Loader stuck in air Deere 4610
   / Loader stuck in air Deere 4610 #1
turboviking
deere 4610
Hello! I have a JD 4610 with factory installed rear hydraulics - and it is switched electronically with a rocker switch on the right operator's console panel. Some time back a problem started that after mowing or doing work with the rear hydraulics only, the front wouldn't re-engage. It wants to and when the switch is pressed the rear is disabled (top and tilt) but the front loader won't work. The tilt function works fine, but the raise and lower won't. I've checked wiring, and such, but now I'm stuck with the loader in the air and it won't come down. It WANTS to do something and will go up and down about an inch or two, but that is it.
Any idears? Anyone really understand this setup and what valves / solenoids etc. do what?
Thanks in advance.
Troy
   / Loader stuck in air Deere 4610 #2
I have not got the electronic set up but something similar happened on my 4520. Did you by chance recently remove the loader? I removed mine one time and got the hoses crossed and it did the same thing. Hope that helps. Mark.
   / Loader stuck in air Deere 4610 #3
Reseat the QD's.
   / Loader stuck in air Deere 4610 #4
VERY IMPORTANT!!!! Be sure to support the loader before you start working with QD's. It could fall on you and hurt you very badly.
   / Loader stuck in air Deere 4610 #5
Yes, with it in the air there will be pressure on the fluid in the lines. It may not fall because it should be captured automatically as the QD is released, but that pressure from supporting the weight will surely prevent re connection.
larry
   / Loader stuck in air Deere 4610 #6
Are your loader valves solenoid operated or manual?
If they are solenoid operated, you could apply 12 v to the solenoid .
Some solenoid valves also have a manual way to move the plunger.
Hello, it is solenoid operated. I see only one solenoid. I plan to remove it and check the condition - but still seeking someone who understands and can explain the design of this hydraulic circuit. HUGS -
Troy
I assume the QDs are quick disconnects. I can do that and will. Thanks for this suggestion.
Troy
Troy
No, Mark, loader has not been off for some time. Thanks
2013 MACK (A50323)
2013 MACK (A50323)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
