new tractor idea possibly....
/ new tractor idea possibly.... #181
Reading this long discussion on how to in the mind get farm equipment to work in real situations.
Was reminded of a inventor named Laturno probally mis-spelled Built elec. motors in the wheels and small generator on frame of what ever the machine was to do.
A loader commonlly called the bouncing betty had 5 buttons on dash for movement forward, left, right ,rearward. the fuel tanks were in the frame .
All before the modern electronic controllers could work in any weather conditions and didn't need a table smooth surface to get around.
Study history of international tractors company. every time the engineers built a piece of farm equipment that the farmers liked the bean counters turned it down as to costly.
With all the electronics . hydrolic motors hoses and parafanalla in your design should something like a operator that has no idea what he is doing connect the wrong hose to piece of equipment. insted of folding turning or doing as designed it curls all into a mass of junk. Who is to repair all of this when a part is bent due to trying to run into a power pole in field .or miss alignment in corn crop and it takes out the corn row instead of doing what was thought it is doing.
Again reading all most all of this forum just what are you trying to build.
Farmers buy equipment to get the job done if it doesn't it is sidelined for something that does.
Example is dairy men buying these 1/4 millon dollor automatic milkers and the electronics get hit by lightening.
Do you ask the cow to be patient while waiting for the repairman to arrive. Or harvesting the rice crop and the weather has turned the field into a 4 inch deep pond . have to use a dozer to drag the combine across the field. fill the trailers to take to the storage area and the tractor (driver trying to get his head phones adjusted) runs the tractor into drainage ditch. turning it over.
Can all the planning over come just the changing weather conditions.
Sometimes I cannot sleep also.
ken
I think it's spelled LeTourneau. He was an equipment genius.
R. G. LeTourneau - Wikipedia, the free encyclopedia
ken
Good Solid post Ken.
though at moment. i honestly can not give you any sort of "direct" answer, due to there is non at the moment. and reason why, last couple days, been trying to nail down, a software package. for example, autodesk inventor to programming language. to take things to the next step. i can see it all in my own mind working, both large and overview doing of things, and then individual components. but it is the piecing things together to work, and then going back every little thing a few to many times. to double check things.
to note it one more time, well said ken, but every time i begin to think about different portions of your post, my mind begins running, of this and that and some way to resolve issues. but need to get my rear back to autodesk tutorials / videos. so i can show it vs just blabing about it. gotta see it through to the end.
and thanks for info, to do more research into the history!
/ new tractor idea possibly.... #184
"Artisan" just caught his "dump trailer angle dangle" thread
http://www.tractorbynet.com/forums/build-yourself/259020-dump-trailer-angle-dangle.html
the picture on post 16. and some comments of multi tool for the top. is what caught my eye. for the SSTT (sideways snake train tractor) for transport wheels. little bit shortening here, little bit of moving of cylinders / hinges. toss a coulple hyd motors into the mix. and voom voom voom.
/ new tractor idea possibly.... #187
Re-reading my posting I wasn't being critical of the design . just could not figure out how it was to be used.
Remember the new designed tractors that had the 12 wheels and in pulling the farm equipment came to a hard soil of clay and strips the lugs off the tires. Now this will put a wrinkle in the tail.
Or combine that is wider than the planter so row keeps shifting.
Farmer would need to borrow money from a friendly bank wanting a total lein on the property if goes into a default from weather. or Goverment planning. they get it all.
All the different computer systems needed and where will the spare parts be found or some one with knowledge of repairing. Even a today's bailer will stop working when a power cable shifts or comes loose. Only saying error on the control panel.
