Catastrophic hydraulic top link failure
/ Catastrophic hydraulic top link failure #1
pclausen
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
I was driving down a blacktop road and then I hit a transition to gravel and there was a little bump (I have driven across this transition dozens of times with various implements). This time I happened to have my stump grinder attached. I was going maybe 10 mph.
Here's what happened to the top link:
Not sure if you can make out the letters, but is was a forged eye.
The stump grinder dropped to the ground and was coasting on the cutting wheel until I came to a stop to investigate what happened. After pulling over, I walked back to the shop and got my manually adjustable top link and was back in business and the stump grinder still works fine. Whew.
If I had had my 2200 lbs chipper mounted on the back when it let go going down the road at speed, that could have been really bad.
Was this likely due to metal fatigue of some sort, and would it be likely to happen again if I replace with the exact same make hydraulic top link?
/ Catastrophic hydraulic top link failure #2
I suspect it was a fluke, I would get the replacement and move on. If it happened a second time I would change cylinder brands.
/ Catastrophic hydraulic top link failure #3
I agree with jeninsph. It could be pot metal they used or it was under stress developing a stress fracture when stump grinding. Either way - it may not be strong enough for your uses/needs. Perhaps you can weld on a new eye of a different brand and call it a day. If it happens again with a new stronger welded on eye - I'd start upgrading the unit.
/ Catastrophic hydraulic top link failure #4
looking at that eye, i'm thinking its simply not heavy enough even for a cat 1 toplink. I use both cat 1 and 2 toplinks depending on the tool attached and the cat 1 link looks to be way heavier than that. as for being pot metal, thats rubbish. the mfgr would be leaving themselves open for all kinds of lawsuits.
/ Catastrophic hydraulic top link failure #5
Looks flimsy to me. I'd suggest a different brand.
/ Catastrophic hydraulic top link failure #6
sucks you would have to replace the whole piston rod since it isn't a threaded on eye, are they all like that?
/ Catastrophic hydraulic top link failure #8
Not a big deal to weld on a new one, just run it all the way out and cover the whole rod with wet rags to keep the seals cool and the rod spatter free.
Aaron Z
/ Catastrophic hydraulic top link failure #9
I would say it could be a fluke, it is likely from a stress fracture and it is definitely light weight for a 2200 lb implement. I would try to find someone that can weld a new eye on as long as they know what they are doing and you get a cat2 eye otherwise look to upgrade when you replace it. That is a lot of weight when you took a bounce and likely previously fractured slightly.
Let us know what you decided on.
/ Catastrophic hydraulic top link failure #10
Aaron Z
I'd consider the above advice as the path to follow. Get a beefier rod end and take it to a good weld shop if you're not comfortable doing a multipass weld without porosities or cold shuts in your own shop. That rod end looks a bit delicate for going over bumps at speed with a 2200# implement dangling off the top link. Is that a class 1 or 2 top link?
2020 Hino Garbage Truck (A60352)
2020 Hino Garbage...
Roto Grind 760 (A60462)
Roto Grind 760...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
Iranch IRGC40 High End Mini Golf Cart (A60463)
Iranch IRGC40 High...
TANK MANIFOLD (A58216)
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60352)
2012 International...
