shortthrow50
Banned
- Joined
- Jan 12, 2012
- Messages
- 930
- Tractor
- 2012 John Deere 3520 Deluxe Cab
What are people doing if they have a hydraulic top link? It's my understanding, that this easy change system dramatically limits the top link extension
On our 265 MF (1976) we were fine on top link and bush hog PTO. A 7' rotary mower comes with an extra long PTO. The added 4" of space between the tires and bushhog is awesome especially when hooking up PTO connector.
Thanks, texasjohn, I will!Friends, if you have a question about if it will fit....just give Pat a call....hundreds of thread replies and everybody says they fit and Pat gives good service....he's sold a ton of these things, people are happy with them and happy with the service...just give him a call to find out if they fit. He knows for sure.
Does your 265 MF happen to have the pivoting ball-end setup? I have a MF 275 with the welded on, pivoting ball-end and am wondering if the added width of the arms would be too wide to accept the Pat's system. I've seen both height of arms and length of straight run at end of arms, but never thickness of arms at the ball end mentioned. Should go out to the barn now to measure but... Does anyone offhand know the thickness/width of opening of the Pat's system?? Thanks
I thought about adding a hydraulic top link to use along with Pat's ECS but my son talked me out of it. In our case it would just be harder to hook up the top link due to extra weight and hoses. He said it would just be money wasted since we do not need to adjust the top link except when we first hitch to another piece of equipment.
We use the Cat 2 ECS system on the 265 MF (60 HP?) with a 1000 pound 8' Bushhog Brand box blade and a super heavy duty 7' bush hog type mower and so far even with some abuse the Pat's system has held up well and reduces accident risks greatly when changing implements.
Our Ford sickle mower came with its own top link that only had to be adjusted once for the style of tractor that it was used with. It had arm clamps that we put in place by hand tighting then we used the lift to put in the top link pin THEN we torqued the arm clamps.
I think a hydraulic top link has its place. It seems like on a 3PH set of forks or materials bucket the extra lifting range would be nice that a hydraulic top link offers if one already had a spare remote.
I have the same question about the set screws. I understand they are used to align the PEC plumb to the lift arms. However, when using implements with pins of varying widths, the PEC will sit square to some pins and be slightly off with others.
In other words, if my arms are set 26'' apart and I plumb the PEC and tighten the set screws, the PEC will be square to the pin on any implement with pins 26'' apart. When I move to another implement with pins 21" apart, the PEC is no longer square to the pins and the hooks will sit at a slight angle to the pins.
What is the advantage of using the set screws and tightening the PEC to the arms? Why not use the main pin through the ball in the lift arm and the shim and leave the set screws loose (or off) and allow the PEC to move left or right on the arm. By doing this, the PEC can self align to the pins on the implement being used.... this is no different then the ball in the arm rotating. What am i missing about the use of the set screws? Thanks
I have a Kubota B2910 and a Woods back blade. I ordered the Pat's Easy Change from Tractor By Net. Will it be difficult to install and will it work with my rear blade>
