JD 4210 E Hydro Loadmatch issue
/ JD 4210 E Hydro Loadmatch issue #1
jdgreg
Gold Member
Warrenton, Va
My 4210 eHydro hesitates only when the Loadmatch is engaged. I've read here that maybe resetting the CPU (remove positive for >1 min) may fix it. Any other suggestions? TIA
/ JD 4210 E Hydro Loadmatch issue #2
My JD4410 load match does not work well with low RPM, must be in the higher operating RPM range. Have you checked the old threads probably a lot written over the years. Good Luck ---Fuse
/ JD 4210 E Hydro Loadmatch issue #3
I shut mine off on my 4310 and never turned it back on. It is the most useless thing I have ever seen on a tractor I owned.
/ JD 4210 E Hydro Loadmatch issue #4
I like it, but it really only shines when I use it with eThrottle enabled. Then the engine speeds up as you press the peddle down, so it all works very smoothly. I have heard that eThrottle is only available on the 4520 and 4720... which sucks:thumbdown:
Yeah, I've searched here, but havent come up with a lot. And yes, the rpms are not too low.
/ JD 4210 E Hydro Loadmatch issue #6
good luck getting to work right i took mine back so many times and heard so many different lines of bs from the dealer till i finally took it and traded it for the same size but with a power reverser tranny .
I tried pulling the pos battery terminal for 5+ min this weekend, still did it. I'll drop by the dealer this weekend and see what they say.
/ JD 4210 E Hydro Loadmatch issue #8
Try pulling out and cleaning the flywheel sensor. May help.