I'm not against the idea of building newer and better equipment. just keep it simple and easy to locate the problems.
ken
autodesk tutorial site, is acting funky at moment, pictures not loading / page not loading. and need to finish up tutorials before charging into the next video, not having a clue what he is talking about.
critical? huh? *shrugs* never phased me. *laughs* did not even think about it, till ya said something. internet at its finest, of being impersonal, and not being able to read body language of person ya talking with.
ya, i understand about keeping things simple. biggest part of this thread, is just getting a understanding of it all, myself, let alone anyone else.
electronics and lighting strikes :/ ya that is a big one. to many times machines get left out in a field and they are the tallest things around, and then of all things get placed right up near a field fence :/ *big frown* old farmer that worked this farm for some time, i know he has been nailed by lighting a few times. just driving down the field up near the fence line. and lighting hitting the fence clear down the line and out of site. and sending a charge down the fence line and attacking the tractor per say.
i am not overly to worried about lighting on each 60 feet section. but rather when 2 more 60 feet sections are combined into a single working machine. and lighting hitting one end. and sending electricity clear through everything. to the very far end at 120 feet away. that worries me. i guess i should say each section as well 60 feet is a long distance, for machine to get into different hot spots. that could cause a couple lighting strikes... (guessing)
i am still having a hard time with running electrical motors directly in the rims of the tires or the like. just do not like that many AMP's and chance of a potential vary dangerous situation happening. more so, someone bozo thinking they can fix something, without shutting things down and properly grounding things out before working on something...
good portion of above, is more likely ya see me reference to hydraulic hydrostatic transmission, or hydraulic motors.
complexity, and keeping it simple, ya it been driving me crazy, with the implement linkages, to linkages to deal with wheels to tracks. along with valving and sensors. KISS (keep it simply stupid). there going to be a lot of battle of this and that. in simplifying things to complexity. i am sure there going to be a few "wellll...." judgement calls, of adding a couple bucks more to total cost, for some sort of harness connecter for wiring harness, or a quick disconnect for hydraulic oil, or perhaps another bracket, that you can actually get a socket wrench / breaker bar on. and then just simply being able to maneuver around the machine to work on it, engine, to valves, to grease zerks, to fueling it up, and checking the fluid levels. to other. along with points were you can actually place a jack under something, to lift things up, to work on something. you say simple. but most machines get complex fairly quick. in order to make the machines simple... i am still trying to figure out, how that works out ;):D
/ new tractor idea possibly.... #189
Using the electric motor drives is probably the simplest solution. I believe power to wheels and efficiently will be far superior to hydro drives.
Hybrid vehicles (Prius, etc) use electric drives. Some voltage reaching 600 volts.
Also modern railroad locomotives use diesel powered generators to power their electric motor drive wheels. Proven technology.
By using electric drives, the integration of controls is much easier on the entire machine.
how are electrical motors going to hold up, when they get completely submerged under water and/r caked with dirt, that is a few inches thick? how is the "heat" generated from the electrical motor, going to hold up in those type of situations?
you really can not put a fan on the motor, and/or rely on "wind" of just going 30 to 70 MPH through the field to cool the motors.
any sort of internal fan. that requires any sort of *its on tip of my tongue*.. baffles and air ducts. to keep rain water and like out, and your risking flooding the motor, when ya go through any sort of mud puddle found in fields, and other nasty areas.
if a heat sink, was placed on a electrical motor, to help reduce heat. you are still at risk of mud build up. and reducing how much can be removed.
hyd motors, the hyd oil itself, can be cooled at a different location than were the hyd motor is. and in that help keep the "temperature" at the hyd motor down.
ya a blanket statement comment, of not wanting to submerge anything into any sort of water, or get mud build up on things. but if that is the case, ya sitting in the shed not doing squat.
a train, the wheels do not go through mud or snow, well i am sure they do, but once snow gets to a certain point, i would imagine snow plows get added to the front of the trains. to keep all the wheels on the track.
electrical cars / trucks. i really can not bight into, at least everything that i have seen so far, is made for highways, and streets were there is no mud / water.
there are some electrical tractors folks have done, and ones i have seen have been tractors that have been modified, were the engine was switched over to the generator, and removing drive shaft between engine and transmission. and placing a electrical motor back on final drive area of the tractor. keeping the motors up and out the way of water and mud.
at moment, i just do not see how a electrical motor located at in the wheels / rim. or just offset just outside of the wheel. could hold up.
and due to how the SSTT (sideways snake train tractor) would move, with both transport wheels, and then with large AG tires and/or tracks. i do not see how it would be possible to use drive shafts, to keep the electrical motors up higher off the ground. so they do not get submerged under water or caked with mud, in the every day life, of a field tractor. and if it was possible, (most likely is) adding the extra drive shafts, (like transfer cases for 4WD / MFWD) would add more complexity and points of failure.
