Chains 2011 Kubota B3300SU - Spacers Needed?
/ 2011 Kubota B3300SU - Spacers Needed? #1
CanuckPT
Gold Member
West Chesterfield, NH
2011 Kubota B3300SU
I just purchased a 2011 Kubota B3300SU and I intend to put tire chains on it. Does anyone know if the chains will fit without spacers? It appears that the V-Bar 2 Link Ladder style are the way to go if you/I can afford them!!
15-19.5 Tractor Tire Chains
Thoughts? Spacers? 4 Link V-bar? I live in NH so we get plenty of snow & ice in the winter.
Thank you in advance for your feedback!
Damon
/ 2011 Kubota B3300SU - Spacers Needed? #3
Speaking from experience with my B3030, I needed spacers. I went with the Kubota ones that gave me an additional 1.5" on each wheel. I would guess that you need a minimum of 2" of space between the wheels and the fenders/frame to run chains. Here's pics of what my spacers did for me.
Thanks for the feedback. This guy's reviews on eBay are great & he's quite specialized so I feel comfortable that he's engineered his product well but I'll post an update after I get them installed.
/ 2011 Kubota B3300SU - Spacers Needed? #5
I would want 2" of clearance between the inside of the tire and fender. If you can afford them I would look into getting a set of Tellefsdal Supers. They are imported from Europe, the importer (don't know the name) is in NH and the salesman drops them off at the dealers free of charge. They're probably about $200 to $300 more than the 2 link v bar chains but they are a life time set of chains. Mine are 3 years old and have no wear on them, they have almost no rust yet. They are too aggressive for pavement or cement but they don't slip at all on ice. They also will not fall between tire lugs.
http://www.tooriistamarket.ee/files/tarvikud/tarvikud%20ENG/04.01.2011/T14_jaaketjut.pdf
Wow - those chains do look like they mean business! Thanks for the information. I'll check it out.
/ 2011 Kubota B3300SU - Spacers Needed? #7
The first thing I notice with these is that all of the tractor's weight will be carried on the bolts rather than the hub. Personally I'd be sceptical about using them.
These look to be a far superior product for the same money. One piece milled spacer with hub flange to carry the weight. If I were buying, I'd go for these ones
B series spacers on the bay....
Thank you for the feeback. I was able to cancel my order and I'm going to pursue the Bro-Tek spacers. I truly appreciate you taking the time to help!
Bro-Tek spacers arrived today! Have to make the time to get them on now. Chains to follow.
/ 2011 Kubota B3300SU - Spacers Needed? #10
Backhoe stabilizers are nice for taking off wheels and getting them back on (heavy buggers if filled). If you've got scotch, I could come over to supervise.
/ 2011 Kubota B3300SU - Spacers Needed? #13
How do you come to that conclusion ?
Most rims are "hubcentric" meaning the hole in the center of the rim matches the size of the hub. This is to center the rim properly and also helps carry weight. The lug nuts/bolts primary function is to hold the rim in place.
Occasionally rims are lugcentric in that the lugs do everything. It is very important that the taper of the lug nuts/bolts exactly matches that of the rim and are torqued properly. These types of rims are also a pita to install when you have lug bolts as you have to hold the tire & rim lined up with the holes while trying to start the bolts
I know my B3300SU rears are hubcentric as are most tractor rears
The welded-together spacers do not have a hub flange.
/ 2011 Kubota B3300SU - Spacers Needed? #14
.... lugcentric.... types of rims are also a pita to install when you have lug bolts as you have to hold the tire & rim lined up with the holes while trying to start the bolts
With fluid filled , there're terrible to handle , but a starter-pin in one bolt hole is a great help .
/ 2011 Kubota B3300SU - Spacers Needed? #15
.....with hub flange to carry the weight...
Both of the above comments are incorrect from a technical perspective. First, the ONLY time weight is carried by the bolts is when the nuts are loose. In operation it is the friction between the hub flange surface and the surface of the rim or spacer as caused by the pinching effect when the bolts/nuts are tightened that carries the weight. Secondly, in the same manner, no weight is carried by the hub flange shoulder for exactly the same reason. At best the shoulder simply assists in centering the rim during installation. Once the fasteners are torqued it is the pinching effect causing friction between the two mating surfaces that transfers the weight between the two surfaces that are bolted together. The bolts only provide the pinching effect. Weight (torque) is transferred/carried/provided by the friction between the surfaced being pinched together. Sorry to go techincal, but wrong is wrong.
/ 2011 Kubota B3300SU - Spacers Needed? #16
ButteBrute said:
Both of the above comments are incorrect from a technical perspective. First, the ONLY time weight is carried by the bolts is when the nuts are loose. Sorry to go techincal, but wrong is wrong.
And the Gold Medal goes to...
/ 2011 Kubota B3300SU - Spacers Needed? #17
This will get everyone going. With all of the issues concerning clearance between the rear tires and fenders on the B30 series, why doesn't Kubota just increase the width of the rear tire spacing by 3 or 4 inches? Seems to me that it would solve the spacing problem and improve the stability.
/ 2011 Kubota B3300SU - Spacers Needed? #18
I reckon it's more to do with reducing breakages than being unhelpful to us.
The stress on the rear end can lead to very expensive damage.
On a BX , they don't like 'em at all , and I can see how it would be easy to crack the trans case with carrying big loads.
With sensible use ( MMM etc ) they're very useful for improved stability and cut quality.
/ 2011 Kubota B3300SU - Spacers Needed? #19
From reading the various forums, I get the impression that the issue of stress and breakage is somewhat of an urban legend. Everyone worries about it, but has anyone ever seen the animal? It would help if anyone who uses/used spacers and has actually had a negative experience (not just "heard" about someone else) please speak up? My own experience was that tipping over was VERY unpleasant and I feel more secure now that I have the spacers and gladly appreciate the certainty of increased stability (and my life) over the rumor of breakages. St. Peter to new arrival: "Why are you here?" New Arrival: "Well, I heard that spacers would...so I didn't use them."
/ 2011 Kubota B3300SU - Spacers Needed? #20
Good question. Especially since the B series spacers are a Kubota option that you can build into the machine right on the website. I went with the Kubota spacers since the price wasn't all that much more than the aftermarket options, which translates to a reasonable charge for the dealer to install them. Plus, I trust the Kubota spacers more than some aftermarket part.
I actually purchased a particular aftermarket component from one of the manufacturers of the aftermarket spacers, and the component I purchased was a very poor design and I did not like the way it functioned at all. It got removed from the tractor within a month and then was sold. I decided that manufacturer wouldn't ever get another penny out of me, even though they have what appear to be some useful components. I just don't trust their design or build quality.
