New ck 35 owner
/ New ck 35 owner #1
Illini22
Gold Member
Northern Illinois
2013 Kioti dk40 hst, wright stander zero turn
I just left the dealer and left a $1000 deposit on a new 2011 ck35 hst. Loader, quick attatch bucket, suspension seat, r4's, grill guard and bucket hooks. They don't fill tires so I'll have look elsewhere for that. I may have them install remotes, $340 for one set, another $430 to turn it into 2 sets. I have know idea if ill ever need them but may add them anyway. image.jpgimage.jpgimage.jpg
/ New ck 35 owner #2
Congratulations on the new tractor. If you are going to spend $ on adding rear remotes, now it the time to do it and get both sets. If you wanted to add that extra one later it would be the same $340 as only 1, unless the price goes up and I have not seen it drop.
/ New ck 35 owner #3
Congrats and welcome to the pack!! Get both sets of remotes now. you won't regret it.
/ New ck 35 owner #5
Congrats, you'll love that tractor. I'm confused though, the CK35 should come with 1 set of remotes. I had a 2011 CK30 and it had one set from the factory, I had the second installed for $500 all in.
/ New ck 35 owner #6
I was wondering about the lack of 1st remote too but didn't mention it. Not sure if it was something Kioti took out as part of cost increases & keeping them to minimum. Maybe this one was destined for Bobcat (which doesn't put 1 remote standard) and someone accidentally put orange sheet metal on it.
/ New ck 35 owner
Thanks for the replys. I have know idea if one set comes standard or not. I'll have to look on the website. Are there better remotes than the ones that motion offers? Also looking for a box blade a tooth bar or ratchet rake and or cutting edge for the bucket.
/ New ck 35 owner #8
I think the CK only came with optional rear remotes and KiotiKen's must have had one installed by the dealer. Attached is page 8 of the 2011 CK sales brochure which shows the rear remotes as an option. It looks like the 2nd rear remote was just available on the CK27 and above. I recall that is the case when I got my DK35.
  • 201101_Kioti_CK_Page8.pdf
/ New ck 35 owner #9
Well, I stand corrected, looking at the specs, remotes are optional. I guess my dealer just installed the first set or ordered it that way, but I certainly never discussed it with him. We are very fortunate when it comes to remotes compared to other brands. I added a second set to the CK, and I'm in the process of adding a second set to my DK and in both cases, the price was the same, $400 for the kit. If you had the other orange tractor, those remote kits are north of $1K.
/ New ck 35 owner #10
Get a tooth bar instead of the ratchet rake or cutting edge. Saves you money and it does both.
/ New ck 35 owner #11
Liledgy, In your other thread you mentioned rear remotes costing just under $800, in this one price is little over $400. If they dealer is going to charge you close to $400 to install, tell him to stick it where the sun doesn't shine and take the kit home, install it yourself. This kit whether 1 or 2 remotes only takes dealer with air and air rachet about 1 - 1.5 hrs to install. At home with simple hand tools (3/8 drive ratchet, metric sockets, & set of metric open end wrenches it takes about 2 maybe 2.5 hours to install. It is very simple and the instructions are well laid out, easy to understand. You need to have dealer nail down the price of the remotes and installation. Most dealers will charge lsit price on the kit and install at no charge if it is figured in with the purchase price.
/ New ck 35 owner #12
The first set is $340 and the second is another $400 for a total of $740. That sounds about right to me. My dealer charged me $500 with tax and install for the second set (and as mentioned in the other thread, it came with float). I was planning to do it myself this time, but I don't think I'll find the time and I'll have him do it again.
/ New ck 35 owner
Ssdoxie, kioti ken, that's correct. $340 for the first set, and the second set which, I believe ties into the first is an additional $4xx dollars. So, just under $800. Is their a need for triples? If I buy a box blade what are the other things I'll need for trim and tilt?
/ New ck 35 owner #14
I wish you could get triples, that exactly what I need for my snowblower.
/ New ck 35 owner
Ha! I guess I'll settle for two sets. After remotes are installed, then You buy TNT? What other additional parts, hoses, etc. are needed?
/ New ck 35 owner #16
After the remote(s) are installed, you'll have one/two little levers on the right side of the seat, just below the 3pt position control lever. Each one will have 3 positions, the first one will be labelled A - N - B and the second C - N - D and they will control the flow (both amount and direction) of hydraulic oil to the port(s) at the back of the tractor. If your second remote is like the one they installed on my CK30, you'll also have a float position, which is great for a TNT kit (think of trying to attach the hydraulic top link with out it). The OEM kits are slick and obviously fit the tractor perfectly. Since you're not going to save much or anything buying a 3rd party version, I'd stick to the Kioti kit.
On the back of the tractor, you'll end up with two ports for each remote you add, so 2 ports if you get 1 remote and 4 if you add both sets. For each set, one is supply and the other is return, depending on how you move the control lever.
If you want more than 2, you need to use a different solution, and it'll get expensive. You'd still add the first 2 kits from Kioti and then do something like a 3rd function kit or add-a valve kit. Lots to choose from, all expensive. I'm either going to leave one disconnected (and get good covers for the ends) so I can change them as I need to, or remove the hydraulics from my rear scraper blade and only use chute rotation and deflection. The extra expense isn't worth it for me.
The only other thing you'll need is something to plug into it. If that's TNT, then the kit should have the lines ready to go. You can buy it now, or wait, either way, the kit will be standard fit for your machine.
/ New ck 35 owner #17
Congratulations on your new tractor, for me I would recommend a minimum of two rear remotes, got three on my last tractor. I didn't get a "float", but would if I had it to do over.
The hydraulic top link is one of the best things I ever bought.
/ New ck 35 owner
Ken and triple, thanks for the info. I never had to think about these things on my old b7100. I'll call dealer today and check on the float. I assume a TNT kit comes with a hydraulic top and side link, hoses and the couplings? Do you have any box blade suggestions? Size, brand? I've searched a bit and it seems I should get a 60"-72".
/ New ck 35 owner #19
I think I would stick to the 60", that's what I had on my CK30 and I still use it on the DK45 although it's now undersized and dosen't cover my track. Even so, I've still been able to stop the DK dead in it's tracks pulling it with the rippers all the way down.
I would get as heavy a box blade as you can or are willing to pay. Weight will be your friend using the box blade and also with the other important role it will likely play for you, ballast weight. I'd look for one with the arms welded together as opposed to bolted together.
/ New ck 35 owner #20
Yes, Top and Tilt will have the hydraulic cylinders. I use the third set of remotes to operate the scarifiers on my Land Pride HR3584. LP also offer hydraulic scarifiers on the lighter HR25 Series. I personally like Land Pride, but others make good box blades too, I've just never used one. I have a BB2584 and HR3584.
2019 Nissan Sentra (A61574)
2019 Nissan Sentra...
CATERPILLAR 573D FELLER BUNCHER (A64276)
CATERPILLAR 573D...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
Caterpillar D5M and D5M LGP Dozer Service and Parts Manuals (A63117)
Caterpillar D5M...
2025 44in. Hydraulic Stump Grapple Bucket Mini Skid Steer Attachment (A61572)
2025 44in...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
