Hydraulic problems Power Trac 1850
/ Hydraulic problems Power Trac 1850 #22
It looks similar to the VSP on my PT-1445. Pump and piggy back pump is made by Eaton.
Here is some data on Eaton pumps.
Pumps
/ Hydraulic problems Power Trac 1850 #23
Pumps
The piggy back may be an eaton (cessna), but that hydrostat isn't......look at the link I provided, it's the same pump as the Hydura Oilgear, the control lever cover assy that gives it away
/ Hydraulic problems Power Trac 1850 #24
I have removed the pump. It was just the manual overrides that was stuck on solenoids, the electrical function is ok. I really need to know the brand of this pump ( Se picture ). Is it a good idea to have a look myself inside this or let a profesionall gay handle it?.View attachment 292398
Did you say that your drive was controlled by solenoids?
The lever on the pump in the last picture looks like a manual lever to move the squash plate.
In reference to Terrys EMAIL, I have it as terrye@power-trac.com
Hi, Thanks for help all of you. wdchyd is right it is Hydura I now find an exact same at Surplus center : .86 CU.IN./ .20 Cu.IN. | Piston & Hydrostatic Pumps - Quadra Trading Corp . this will make it a little easier I guess. I hope I can find the assembly drawing somewhere. My forward / back is controlled by solenoids, but the speed is manual lever from the pump. The Hydura pump at Surplus center is it used? Some warranty? You think.
PowerT 1850
/ Hydraulic problems Power Trac 1850 #26
Good price on that pump.
Here is the warranty from Surplus.
Surplus Center - Help
A copy of the warranty, if any, for an item in this catalog may be obtained, at no charge, upon written request addressed to:
Surplus Center
Warranty Department
1015 West "O" St.
Lincoln NE. 68501
When I will make my PT as new, is this the right wheel engine to use? Surplus Center - 28.3 cu in HYD WHEEL MOTOR W/5 BOLT HUB
/ Hydraulic problems Power Trac 1850 #28
If you replaced all four, would probably work.
I believe I would get a parts manual from Terry so you get a hyd motor that matches up with the other hyd motors. He should be able to Email you some data.
If you use a different hyd motor, say a 25 cu in, or not the same cu in displacement, then the rpm for that motor will be different that the rest, with the same GPM.
What is the manufacturer and numbers on your current hyd motors?
Can you verify whether the motors are in a series/parrallel arrangement?
Did you ever contact Terry. He has been most helpful to all of us.
Check the shaft size also. It is probably a tapered shaft, and hub.
/ Hydraulic problems Power Trac 1850 #29
I wouldn't be a bit surprised if that main pump is for for/rev and the solenoid was for 2wd vs 4wd .....or speed control (series vs parallel)
You could be right, but never seen them use the pumps for anyting other than for/rev.......it would be a waste of an overcenter hydrostat pump to configure it that way.......the swash-plate design is much more efficient and more expensive to do so
as always, someone (other than factory) may have jury-rigged that way
I wouldn't just buy a new pump till you tear it down and inspect the innards.......the rotation group will either be trashed or pristine......usually openning these up will help determine that.......where you said it crapped out all of a sudden, it will be quite obvious if it is the pump
Changing hyd wheel motors with anything other than the exact same displacement will be a nightmare if they are different.....be carefull
Took a peek under the lid. Found pieces of metal, is the same as the entire oil system is packed with pieces of metal? Well no turning back I guess. Dismantle the rest. Any concerns? Do I have too clean the hole hydraulic system? Buy a new pump? See attached photos. WDCHYD , is this the overcenter contruction that can also make forward/back. 2012-12-15 001.JPG2012-12-15 002.JPG2012-12-15 003.JPG2012-12-15 004.JPG
/ Hydraulic problems Power Trac 1850 #31
the best is to tear down the pump completely......assess the damage, look carefully at the mating parts on that rotating barrel (you'll see where the valve plate meets the barrel) those surfaces need to be not scored......
Look at the pistons.....the shoes on the end should not be flopping loose
Please take a bunch of closeup pix of more damage......
Those parts are avail but depends on just how much is needed to repair
Even after you rebuild or replace pump, the components connected to this pump need tearing down and rinsing (including the hyd motors), if not the debris that is floating around between the pump and motors WILL do more damage if not flushed out
It's entirely possible the hyd motor damage from the original repair was was the pump coming apart and throwing debris into the hyd motor
/ Hydraulic problems Power Trac 1850 #34
That doesn't look good, needing a new rotation group at the very minimum, pricing out a new pump may be wise
Was there any original pump ID number on your old pump......the new pump you have a link at Surplus Center looks like the rear aux pump has the wrong mount and a different gear pump (smaller)
Don't forget these pumps are put together using different displacements, mounts, shafts and ports......sometimes you'r just as well not getting from a place like Surplus Center cuz they offer "surplus" excesses from other companies that cannot sell them, that way the price is cheaper but the model codes are different
/ Hydraulic problems Power Trac 1850 #35
Look at the teeth on the pump to engine, you will need to match those splines. and diameter.
