3320 Diesel additive question
/ 3320 Diesel additive question #1
BlackRaptor
Gold Member
SEMN
John Deere 3320
Good Morning guys,
I have a quick question. Nights in MN are dipping into the mid/low 20's and it got me thinking the 3320 still has 3/4 of a tank of summer diesel in it and with most summer projects done now i don't see my self burning that much fuel before it starts getting really cold.
Do you guys have a diesel additive you recommend? My 2520 I never added anything to the Diesel but normally by this time of year i had it almost empty and it was ready for a full tank of winter diesel. Going to swing by fleet farm after work and get some if someone can help point me in the right direction.
Thanks
Chad
/ 3320 Diesel additive question #2
I use Power Service all year long.It has an anti-gel additive in it.
/ 3320 Diesel additive question #3
I use Optilube XPD. It has an anti-gel, cetane boost, water demuslifycation and most importantly lubrication. The ULSD we have today has horible scar numbers and can be very hard on fuel pumps and injectors.
Its pretty easy to find the independant testing Arlen Spicer did on these fuel additives. Unfortunatly, while Power Service is readily available at almost anywhere, its performance is at the bottom of the list.
Prices for this stuff are the same all over, but these guys are running a sale on shipping. You save 12 bucks by using this link.
Diesel Fuel Lube - Sale on Gallons of Optilube
/ 3320 Diesel additive question #4
John Deere has a winter fuel additive you can try. I Use Stanadyne fuel additive in my JD tractor, VW turbo diesel and my Excursion 6.0 diesel. I've used this additive for too many years to count and am very satisfied with it.
/ 3320 Diesel additive question #5
JD use to rebrand Stanadyne and I would bet they still do.:thumbsup:
/ 3320 Diesel additive question #6
All of the independent studies have shown the ULSD fuel has adequate lubrication even for older engines. The Federal Government required the refiners to add lubrication as a part of the USDL requirements. There are myriads of forums on diesel engines that cover this area.
Thanks for all the good info guys!
/ 3320 Diesel additive question #8
They no longer do. Golden eagle makes it now. They are the makers of Stabil products.
Please show me an independant test that shows thaey have adequate lube? I will show you one that proves they do not:
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Also, I called my local BP distibutor that says the scar numbers from thier fuel in my area go from 330 to 550. Bosch pumps require a 420 max.
/ 3320 Diesel additive question #9
Just remember that the OP seems to be more interested in an additive that can winterize the summer diesel in his fuel tank.
I've also read the "for and against" threads and links for the lubricity concern. An additive is relatively cheap protection and frankly, I don't put a lot of credence in the government reports.
/ 3320 Diesel additive question #10
Roy,
That is exactly why I am trying to steer him away from power service. While it will lower the cloud point, it does little for the condensation issues that could build. It does little for keeping parts that might have water in the fuel touching them. It does not lubricate items that might need it. Power service is the bottom end of fuel additive that many people use because they are easy to get and cheap. He could pour kerosine in his tank and do what power service does.
At least step up a little and use howes or FPPF. Something other than the worst product made.
/ 3320 Diesel additive question #12
/ 3320 Diesel additive question #14
*All of the independent studies have shown the ULSD fuel has adequate lubrication even for older engines. .
That's what i understand also.
Good Morning guys,
1*I have a quick question. Nights in MN are dipping into the mid/low 20's and it got me thinking the 3320 still has 3/4
2*I never added anything to the Diesel but normally by this time of year i had it almost empty and it was ready for a full tank of winter diesel.
Chad
1*My tractor manual says I can use the summer stuff down to 14 degrees F so at 20 degrees y0u are good to go with what you have.
2*I use PS in the white bottle 12 m0nths of the year.
I use 1 quart in a 55 gallon drum or 1 half a QUART in A 30 GALLON DRUM.
/ 3320 Diesel additive question #15
Is there any reason not to just top it off with diesel number one?
/ 3320 Diesel additive question #16
Any of these will do just fine when the instructions on the label are followed.I personally use Power Service. But if that's your choice, be careful which formula you buy. The white bottle has anti-gel, the silver bottle does not. And the red bottle is for emergency use after the fuel has already gelled.
//greg//
UNUSED RAYTREE RMBD50 - 50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2024 Honda CRF 450RL, VIN:JH2PD1117RK500228 (A61166)
2024 Honda CRF...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL4DL295841 (A61165)
INOP/NON-RUNNING...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2022 John Deere HPX615E 4x4 Gas Utility Cart (A61567)
2022 John Deere...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
