LouieJunior
The jungle is constantly encroaching on my roads and trails. Is there a safe and easy approach to trimming this foliage on the roadsides? I am amazed at the rate this stuff grows!
If i'm not mistaken, Befco's sickle mowers as well as their tillers and other hay equipment are imported from Italy. I do not know of any sickle mowers made in America besides the New Holland.I just ordered a BEFCO sickle bar mower that is supposed to be able to cut at a 90 degree upward grade. Everything Attachments and Carver Equipment also sell Italian-sourced sickle-bar mowers that are said to cut at a 90 degree upward grade. I decided on the BEFCO because it is made in the USA, in NC where I live, and BEFCO has a long company history.
I have a First Choice sicklebar mower that will run vertical and I have tried it and it does work. It will cut brush and small limbs very well. But I have got to tell you that it is nerve racking work having that sickle running right behind your right ear and above your head with stuff falling down in your face. A sicklebar is a little floppy when not supported on the far end by the ground. I would not recommend using one that way. But maybe I'm just a chicken.
I have miles of trails and roads to maintain. For me the best method is to use a chainsaw, polesaw, and bushhog. Once I get the brush and trees cut back far enough at ground level upkeep is alot easier. I use the sickle bar at ground level to reach under the branches and keep stuff on the sides from growing.
