Catastrophic hydraulic top link failure
   / Catastrophic hydraulic top link failure #21
Anyone got ideas for how to prevent a similar failure? Is it a good idea to lock the 3 point up with the knob under seat when transporting heavy implements over long and bumpy distances? What about adding chains or a ratchet strap between the tractor and implement somehow to "help" the top link handle the load + bumps/shocks?
   / Catastrophic hydraulic top link failure #22
John,
Next failure might be a side link failure, not a common problem to be too concerned about. If you have a bumpy road to traverse I would sugest slowing down for the potholes.
In most cases where the road is rough I usually trailer the tractors to minimize damage.
   / Catastrophic hydraulic top link failure #23
Well guys, it was one of my top links. :eek: It was a cat 2 end, but not heavy duty. I have since gone to all heavy duty ends on the 3' cylinders and doubt that this will happen again. The std cat 2 ends are just not strong enough to take any additional load stresses such as the bouncing that was apparently going on. :eek: I was notified of this failure this morning and the replacement is done, paint is drying and will be shipped out tomorrow. Oh, and all with no questions asked, period. I don't want any failures out there and this is CLEARLY A FAILURE. :ashamed:
   / Catastrophic hydraulic top link failure #24
Brian - what a great response, though I know it pained you that you had to do so (and that it occurred at all). Thanks for being a standup guy running a standup business. Makes me even happier I ordered a toplink from you, and can't wait to get it.
   / Catastrophic hydraulic top link failure #25
Not a big deal to weld on a new one, just run it all the way out and cover the whole rod with wet rags to keep the seals cool and the rod spatter free.
Aaron Z
thats what id do
Edit: looks like Mtn stepped up. Thats an even better solution.
   / Catastrophic hydraulic top link failure #26
Oh jeez
Oh no
Oh gosh
Will mine do that!!!!
Can I get a refund?
Just joking.
But seriously, Brian was great to deal with. I had what seems like a hundred emails w/ him going back and forth so he could make sure I got just what I wanted/needed.
Can't wait for my TnT to show up.
Thanks for being a stand up guy.
   / Catastrophic hydraulic top link failure #27
Oh jeez
Oh no
Oh gosh
Can I get a refund?
Just joking.
Yours my friend will have the big ends to start with. :thumbsup: Someone mentioned pot metal. :confused2: My guess is if it says forged on it and you can weld it, then it most likely isn't pot metal. ;)
   / Catastrophic hydraulic top link failure #28
That IS an awesome response. Especially considering he didn't point you out as the seller, even though he had the opportunity. Way to man up and rectify the situation, then publicly admit the fault. I know where I will be going for a tnt if I ever get around to getting the hydraulics plumbed.
   / Catastrophic hydraulic top link failure #29
Brian, I'm with the other posters here. Your response is exactly what is missing in much of today's business world. A hydraulic top link has been on my list of "tools" that I wanted for the JD 3720 for some time. Your product just jumped to the top of the list of suppliers. We will be in touch.
   / Catastrophic hydraulic top link failure #30
Aaron Z
I do work for a local farm and have welded new eyelets on cylinders either because they wore out or got damaged. In some cases I machined larger ones to make them stand the abuse the operators could give them. Never had an issue with them after so Aaron is giving you good advice. :thumbsup:
   / Catastrophic hydraulic top link failure #31
Thanks, just repeating what I have seen recommended on here various times.
MtnViewRanch, if we ever need a hydraulic toplink or a Top and Tilt kit, I know which one place we will be looking.
Aaron Z
   / Catastrophic hydraulic top link failure #32
Good for you, sir! Everybody knows "stuff happens", that's a given. It's the response afterwards that shows the caliber of the person (or company). Keep it up and have a Merry Christmas!
   / Catastrophic hydraulic top link failure #33
Was this likely due to metal fatigue of some sort, and would it be likely to happen again if I replace with the exact same make hydraulic top link?
To understand real technical reason, the crack should be studied in a laboratory. It can be due to fatique or manufacturing error (weak structure, forge default, material, heat treatment, a residual crack at beginning propagated later in time which showed itself at a shock load.) We don't know real reason for failure, but, we know one thing that it isn't the cylinder which failed first, so, even if it was a manufacturing error, it must be an accidental, escaped out of quality control type of product. Poor quality toplinks usually fail in cylinders, causes leakages, etc. Eye in this toplink is a cheap part of the total cost, so, I don't think mfg error is intentional if it is mfg error.
   / Catastrophic hydraulic top link failure #34
^ good call. But it doesn't matter on the user end as the supplier is replacing it with a more robust unit. As a user, that's what's important!
   / Catastrophic hydraulic top link failure #35
Brian,
Great that you stepped up and dealt with this so quickly.:thumbsup: Good service such as yours will be remembered by all of us here.
   / Catastrophic hydraulic top link failure #36
Aaron Z
x2!!!!
   / Catastrophic hydraulic top link failure #37
Brian,
Couldn't have said it better myself...
   / Catastrophic hydraulic top link failure #38
Here's a closeup of the metal surfaces that broke.
I too am very glad it didn't happen with the 2200 lbs chipper attached! My stump grinder weigh a little over 1000 lbs. My Bush Hog 3209 cutter weigh as much as the chipper, maybe even a little more. I also recently got a Valby 3pt log grapple that could have put a lot of stress on the top link when lifting logs off the ground.
The top link is a 3" cylinder and cat2 specs as far as the pin dimensions, etc.
I did contact the seller and a replacement is on its way at no charge. It also incorporates a different design with beefier ends.
srs, yes, I certainly have been though a lot worse than this before!
The quality of this picture shows that the failure was very sudden. It may have been instant, or may have begun as a crack a million or so milliseconds before that stayed tiny until the high failure load. The failed area is fresh and shows no rubbed area or rust. With some attention in the finishing stages that meager eye could probably reach an acceptable durabilty level by blunting/peening all sharp edges/corners in stressed areas. Thats the kind of thing to do only if you are stuck with it. ... More metal is cheap in this application. MtnViews fix will be bullet proof.
larry
   / Catastrophic hydraulic top link failure #39
I had another thought on this, if more OEM's and vendors would step up to the plate like this, we (the TBN members) may not see threads deleted and/or censored like we have so much recently. We will never know if its the ownership protecting their financial interests or the vendors not wanting the negative press.
   / Catastrophic hydraulic top link failure #40
All I can say is that I have been in business for myself since 1975. :eek: I am very good at what I do. Stuff happens beyond my control, whether it has been a material failure or customer neglect or even abuse. I have ALWAYS taken care of the problem and will continue to do so. If I ask questions, it is because I want to understand how or why the problem came about. No blame is brought up, just if some things are done-handled differently then the problem might not occur again. ;)
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
1986 KUBOTA R-400 WHEEL LOADER (A60429)
1986 KUBOTA R-400...
