JD 3520 Second Service
/ JD 3520 Second Service #1
LHS Inc
Gold Member
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
I don't put enough hours on my 3520 so I get the oil changed yearly. I'm getting close to my second yearly service at 115 hrs. I continued with break-in oil with the first oil change. Should I use it again since I'm still under the 200 hr interval?
What other services would anyone recommend with the amount of hours I have on it? They aren't hard hours.
Its been a wonderful tractor. Done everything I've asked of it.
Thanks
/ JD 3520 Second Service #2
I am in the same boat. 400 hours and have a 2005. I did not use break in oil on my 2nd service.
/ JD 3520 Second Service #3
I change the oil every year even if I don't go over 200 hours. Oil breaks down over time and will not offer the same protections as when new. Cheap insurance.
/ JD 3520 Second Service #4
Thanks
I would recommend you do things like check bolt torque on everything you can especially the wheels.
I didn't use my 4520 that much this year either as most lawn projects were small and far between. Hope next year is better.
/ JD 3520 Second Service #5
Yep, check your torque thrust bolt on you front axle too, they all seem to come loose.
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
PORTA POTTY (A68842)
PALLET OF HEAVYEQUIPMENT PRESSURE WASHER PARTS (A68842)
PALLET OF...
2019 HAULOTTE 5533A PORTABLE ELECTRIC BOOM LIFT (A65056)
2019 HAULOTTE...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
CAT D6T SU Blade (A68134)
CAT D6T SU Blade...
