JD 3520 Second Service
/ JD 3520 Second Service #1
LHS Inc
Gold Member
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
I don't put enough hours on my 3520 so I get the oil changed yearly. I'm getting close to my second yearly service at 115 hrs. I continued with break-in oil with the first oil change. Should I use it again since I'm still under the 200 hr interval?
What other services would anyone recommend with the amount of hours I have on it? They aren't hard hours.
Its been a wonderful tractor. Done everything I've asked of it.
Thanks
/ JD 3520 Second Service #2
I am in the same boat. 400 hours and have a 2005. I did not use break in oil on my 2nd service.
/ JD 3520 Second Service #3
I change the oil every year even if I don't go over 200 hours. Oil breaks down over time and will not offer the same protections as when new. Cheap insurance.
/ JD 3520 Second Service #4
Thanks
I would recommend you do things like check bolt torque on everything you can especially the wheels.
I didn't use my 4520 that much this year either as most lawn projects were small and far between. Hope next year is better.
/ JD 3520 Second Service #5
Yep, check your torque thrust bolt on you front axle too, they all seem to come loose.
2007 BIG TEX 20 T/A UTILITY TRAILER (A67714)
2007 BIG TEX 20...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
PORTA POTTY (A68842)
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
2018 Ford F-250 Ext. Cab Pickup Truck (A66736)
2018 Ford F-250...
