generatore to waterwell electric conection
   / generatore to waterwell electric conection #11
My pump has the capacitor box mounted in the basement and lines out to the well for the submersible. If yours is similar and you try and wire a plug into the line without your capacitors you're in for a world of hurt.
   / generatore to waterwell electric conection #12
you cant just wire it directly to the well motor. there has to be a pump control box and a pressure switch controlled to the system. this is what controls the pump and tells it when to turn on and off.
find an electrician before you ruin a well pump.
i planed on running it before the pressure switch, so i would be braking the wire between the electric box and the press switch.but i mite not do it this way i read that some gen wont work with the neutral not connected.
my well dosnt have a capacitor box.
   / generatore to waterwell electric conection #15
Just add a load for the neutral. Like an outlet and plug a night light into it. You can get LED night lights that use very little power. I get one that's always ON, if it could make a difference for the generator to have a neutral.
Rubbermaid 100 gal Poly Tank (A50515)
Rubbermaid 100 gal...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2015 Ford F150 Crew Cab Pickup (A50323)
2015 Ford F150...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
