HF Quick Hitch
/ HF Quick Hitch #1
andy33
Mo
Ferguson30 Kubota L 3800
Anyone use the Harbor Freight Quick Hitch? Read some of the reviews and seems to be an issue with an adapter that is needed for some equipt , but they dont sell the adapter. I could probably make one if i see exactly whats needed. Just wondering if anyone has had any luck with them. Andy
/ HF Quick Hitch #2
If you want that type of QH then HF is as good as any. IMO they are all a hassle unless every piece of equipment you use is set up to use that type of hitch.
There are many threads discussing the pros and cons of such QHs.
/ HF Quick Hitch #3
I got the adapter, but have not actually needed for any attachments because of the adjustable hook. The adapter is not listed on the website, but if you call them they know exactly what you need and you can order it. The hitch works fine, but as I've noted before, be prepared to do a little grinding on the hooks if they are not forged exactly right.
/ HF Quick Hitch #4
I just made a top link adapter for mine , but I had the material and time at work to do so.
/ HF Quick Hitch #5
s a farmer with big tractors in addition to my NH compact, the HF quick hitch is rather lightly built. Flimsy, would be another word.
However, for a compact tractor, that seems to be a good thing. :)
It's light weight enough to put on & off pretty easily, and seems to hold up to the compact loads I've given it. So it gets a good rating from me.
An early batch that was shipped seemed to have an issue where the lower sockets were too narrow, so it didn't fit on some tractors. Mine is just fine, it seems the newer batches have been corrected?
The top adaptor is needed for some 3pt equipment that didn't follow the rules, so the top hook doesn't have clearance to grap the implement. It is available from HF, but they don't advertise it.
All in all, a very good value.
--->Paul
/ HF Quick Hitch #6
--->Paul
Especially if you use the perpetual 20% off coupon and catch it on sale:thumbsup:.
I did order the adapter and I still ended up having to modify the hitch on my "Kubota"- branded ballast box [which my local Kubota dealer "threw in with" with my tractor] because the brand spanking new [when we bought it] box doesn't conform to the correct category 1 hitch standard:thumbdown:.
I know we only have a tiny little compact tractor [Kubota B2320] but using the HF QH, it still manages to pull our tiny little 48" Rollover boxblade and the QH doesn't seem strained by it at all, even in 4WD with hubs locked to keep all the tires from spinning in place:drink:.
/ HF Quick Hitch
Thanks for the replys,I picked one up last Saturday for $90 a HF. Looks like my Brushhog will pick up OK but the 3 point on my blade was not built for it. Looks like Agri-Supply has a adapter for their QH, which looks a lot like the HF. Never did see the HF adapter. Didnt really get too involved because my new tractor was delivered Monday morning!
/ HF Quick Hitch #8
I just got a cat1 Quick Hitch yesterday at HF on sale for $79. Fliped out my 20% discount coupon, got a free LED flashlight and was out the door for $65. The clerk was kind enought to put my 20% coupon back in to my bag so that I would come back. If it doesn't work out I'll take it back. Gave my wife the flash light for her car but didn't tell her it was free. She thinks I'm so thoughtfull, , , By the way they had an open box CAT2 hitch for $79 as well. The store is in Citrus Heights Ca.if anyone is interested. A gut could probally talk to the manager and get it for $50.. just a thought
/ HF Quick Hitch #9
I've had one now for a year or so. Did not get the adaptor. Some equipment works well with it....Woods Brush Bull 72 and others have a tighter fit.....KKII 72" tiller.
By accident, the bottom bolt came loose and out. So, the top pin "hook" pivots and this has worked out so well with my Brush Bull!!!! The pivoting actually lets the cutter float up and down when I need it too. Building a 3pt sprayer right now and setting it up to fit the QH. I really like it. If you don't have level land to sit your attachments on, it can be frustrating to hook up sometimes. I don't think you'll be disappointed once you are past the "learning curve" if you know what I mean?
Bist wishes for success!!:thumbsup:
/ HF Quick Hitch #10
Congrats on the new ride- What did you get?
Remember- POST PICTURES! and don't forget to let us know how you like it!
/ HF Quick Hitch
Thanks PhysAssist, its a L3800 HST Kubota, just turned over 3 hours! So I did a little repair work on a berm to channel some runoff out at my place and used both tractors due to me being lazy and not wanting to take the blade off old Ferguson because it is not adapted to the Quick Hitch which I have on the new one, seems like one is a tractor and one is a sports car with a loader! Really like it so far.
