how to level deck on 520H?
/ how to level deck on 520H? #1
monkers
I noticed the deck on my 520H seems to tult down quite a bit in the front. How do I go about leveling it? There isnt anything in my owners manual about doing it. Its a 1989 520H with a 48" side discharge deck. There is a linkage rod on the rear of the deck with a nut on it that looks like it is an adjustment but I would like directions before I start messing around with it. Thanks
/ how to level deck on 520H? #2
Yes the rod will level your deck.I put mine on a flat surface and with a level on the deck bring it in so the front is just down a little from the back.
Great, thank you! That tie rod is the only adjustment used? Which hole di you have the chain connected to on the lift arm underneath, the front hole or the rear?
/ how to level deck on 520H? #4
Not sure off hand.I can check later when I get to the barn,
Thank you for your help, i think mine is in the front hole of the lift arm
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
E-Z Trail 300-bushel Gravity Wagon (A66408)
E-Z Trail...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
