generatore to waterwell electric conection
   / generatore to waterwell electric conection #1
sal64
ny orange county
jd 2320 jd 990 jd950
hello all ive been looking to purchase a gen to run my well, 3/4hp220v 2 wire and a gnd. what i want to do is simply cut the wire going down to my wellpump put a male and female plug in so i can unplug it when the power goes out and plug the gen in. my question is the gen is a 4 prong plug so how would i wire my well 3wire to a 4 wire?tuvm
   / generatore to waterwell electric conection #2
Do a search for NEMA plugs. Electrical Outlets by NEMA Ratings I do not know the answer but if you look at your generator owner's manual it should have a spec for the plug which you can cross reference. I did that when I got a big twistlock for my generator to run to a small sub-panel.
   / generatore to waterwell electric conection #3
you may need to wire up to the pump controller and pressure switch if you have one.
   / generatore to waterwell electric conection #4
You would need to have the plug before your pressure switch. Assuming that the plug is before your switch get a 4 wire plug for your generator and use the 2 hot and ground of the plug and leave the nuetral without a wire, your 220Volt pump is not using a nuetral.
   / generatore to waterwell electric conection #5
x3 it has to be before the switch or your pump will just run, build pressure and kerplow. Just leave the neutral out.
i have an on on and off switch between my electrical box and pressure switch i planed on taking that switch out and put a female twistlock 3 prong then put a male 3prong and plug the pump in to the grid and my gen extention cord would have 4prong male to gen 3prong female and leave the nuetral out am i doing this right? witch one would be the nuetral out of the gen? i did some reaserch i read some gen will sence that the nuetral is not connected and wount work.
   / generatore to waterwell electric conection #7
put a small electrical panel out there.. wire the pump to that panel. have the incoming line from the house tot he panel. (have your disconnect there). have a wire stub with plug there..break when needed..
   / generatore to waterwell electric conection #8
Show a pic of your generator plug and we can figure out which one is the Nuetral.
   / generatore to waterwell electric conection #9
One of these?:
didnt buy one yet just trying to figure out the easyest way to set it up. tu for the replie.
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
2022 J&M 1151-22S Classic Grain Storm Grain Cart (A50657)
2022 J&M 1151-22S...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
71065 (A49346)
71065 (A49346)
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
