back into position, hence why I said way back when using a press brake would be the ideal way to do this as the heat distorts everything it seems. It took a little adjusting to get it where I wanted it.
/ Homemade quick attach #156
So right now you have just the U for the tractor side without the bucket pieces? Set it with the ears of the U down on something very solid and hit it with a BFH in the center of the U and you'd be surprised how much you will be able to bend it out. Ideally use the round of a ball-peen hammer. Hit solid and hard and check after every couple swings for pin fitment. Once you get them to fit, don't do any further welding without pins installed and only weld a bit at a time.
Is the binding just between the pin and the 2 sides of the U or does it bind on the loader/cyl mount also? If it only binds on the QA adapter, it's really not that big of a deal, you'll likely never take is back off again anyway.
/ Homemade quick attach #157
Joshua,
Maybe you explained it in your post and I didn't understand but I'll offer suggestions for both ways...
If the two top ends of the 'U' are too close... try to drive something just slightly wider in between and then lay the bracket on its side, on something solid (I have a short piece of railroad rail just for this purpose) and hit it hard with a BFH all the way along the welds. You'll be surprised how much it will open up.
If the tops of the 'U' are too far apart, squeeze with a c-clamp and pound with the BFH as described above.
You could also go back to the machine shop... they likely have a hydraulic press that could 'massage' it slightly.
/ Homemade quick attach #158
Thanks, folks. I will give these suggestions a try and let y'all know how it goes.
/ Homemade quick attach #160
Have I mentioned how awesome you guys are? You're awesome! I keep having to remind myself that this is a learning project, and boy am I learning.
Per your suggestions, I rigged up a spreader by buying one of the couplers they make for all-thread and mating it with a bolt. I bought a grade 8 bolt because I wasn't sure how much pressure the threads would be under, and since I was just buying one, the price difference was negligible.
I applied pressure to the side-plates until the pin slid in as smoothly as possible, then I turned the bolt another half-turn or so until the pin bound. I figured taking it slightly past the desired point would be helpful. One of the pins had to be expanded, and the other had to be compressed (I used a C-clamp). Then I beat on it with a 4-lb mallet. Shortly thereafter, the bushings were as aligned as they were going to be.
In retrospect, this could all have been avoided if I had drilled the holes, then built the adapter, then aligned and welded in the bushings. However, this would have prevented me from welding up the back side of the bushings, which is one reason I did it the way I did. I'm not sure which would be more desirable: easily aligning the bushings or having full-pen welds. Because the bushing holes were drilled oversized, not welding up the back side would leave an ugly gap. Only I would know it was there, but I'd know.
Anyway... onwards I go with this silly project.
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A65053)
2014 VOLVO A25G...
Pull-Type Hay Stacker (A66408)
Pull-Type Hay...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
New Holland 499 MoCo (A66408)
New Holland 499...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