/ HF Quick Hitch
thanks GKH 7890. I knew my blade was not going to fit the QH due to the way the 3pt tower is built but at 1st glance I thought the BHog would lift, but i tried the other day and there are 2 pins or bar spacers ,one in front of the other, keeping the strap steel spread under where you hook the toplink on the BH and the top hook of the QH is so fat it wedges itself in between those two bars and keeps the hook from seating. I just looked at it a little and can probably come up with a fix fairly easily. Working on a weight box now.
/ HF Quick Hitch #13
You're entirely welcome!
Your new "ride" sounds great!
Sometimes I think we could've done better with a bigger machine like one of the L-series, but we have some really tight places to get through, so I don't think it would've helped as much as all that.
Sounds like you were being efficient to me.
When you need to get jobs like that done, sometimes you have to do what's most expedient to get 'er done in the quickest time frame possible.
Sometimes you have to save the fiddling around required to adapt your tools for a more leisurely day.
As long as you have it ready for the next job...
I had never used/driven any tractors except old Farmalls until we got the Kubota, and you're entirely right about the differences between the newer tractors and the old faithfuls.
BTW, to get the adapter from HF, I had to call their customer service number with the HF-QH part number, and pay'em about $20 [shipped].
It has helped with some of my hook-up problems, but not all of them, so if you can fabricate/weld metal, it might be better to make your own.
It just looks like a squared-off "Y" with the double end at the QH, and the bottom at the implement.
I'm contemplating making another [longer] one that will fit my implements universally.
/ HF Quick Hitch
PhysAssist- Good to know about the HF adapter, just looked at the Agri-Supply catalog i received Friday and it lists an adapter for their QH which looks a alot like the HF, so I look online and typed in the item # and it looks just like you described. I usually buy my mower blades from AS and when I order I may just pick up the adapter also its only 9.99.
/ HF Quick Hitch #15
That's great- a better deal than HF is always good to find.
/ HF Quick Hitch
$17.49 on-line. Is the one in the catalog a different number?
Shf141145 Top Hitch Adapter Bracket
Bruce
Bruce, seems like it is, somehow the # you used did not ring a bell, only because i had to write the # down and bring it home from my cabin when i originally looked it up. I found a March catalog at home here and it was in there. Not sure how to put links in, if the link dont work try #80717
Agri Supply - Search
/ HF Quick Hitch #18
I have a harbor freight QH. Actually this is my 2nd one. The first one was only 26 inches wide, the one I use now is 27.5 inches wide. There has been LOTS of discussion about these hitches but the wider one is the one to have. I have all of my equipment except for 2 implements set up to use the quick hitch and I am working on fixing one of them. I have a Ford 102 Series 2 bottom rollover plow (picture in my profile) that I doubt I can come with any workable solution for using the quick hitch with it but my rears flail mower should be no problem if I just get with it and do it. I really don't understand why the mower, for what it cost, was not QH compatible from the factory but oh well...
this thread
http://www.tractorbynet.com/forums/attachments/251874-i-nearly-forgot-pictures-my.html
has pictures of my QH hooked to my blade.
For me, it is a simple matter to convert any implement that isn't already QH compatible and I do it without hesitation. It is just so much easier.
Also a hydraulic top link (which I have) and a hydraulic side link (which I don't have) make any un-level hookup issues moot.
/ HF Quick Hitch #19
Went to HF this morning with a friend who was in need of a cheap air compressor . Anyway while looking aroung I knowtised they did not have any quick hitch attachments on display. I did not need one but asked manager if they had any. He said yes.
Turns out they had a CAT 2 in back, manager said I could have it for $ 67.82 tax included. :thumbsup: Then while at register it turns out they had some kind of promo where I got a tape measure thrown in with deal. :cool2:
He said it was the only one they had in stock. Also BTW those little generators they (HF) sells for about I believe for about $100 were sold out due to potentential FL hurricane threat. I also asked manager if they had any return generators out back I could buy "as is" but they did not have any,thinking I could buy one and repair cheap.
Boone
/ HF Quick Hitch #20
Boone
I did not know that they had a cat 2 qh.
1991 26ft Pursuit 2350 Walking Around Cabin Cruiser with 2017 21ft S/A HMDE Performance Boat Trai... (A66738)
1991 26ft Pursuit...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
Deere PA30B Auger (A64911)
Deere PA30B Auger...
2007 KENWORTH (INOPERABLE) T880 (A67714)
2007 KENWORTH...