then again, i very well could be wrong. i know, i do not know enough about electrical motors, let alone experience. to fairly judge them. would loved to be proven, wrong!
and i know "i just walked right into it" so lets hear it! :)
finally got into "ilogic" of setting parameters and adding rules.
digging a bit deeper, and can work with "visual basic" programming code. *smiles*
and the basic built into autodesk inventor "ilogic" / creating a custom rule has if/then/else and loop functions. though very generic versions of them.
*ear to ear grin* i can work with that!
tagging a link for tomorrow, for autodesk inventor API (programming)
Autodesk - Developer Center - Course Schedule
/ new tractor idea possibly.... #192
You bring up a good point regarding motor cooling. In order to keep the motors small, water cooling maybe the best solution. I agree air cooling is no good.
A good application of sealed water cooled motor to study is underground mining equipment. These motors must be sealed due to potential explosive gas encountered in the mines. Water is pump through the miner into water jackets that surround motors and then sprayed out onto the coal or ore to reduce dust. This is a very effective system.
Your system could use a similar set-up as the mining machine... except you would recirculate the water (closed loop) to a radiator. The system would be 100% sealed.... so no issues with mud getting in motors, etc. The motor can be directly attached to the wheels using a planetary gear train. Very rugged and very simple! Modern large dump trucks, wheel loaders, etc use this system. If you can use a brushless motor... all the better!
I believe the hydro system will have too much power loss on a machine as large as you are talking about. And will be especially limited at higher speeds. Even a small hydro compact tractor (5000 lbs) must use a 3 speed gearbox to compensate the hydro motor for different speed and load conditions. And they only have a top speed of 14 mph! Your tractor must have major pulling power and I'm just not "feeling" hydro drive for it.
Electric or Hybrid vehicles are exposed to extreme conditions during normal operation. Water is always an issue. Hybrid vehicles use a cooling system to keep the motor controllers and motors cool. The systems are fully sealed and have no issues when operating in mud and water.
/ new tractor idea possibly.... #193
Great example of electric motor hubs operating in extreme conditions.... Of course in this case the machine isn't cheap! :laughing:
Looks kinda like your SSTT ey? ;)
Debbie, from John Deere, just called me, approx. 20 minutes ago. Noted she would pass this thread to the R&D department, noted she could not promise anything, and just pass along the info. but hey, all wanted was some contact info. to get things moving.
boy was phone call, a disaster on my part. all focused and dug into something else. and was caught completely off guard with phone call. *shrugs* *looks happy*
View attachment 283096View attachment 283097
You do not leave much to chance do you! no wiggle room to work with :laughing:
ya, i knew i walked into it pretty good at end of the one post. with antifreeze/water mix. and setting up a radiator. and i also knew my mind, was getting tweaked out for what ever reason. of getting over the idea of using an electrical switch. to adjust how much amps/volts went to a electrical motor. vs a hyd valve with an electrical actuator on it.
but more to the point is the 2 cooling hoses. (cold in, hot out) lines. and then wrapping my mind around, needing to run some heavier wires, to and from motors.
the wires connections themselves, are going to be a problem. i am not familiar with any sort of larger size connectors for electrical wire, beyond "water tight" connections for conduit to run wire in. i am not sure if a simple rubber boot that could be physically moved about. to deal with wires on repairing things, would hold up long term. the nearest thing i can think of, using some sort of silicon or polyurethane or some form of calking tube. to apply something to water tight connections of electrical wires.
well a suppose a generic water proof/dust proof wiring harness connection could work. that has a 0-ring or 2 to seal things. but how do you deal with, when a wire gets snagged, and pulled. and redoing a wire, into a wire harness end connector...
i suppose awe i do not know the technical name. a plastic cinch? pushes over wire end and over the insulation, and is kinda in shape of a "cone" with slots around the perimeter of it. kinda like a compression fitting of a gas line, and tightens things down around the wire.
