generatore to waterwell electric conection
   / generatore to waterwell electric conection #11
My pump has the capacitor box mounted in the basement and lines out to the well for the submersible. If yours is similar and you try and wire a plug into the line without your capacitors you're in for a world of hurt.
   / generatore to waterwell electric conection #12
you cant just wire it directly to the well motor. there has to be a pump control box and a pressure switch controlled to the system. this is what controls the pump and tells it when to turn on and off.
find an electrician before you ruin a well pump.
i planed on running it before the pressure switch, so i would be braking the wire between the electric box and the press switch.but i mite not do it this way i read that some gen wont work with the neutral not connected.
my well dosnt have a capacitor box.
   / generatore to waterwell electric conection #15
Just add a load for the neutral. Like an outlet and plug a night light into it. You can get LED night lights that use very little power. I get one that's always ON, if it could make a difference for the generator to have a neutral.
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
2008 Ford F-250 (A52128)
2008 Ford F-250...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
SCAN TO RECEIVE TEXT UPDATES (A51243)
SCAN TO RECEIVE...
2019 CATERPILLAR 316FL EXCAVATOR (A51242)
2019 CATERPILLAR...