Your PTO pump on the back of the VSP pump may fit, and might not. If it has the same number of teeth and diameter, then just bolt the PTO pump on the new VSP pump.
As far as I can tell, my wheel motors are connected in a series/parrallel setup.
My hyd system is a closed loop hyd system. The same fluid just rotates through the wheel motors, and the charge pump replenish any loss through leakage from the wheel motors, and also flushes the hot fluid from the pump to the radiator and then tank. My wheel motors also have drain lines.
One side of the pump output call it #1, goes to a tee. Half the flow goes to the back and the other half goes to the front. The back hose goes to a wheel motor, and the output from that wheel motor goes to another wheel motor input, and from that motor goes back to the input of the VSP pump. The back half is parrallel with the front. The return from the second wheel motor in the series circuit returns to the pump. The return flow is coupled through a tee and sent back to pump.
In reverse mode, the flow is from #2 port, trough the wheel motors and back to pump , radiator , then tank.
When you select fwd, the fluid flows to turn the wheel motors in a fwd direction. When you select rev, the fluid flows in reverse through the wheel motors.
It appears that the 3000 psi is developed across two wheel motors in series.
There is a 10 micron suction filter on my charge pump.
Your system could be connected so the left rear and right front is powered in a series circuit.
I am not sure there is standard with all the Power-Tracs.
/ Hydraulic problems Power Trac 1850 #36
You could make up your own circuit, such as a parallel wheel motor setup, but in a parallel arrangement, if one wheel loses traction, most or all of the flow will go through the motor with the least resistance.
You need to know how much torque you need to move the machine at a certain speed with a load.
To go parallel, since the pump will produce about 3000 psi, all the wheel motors need to be able to handle the 3000 psi . Now you need a VSP pump that will provide the GPM for the speed you desire.
You could do the series parallel like mine, or a series parallel but using the left front and the right rear, so as to always have some traction.
Thanks for all help! Is there any good literature that descripe building hydraulic system like this? What is the best way to clean the hoses? By compressed air and a small plastic tube? Can you give me links to useful pump and wheel motors. Even filter to suction side to protect the pump. The ID- plate is gone on my pump, can it be possible to get a new rotation center anyway for this Hydura pump?
/ Hydraulic problems Power Trac 1850 #38
Oilgear Hydura Hydraulic Piston Pump PVW w Solenoid | eBay
Oilgear Hydraulic Variable Displacement Pumps
Send a picture to these guys above and maybe they can put you on track for parts or a new pump.
Wheel motors.
http://www.surpluscenter.com/sort.asp?catname=hydraulic&keyword=HMWM
http://www.whitedriveproducts.com/productPages/CE.html
http://www.sauer-danfoss.com/Products/PistonPumpsandMotors/ClosedCircuitLowPowerPumps/index.htm
As far as cleaning out hoses and other valves and motors, I think I would add an inline high pressure filter in the wheel motor circuit at the pumps input hose and use fresh fluid to circulate through the filter.
The charge pump on my VSP has a 10 micron suction filter , but that only filters make up fluid for the closed loop hyd circuit. The fluid coming into the suction filter is coming from the tank.
If you can find a small oil gear pump, you can make yourself a filter cart with two filters, a 10 micron and a 1 micron filter with gages, and a timer. Plug it into your tank and let it run as much as you need, checking the filters often .
You could run a lint free cleaning ball through all the hoses if you really want to get into large scale cleaning.
You might as well do a through job of checking all the hoses for cracking flaking, and general deterioration.
/ Hydraulic problems Power Trac 1850 #39
I use a solvent based cleaning tank w/air to clean hoses while off the machine......looking carefully you'll probably need more parts than just a rotation group to renew the pump (swash plate, valve plate, bearings ect)
Any way you can get the factory people to come up with a model code..??......with that you can figure out what the displacement is and possibly change it over to a different brand if parts not avail
That link on the Tennant sweeper may be helpfull as far as an exploded breakdown sheet but not for part numbers (cuz they may be from a different size pump)
/ Hydraulic problems Power Trac 1850 #40
Using a 45 HP diesel running at 2500 rpm.
A rough guess is that you have so much HP to turn all the pump you have, If you know the displacement for the other pumps, each one takes so much HP, so you can figure the HP to power the two pumps you know, and the remainder of the HP you can use to figure the VSP displacement.
If these two displacements are known
? Steering pump is a 3 GPM, .3 cu in displacement, at 3000 psi = 6 HP
? PTO pump 8 GPM, at .7 cu in at 3000 psi = 16 HP
Estimated HP available for VSP pump
VSP ------11 GPM-----1.0 cu in -------------= 23 HP
So if the engine was a 45 HP and the other pumps use about 22 HP, then the VSP would use the other 23 HP for drive.
This is a possible maybe scenario.
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
2001 International 4000 DT 466E (A60462)
2001 International...
2001 Ford F-450 Super Duty Flatbed  7.3L Power Stroke Diesel (A63688)
2001 Ford F-450...