as far as gear reduction, and 1 to say 4 gear box. ya i know, MPH, both in field and in transport mode is still up in the air. planetary gears or other.
i really do not want to add a centralized transmission / gear box on the SSTT main frame. and in that rather have, each set of transport wheels, or large AG / R1 Tires, or tracks, have there own motor/s, /transmissions, and switches / sensors. on each doing. or near to that. some of it has to do with overall length and distances between each wheel set / tracks placement on the main frame. other. i could see a few folks. tossing the transport wheels, and adding another set of tracks in that spot. and then using some sort of modified "trailer" to transport the SSTT. or upgrading, from say AG/R1 tires, to tracks. another part is being able to "adjust" wheels and tracks. to some degree. for spacing for crops, to other. and perhaps "turning into a robot transformer in idea" between planting to harvesting, and turn into a better unit geared for harvesting or planting. pending on the upcoming season.
i guess i need to research / look at some electrical switches internals, to get grasp, of the mechanics of them, in how they operate. along with terms, used for the different switches. i would imagine there is a better designed setup, for the physical contacts. inside the switches, that would be wanted, over other designs. both for long term use and hold up to vibrations and wide range of temperatures, but also possibly being able to replace the contacts or repair / replace things that would be prone to wear over the long term.
some thing for electrical motors.
think i am going to hold off, digging real deep into electrical motors, till start of next week. hopefully give me enough time to finish out the tutorials on autodesk inventor, and see if i need to dig into another software for running multi simulations. and spitting out information form the simulations.
i know i will need to deal with it soon or later, is patents / copyright, and the like. along with dealing with anyone that has replied to this thread. once those $$$ signs gets involved. man, i hate approaching the subject. just bringing it up, is going to offend someone, and someone else may get really into it, to point of lawsuit or some such. and honestly, not prepared to deal with any of the sort.
when initially creating the thread on TBN for me, was to get some help / feedback, nothing more to it than that, to see what might come of it. as things have further progressed, my thinking has changed, to a point that it is very possible, and more of gaining contacts, and gaining info on who has replied to the thread, to approach later on as things progress. also to help get folks use to the idea, of a different "type" of tractor, and how it might operate in the fields.
as much as i thought i was digging a deeper hole for myself a few minutes ago. i think i got a better "business model" to follow. that might work, short and long term. and that is, what many "open source" software, go by, the General public license agreements or the like.
were, it is free to use, for non-profit organizations or like, and freely to distribute the information as long as credit and blah blah blah is noted. but not able to use for commercial use / doings were money would be made, without direct signed authorization by the developer/designer. or how ever it is worded.
Man a lawyer would have a field day with above paragraph.
see if i can restate things... a better way.
*eats lunch* and my train of thought has left me.
i am looking for something,
---that allows, others to help / give feed back / work on the SSTT and/or STB. and still gives credit to those folks and/or companies.
---no one / entity / company and plural forms, can make a profit of the doings, without direct signed consent.
thinking it still keeps me in control of things, to a point, were i can still sign a contract/s or like. and i would be required to give credit. to those that have done work on the project/s. and in doing so, does not imply any sort of "money" being exchanged or implied.
though i am not sure how above might apply to copyrights, and patents. i would imagine, if someone came up with this nitfy little doing, that works, and it was patented, the given person / company. would be listed on the patent. but the entity in control of the patent or like, that may gain a profit, of the patent. would be, who ever, i signed the contract/s with. that basically kicks out the little guy, that did things, in gaining any sort $ of doing from the idea.
with open source software code, you are normally able to make changes or what not, as long as credit is given, and blah blah blah, is kept with the doings.
i think i need to get my mind over the idea, of work, vs idea, vs credit. there is a difference. and because many things can move so quickly with source code itself. and knowledge and ability is there. that the "idea" itself is for most part is mute in point. and it is more about work done, and shown, put into a project, and credit noted. vs the idea itself. when it comes to open source software.
but as good as that last paragraph sounded to me. there is a snag, and that is, an attempt. keep some what control to a given point. to promote my own self. (other words i need to making a living as well).
and this about the time, i wish i lived in the age of "star trek" were a value of X for given work done, is no longer there for everyone. a well *wishful thinking* time to get back to reality.
getting back to reality, and that is approaching companies.
do i ask for help direct help with development? or do i seek a job? or both? or other? am i asking for "funding", what am i asking of them? and were do i want to position myself.
and i do not have a clue... lunch is over, time to get back at things...
