how to level deck on 520H?
   / how to level deck on 520H? #1
monkers
I noticed the deck on my 520H seems to tult down quite a bit in the front. How do I go about leveling it? There isnt anything in my owners manual about doing it. Its a 1989 520H with a 48" side discharge deck. There is a linkage rod on the rear of the deck with a nut on it that looks like it is an adjustment but I would like directions before I start messing around with it. Thanks
   / how to level deck on 520H? #2
Yes the rod will level your deck.I put mine on a flat surface and with a level on the deck bring it in so the front is just down a little from the back.
Great, thank you! That tie rod is the only adjustment used? Which hole di you have the chain connected to on the lift arm underneath, the front hole or the rear?
   / how to level deck on 520H? #4
Not sure off hand.I can check later when I get to the barn,
Thank you for your help, i think mine is in the front hole of the lift arm
2001 STERLING DUMP TRUCK (A54756)
2001 STERLING DUMP...
2011 GALYEAN 130BBL VACUUM TRAILER (A53843)
2011 GALYEAN...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
2019 FORD F150XLT (A53843)
2019 FORD F150XLT...
