What's your LEAST favorite fall task?
/ What's your LEAST favorite fall task? #21
I think my least favorite task is on the mornings I dont have to work, yet still get up well before the crack of dawn, cold and miserable with frost on the ground, only to suit up and trek out into the woods, barley being able to see for lack of light, and then climb up 18 feet in the air, and sit there for 2-3 hours watching the woods come to life, scanning back in forth across the horizon, hearing all the nature sounds, all the while never seeing even a glimpse of those ever-elusive white-tails:mur: and then climb back down, go back to the house disappointed, eat some breakfast and enjoy a coffee, all the while just waiting on evening to roll around to do it all over again:confused2:
That has GOT to the least favorite thing.
Which part? The hunt itself or being unsuccessful getting a deer? Oh now I get it...Nobody is making you go hunting, so it's obviously the lack of getting a deer that you detest
/ What's your LEAST favorite fall task? #23
Which part....It all sucks when you dont have any luck.
But when you finally do....it makes it all worth it:thumbsup:
/ What's your LEAST favorite fall task? #24
The leaves are too thick to attempt to mulch here. They end up killing the grass. Small hand held blowers will only do so much before they cannot move the piles any further. So I would blow the leaves into windrows perpendicular to our woods, then use the snowblade on my PowerTrac to push the windrows into the woods. That works pretty darn good. Then I got a tow behind brush type lawn sweeper. That works really well. It fills up fast, though. But I can empty it from my seat by pulling a rope, so I never have to get off the tractor. It is much faster than the hand held leaf blower was. If I had some extra cash to spend I would get a power leaf vacuum that mulches so I would not have to empty as often. But all in all, leaf removal only takes three or four afternoons and it is a good excuse to get outdoors.
/ What's your LEAST favorite fall task? #25
Why pick them up....mulch them with a mower. If only I could do that with walnuts without killing the grass by cutting it too short.
How I wish that were an option! I have soooo many oak trees with soooo many leaves trying to mulch the leaves creates a real mess. I tried mulching then mowing with a bagger and that took longer than raking/blowing.
Plus, and this is even a bigger headache --- getting leaves out of flower beds, bushes and planters. Bottomline --- I need to blow to a pile, pick-up, dump in the woods, repeat, repeat, repeat, repeat - well, you get the idea.
/ What's your LEAST favorite fall task? #26
We don't rake leaves here in the country the wind takes care of them sooner or later. However I do have to get on a ladder once they are all down to clean the gutters. You would think that as much as I hate that job I would run out and buy gutter guard. hmmmm :laughing:
I have tried several types of gutter guards problem is if your gutters are on a steeply sloped roof much of the rainwater simply runs over them and splashes on the ground.
/ What's your LEAST favorite fall task? #28
Fall is my second favorite time of year after spring--love the spring and fall fishing!! The hardest physical job I have to do is installing the front-mount snowblower and those heavy darn chains on the Kubota, but once I get those done I'm ready for winter (my least favorite). Regards, Mike
/ What's your LEAST favorite fall task? #29
That happens in heavy downpours anyway.
/ What's your LEAST favorite fall task? #30
I hate trying to stuff everything in the barn! Tables, chairs, trilers and everything that sits out all summer that "needs" to be inside in the winter.
Hate is a strong word but I am with you on putting away mommas stuff lol ;)
/ What's your LEAST favorite fall task? #31
You know I never minded when I was younger but cleaning the chimneys has become a bit of a chore. It takes 3 ladders to get up there. He!! I spent younger years as a technical rock climber. I even built the chimneys. Now I get up there and consider the ramifications of a fall. There are days I wish I could grow another pair to take up the slack.
/ What's your LEAST favorite fall task? #32
The chore i hate the most in the fall is going to work. It gets even worse in the spring.
David from Jax
/ What's your LEAST favorite fall task? #33
Gutter cleaning, :mad: getting too old & fat for the second story ladder work in back! ~~ grnspot
/ What's your LEAST favorite fall task? #34
I hate gutter cleaning too grnspot. Getting on a ladder now gives me a nosebleed. Height seems to bother me more as I get older, or maybe it's anticipation of a fall I don't know.
At one time I used to service a lot of rooftop HVAC equipment. Now there are no ladders on my truck as I leave that work to the younger technicians.
I too detest gutter cleaning while on a ladder so I made this gadget. I found a powerful Craftsman electric blower at a garage sale for about $10, it had no tubes but I didn't need those. The 2" PVC pipe extends about 7' from the powerhead and with a 2" connector cemented to the end, it is a snug fit into the blower opening and a bolt secures it. The entire assembly is reasonably easy to handle and strong enough to hang on a gutter, I do that to direct air down at the gutter drop openings and feel for air coming out of the downspout end. Many clogs with dry leaves can easily be blown out from above, and even with wet leaves in the gutter the airflow is usually strong enough to blast them out. The square PVC pipe is a deck spindle and provides a secure second handhold. Not sure if you could extend the 2" PVC pipe to make it long enough for second story gutters as that would make it much more awkward. And yes, that is a car convex mirror at the blowing end...gives me a view from the ground as to where leaves are. WARNING: If you use a device like this one, wear old clothing and protective eyewear as the stuff dislodged overhead usually comes right down atop you...:laughing:
/ What's your LEAST favorite fall task? #36
Great idea :thumbsup:
I wonder if adding one more ell would direct the debris away from you instead of on-top of you. :D
/ What's your LEAST favorite fall task? #37
Nice job. My dad bought an attachment like that for his father after my mom caught him up on the roof cleaning gutters.... he was 90! :shocked:
I like the cord wrap feature, too. :thumbsup:
I do have another 90 degree ell fitted with a rubber flex connector that can be rotated to any angle once attached to the end but the more bends that restrict airflow the less the blowing power.
/ What's your LEAST favorite fall task? #39
Weeding the flower beds for the last time and freezing my *** off doing so.
/ What's your LEAST favorite fall task? #40
That's what I use on my front gutter & sheds, but it's too hard to handle with enough pipe for the back of the house (two-story)! ~~ grnspot
