generatore to waterwell electric conection
   / generatore to waterwell electric conection #11
My pump has the capacitor box mounted in the basement and lines out to the well for the submersible. If yours is similar and you try and wire a plug into the line without your capacitors you're in for a world of hurt.
   / generatore to waterwell electric conection #12
you cant just wire it directly to the well motor. there has to be a pump control box and a pressure switch controlled to the system. this is what controls the pump and tells it when to turn on and off.
find an electrician before you ruin a well pump.
i planed on running it before the pressure switch, so i would be braking the wire between the electric box and the press switch.but i mite not do it this way i read that some gen wont work with the neutral not connected.
my well dosnt have a capacitor box.
   / generatore to waterwell electric conection #15
Just add a load for the neutral. Like an outlet and plug a night light into it. You can get LED night lights that use very little power. I get one that's always ON, if it could make a difference for the generator to have a neutral.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
71064 (A49346)
71064 (A49346)
2019 POLARIS RANGER 4x4 UTV (A51222)
2019 POLARIS...
2010 John Deere Gator UTV (A49461)
2010 John Deere...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