/ new tractor idea possibly.... #198
Ryan Look at the elec. 100 ton trucks hauling ore out of copper pits in Ariz. and Utah other areas. they have upgraded to 300 ton vehicles one whoppinmg big trucks.
Unless changed recently they were Elec in the wheels. belly deep in mud bottom of pit and able to pull out of pit taking close to 1 hour of dead weight pull uphill.
dump the load and return into the pit. huge grids coils to cool using the motors for breaking action.
ken
/ new tractor idea possibly.... #199
ken
:thumbsup:
not much of an update.
autodesk inventor. finally getting through "restraints" and figured out YA!
but... collision detection..... not looking so good. for what i was hoping for. as far as programming a simulation. when i get over into "autodesk simulation multi physics" program. maybe something there. but not enough time to go through it.
also going to need to pickup "microsoft excel or office" 2003 to 2010 license, in order to do much with inventor. well i should say, keeping track of all the parameters (length, width, height, diameter, etc...) openoffice does not work, due to how autodesk inventor and microsoft excel "talk to each other" to update things parameters.
i have downloaded a few other autodesk app's (auto cad mechanical, simulation CFD, autocad electrical), and i am going to need to go through them, to look at simulation, but at moment it is not looking to promising. as what i was hoping to find, for simple collision detection. that could be used as a constant / variable set parameter. though, that maybe, the newbie of me speaking.
collision detection... *grinds teeth* ggggrrrr....
using autodesk student edition. trying to learn.
4 cylinders. (errr ok modified generic flat cylinders)
hhhmmsss i thought the image was suppose to have a "autodesk student edition" markings on the image....
the 3 different "angle" constraints. are giving me problems. in wanting to set 1 to 2 of them. and only allow freedom of moment so much in one direction, and then setting another constraint to be able to move so far in the other direction.
was actually hoping for "collision detection". to work better and spit out how many degrees and other parameters, when something happened. but... i am not finding/seeing the info.
going through "constraints" videos on youtube, and came across this video.
a bar that fits into the end, of a cylinder, and is used to determined position of the rod of the cylinder. *shrugs* something to remember. vs the gear / toothed bar, from an earlier post.
https://www.youtube.com/watch?v=QkEvE7SqsMI&feature=related
i dug some what into "electrical motors" on google. but i need to dig further into how motors are actually made, (windings, center core, etc...) been way to many years, since basic A/C and D/C college class. and in that get back to the fundamentals of electrical motors.
my dad called me last night, and i asked, about, if he had a old multi phase motor, that was burned up at the plant he works at. that i might be able to get and tear apart. hopefully one that is variable speed design. granted no wheel hub motor design. but something possibly.
i am still hesitant about use of electrical motors.
my last thoughts have been on.....
hyd motors. i can keep feeding them more and more GPM of hyd fluid. and as long as they do not over heat, i can keep on pressing more GPM of hyd fluid through them. if hyd oil pressure gets to high, a pressure relief valve opens up and lets excess pressure to by pass the motor.
other words to above.... i could pickup the transport wheels, put down the tracks for field mode, and pump every last bit of GPM of hyd oil coming from the engine and hyd pump. to just 2 track motors. and gain higher MPH.
if i try and do same thing with electrical motors, by raising AMPs and Volts. at some point sparks are going to happen. and things are going to get burned up (or rather i should say, before sparks begin to fly and cause things to get welded to each other). or less i keep increasing the size of the motor and in that windings can allow for the higher AMPs and volts....(hopefully correct term aka windings) i would like to think a fuse / breaker / resister, would be set in place to keep an electrical motor from destroying itself. but with a fuse / breaker... once a fuse blows / breaker trips, ya gotta get out there and manually replace fuse, or reset breaker. unlike a hyd pressure relief valve that auto resets itself, once pressure is reduced to a given point.
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
832749 (A61166)
832749 (A61166)
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
