Arctic Poly Skin
/ Arctic Poly Skin #1
4shorts
Elite Member
Bay Roberts, Newfoundland
Kubota 5740,BX25D
Our TBN member (RFB) asked me to show him the poly skin I have on my blade so rather than post it on someone else s thread I'll post it here.
This is a poly plow I had on my old pick up that I later modified to fit my Kubota 4240 and now my Kubota 5740. The poly skin can be purchased at a Arctic Plow dealer and you'll have to cut the steel skin off your blade and adapt the blade frame to accept the poly skin. The skin's thickness is 3/8th thick and snow will never stick to it so that's why I like it so much. We get a good bit of wet snow over here and this blade takes care of that.
I also added a kick back shock to the blade as well because there were times the blade would recoil and flick snow and ice back towards the windshield. The shock took care of that issue. The blade comes back nice and easy now making it much safer.
I also added rear skids to the "A" frame to prevent the rear of the blade from digging into the pavement. Here's is a link to the original thread.
http://www.tractorbynet.com/forums/customization/131136-snow-plow-adapted-fel.html
Lower rear skids
Front skin
Front shock
/ Arctic Poly Skin #2
Paul,
Is there a skin made for, or a way to put a poly skin onto an existing steel skin (I run a Curtis 7.5 in the attached pic.)
Thank you sir!
/ Arctic Poly Skin
Paul,
Thank you sir!
I'd say it's an easy install. I can measure mine tomorrow and see if it would fit yours. You'd just need to drill a few 1/2 holes and use carriage bolts to mount it to your steel skin.
Your kindly welcome ;)
/ Arctic Poly Skin
Somebody sure has been busy getting ready for winter.
Na. The tractor is ready but I am working on one small mod right now that's pretty neat if I must say so myself. The shop is still going full tilt and we got the big wedding day in a few weeks for our youngest Navy son so I have to concentrate on the wedding car and a hundred other wedding related things ;)
/ Arctic Poly Skin #6
Paul,
Thank you sir!
I have seen what you are talking about before but cant seem to find a link at the moment. I think I have seen them in the discount-snowplow-parts catalogs I get. It is basically a thinner poly skin that gets glued over the existing steel skin. I'll keep looking and see if I can fidn a link.
/ Arctic Poly Skin #7
Found what I was looking for. Non-Stick Snow Plow Liners
There are others that make them too. You can do a search for "poly snowplow liner" and come up with a ton of stuff
/ Arctic Poly Skin
I haven't seen the glue on ones but you could buy a sheet of Teflon and do the same. Here is the link to Arctic Plows. You could email them and ask how much for a replacement skin.
Arctic Snowplows - Accessories
/ Arctic Poly Skin #10
Yea, maybe I was mis-remembering?? The link is the ones I was talking about. I never paid much attention (and never used them), so I just assumed they glued on. But now I see that they get bolted on at the top, pinched under the cutting edge at the bottom, and silicone to seal and kinda act as a glue for the middle.
/ Arctic Poly Skin #11
Gentlemen,
Thank you kindly for your efforts in helping me. I have a couple of questions:
1. I wonder how you make the sheet hold the curve of the plow face. I see the bolts and then under the cutting edge and the edge seal. It must be that once "pinched" under the cutting edge, then downward (and towards the concave) pressure and then bolted, holds the curve. Am I thinking correctly.
2. Paul (and anyone else please feel free), what is the thickness of your poly, and where would one look to buy an equivalently size sheet of Teflon? (Are you recommending Teflon over poly?)
/ Arctic Poly Skin #12
High density polyethylene (HDPE) would be the material of choice. Teflon is too soft and not tough enough to hold up well here (and very expensive). HDPE is slick and very tough. You could even go up to UHMW HDPE which is ultra high molecular weight. Even tougher but can get pricey.
You could probably do any thickness you like. The thicker it is, the longer it will last but the harder it will be to install (stiff).
You should be able to find a plastics distributor in your area where you could buy raw sheet stock, probably cut to size per order too. Some web searching should get you what you need.
/ Arctic Poly Skin
Gentlemen,
Gee I just realize my blade is out rapped up for the summer BUT I did get to measure the thickness of the poly and it's 3/8th thick and it's 24" high. I believe they are pre-formed. When I removed it, it kept it's shape. It's not tucked under the cutting edge but sits just above it and is attached by carriage bolts on the bottom and the top. This skin has plowed snow commercially since 1994. The poly is natural orange and never painted. If you contacted an Arctic Plow dealer they could give you a price on the poly skin.
Good info Dave. Guys around here use Teflon and it lasts on their plows. Teflon here is easy and cheap to get because of the local fishery. It's used everywhere around these parts.
/ Arctic Poly Skin
Here's a better photo of the blade.
/ Arctic Poly Skin #15
4shorts, what you have is an actual poly plow. And the poly is 3/8" thick for strength. And no, teflon wont work in that application.
What I posted, and I think RFB was asking about, (and probabally what the guys you mention use the teflon for) is a "liner". They are pretty thin. They are designed to go OVER the steel. Mearly just a "coating" over the steel so the snow dont stick. But dont have to provide any support or have to be strong like your 3/8" blade. Because yours dont have a layer of steel behind it.
And the liners that I am talking about are flexible. With them pinched under the cutting edge, formed to the plow and then bolted at the top, there is no where for them to move. They will hold their shape just fine.
/ Arctic Poly Skin
I realize my skin is a poly skin. I paid $4500. for the system back in 1994. I've got a sheet of 1/2 Teflon here now that you wont tuck under a cutting edge :laughing: I also have it in 4" diameter so that I can machine it. It's all over the place here LOL but I fully understand what your saying. By the way. These poly Arctic blade weigh more than their steel blades. It's due to the extra ribbing added to them. Built like a battleship.
/ Arctic Poly Skin #17
Yep. Polys are usually a bit heavier. Not just the extra ribbing, but the steel skin on a plow is only gauge steel. My plow total weight is ~750lbs for a 7.5' plow. I re-skinned it with 11ga. That skin was only like 80lbs. I bet a 7.5' x 26" sheet of 3/8" poly is pretty close to that itself.
/ Arctic Poly Skin #18
Interesting. I wouldn't expect teflon to hold up well there due to it's softness. HDPE or UHMW is where I would go. Cheaper and a lot stronger and tougher. This application as a "liner" wouldn't need anything near the thickness of your blade. If I had to take a guess I'd suggest something in the 30-50 mil range (0.030-0.050") as being plenty. 1/8" (0.125) would probably be way overkill. But these are just guesses from my desk chair...
/ Arctic Poly Skin #19
Gentlemen,
Thank you again for your erudition on the subject matter. I will call the location that LD1 and get more information from them.
(I have a sneaking suspicion that the reason that Paul keeps the snowplow under the tarp is so that he can secretly conceal himself under it while he waxes the plow.;) )
edited to add: I called them today and they said that it is already curled (ships as a tube) so that will assist with the install, and it is 1/8 inch thick. Sounds like I may have a go at this.
Thanks again,
RFB
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
ELECTRIC CHAIN HOIST (A64278)
ELECTRIC CHAIN...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A64553)
2015 A and A...
