Big ride on mower
/ Big ride on mower #41
you are going to have to help me with the hydraulics bit as l am not clued up on them,
open centre would be where the inlet or pressure port is connected to the outlet and hence tank when the lever is in the middle position ? and does the lever stay in any of the 3 positions forwards,backwards and centre/off ?? every valve l have used has been spring loaded to centre
Correct. For a detailed explication, Wikipedia says it better than I can (emphasis mine):
http://en.wikipedia.org/wiki/Hydraulic_machinery#Open_and_closed_circuits said:
Open-loop: Pump-inlet and motor-return (via the directional valve) are connected to the hydraulic tank.The term loop applies to feedback; the more correct term is open versus closed "circuit". Open center circuits use pumps which supply a continuous flow. The flow is returned to tank through the control valve's open center; that is, when the control valve is centered, it provides an open return path to tank and the fluid is not pumped to a high pressure. Otherwise, if the control valve is actuated it routes fluid to and from an actuator and tank. The fluid's pressure will rise to meet any resistance, since the pump has a constant output. If the pressure rises too high, fluid returns to tank through a pressure relief valve. Multiple control valves may be stacked in series [1]. This type of circuit can use inexpensive, constant displacement pumps.
Aaron Z
/ Big ride on mower #42
Looks awesome so far.
#1 - why two seats on a mower? Do you need a Navigator? :D
#2 - what will you make the body out of?
Thanks for sharing sir!
David
/ Big ride on mower
I am worried that your ground speed will be too fast at the proper speed to for the mower decks run. How close are you too a test drive?
well now is a good time to question it, once l have made my engine mounts it will be a lot harder to change, l could change the layout and drop a suzuki transfer box in the drive train to give a 2 to 1 drop or even 4 to one with aftermarket gears if needed,
l have never been a work it out technically sort of guy more a "lets try it and see what happens" but based on engineering principles, now maths never was my strong point so following may be wrong and l am sure some one will be along to correct me ,
the mower l have the decks from ( jacobson HR-5111 ) l think seems to make max power at 2500 rpm according to this manual l found on line http://isurplus.com.au/manuals/Jacobsen HR-5111 Parts Manual.pdf
it also says the forward cutting speed is up to 8.5 mph, l dont want to run my engine at high rpm's so l am going to assume it will be 2000 rpm when l am cutting ??
if the engine is turning at 2000 rpm and l am in fourth gear which is 1 to 1 then there is 2000 rpm going into the diff ( first diff )
which is 4 to 1 so 2000 divided by 4 would mean that my drive shafts are heading into my axle diffs at 500rpm when the engine is spinning at 2000rpm ?? the axle diffs are 5.125 so the 500rpm gets divide by 5.125 which gives me 97.5 revolutions of the wheel for every 2000 revs of the engine ?
tyres are about 31" tall which equates to 90" circumference, so in a minute they would cover 90x97.5 = 8775 inches divided by 12 to get to feet =731 feet a minute x 60 to get to hours = 43,860 feet per hour as there is 5280 feet in a mile divide by 5280 to get to miles per hour = 8.3 miles per hour in 4th gear at 2000 rpm
now thats in fourth and l have 3 below that 3rd is 1.15 2nd is 1.87 and first is 2.92
l think that works out at
1st= 2.8 mph
2nd=4.4 mph
3rd= 7.2mph
4th= 8.3mph
5th= 9.2mph
all at 2000rpm does that sound right ?? and is 2.8 mph slow enough to mow at ??
/ Big ride on mower
David
thats a seat for my honey, l can show her how it works and leave her to it while l go back in the workshop and build a better one lol
and aluminium for the body panels l think
/ Big ride on mower #45
It sounds like your gear will be fine. I just did not want to see you have something that in 1st gear you were running 10mph. For your mower deck gearing you may want to look at the blade tip speed in feet per minute. I would not go lower than 14000fpm. Some zero turns are over 18000fpm.
/ Big ride on mower
how do you work out blade tip speed ??
dia cutter x pi 24 x 3.142 divide into the speed you want ?
24x3.142=75.4 divided into 18,000 = 240 rpm or about 1/8 engine speed
dose that make sense, dosent seem very fast to turn the blades ??
/ Big ride on mower #47
If you have the hydraulic pump on the crank, could you run it via an electric clutch from an Air Con compressor? Not sure what the power capacity of one would be though. You could look having it set up like a power steering pump driven from the crank pulley but via the clutch.
hi woodsmith
you can come see me anytime, infact l will be in manchester next week, openshaw where ever that is l havent looked yet,
cheers Andy
Cheers for that, Andy, I will bear that in mind.
Openshaw is at the 3 O'clock position of Manchester, I am at the 9 O'clock side.
Ahhh, the honey seat!:D
That is what messed up my whole trike design!:laughing:
/ Big ride on mower #48
I'm not good at math but here is a link to a forumula I found.
/ Big ride on mower #49
18000/((24 x 3.142)/12) would be the formula (comes out to 2864 RPMs), the difference is that the circumference of 75.4 is in inches and you have to convert it to feet.
Aaron Z
/ Big ride on mower
Aaron Z
thanks Aaron
that makes more sense, l dont know why but l expected the cutter motors to be going at least as fast as the engine
these are the 3 hyd motors of the cutting deck although l might go up to 4 at a later date
now as the pumps are in series l guess l dont need a large pump as the fluid leaves one and goes into the next, where as in parallel l would have to supply them all at the same time, now l have 2 pumps here and can maybe get a 3rd
this is the one l would like to use as l have it and it will be easy to mount, l see its a vickers vane pump but that is all l know, l cant see any arrow indicating the direction it would like to turn
the other pump l have is off a 6 ton excavator, probably 4 times the size of the one above physically, and l might be able to get the one off the mower the cutting decks came from but that is a multiple pump and was mounted flywheel end which suggests it rotates the wrong way
/ Big ride on mower
l had a bash at finishing the cut down axle for the rear tonight, just about there l think
l dident cut any plates for this l just tipped out my old scrap bin its full of old laser cut tabs and brackets and just made do with what l could find
l see this axle as a prototype so its a case of make it up as l go along,
maybe make another maybe not see how this one works first
l bought some new track rod ends for the steering and then managed to find some rose joints on ebay with the right thread to screw straight on
need shortening a bit but thats no great problem
next l have to strip the old sidekick back axle and get it shotblasted so l might be quiet for a while
Andy
/ Big ride on mower #52
I've been amazed since day 1!!!
Great job!
/ Big ride on mower #53
Andy
:thumbsup:
And people wonder why I visit the scrap metal yard and come back with a pile of bits with holes in!:D
/ Big ride on mower #54
Great job Andy! I've been looking at other forums on tbn and I can see that I have found the right spot. You guys are talking my language. There's no better feeling than to visualize a project and build it into existence!! Good luck!
/ Big ride on mower
:thumbsup:
yup about the same here, l pop down the laser cutters now and then and have a sort through his scrap bin, bit of cash and he is happy and l am happy lol,
you just need a bit of imagination and away you go,
just made theses into a support for the gear change cables
been doing a bit just not much worth taking a picture of, engine mounts are done and the cross members are in
/ Big ride on mower
hi
l forgot to say last time l posted that l decided to go with the manual gearbox, if l am honest it was just laziness, l have this car that works fine, same diesel engine but auto gearbox and l was planning on pulling the engine and box and using it in the mower but when it came to it l opted for the manual l already had on the bench :ashamed:
l might swap the power steering pump over on to the mower still though as on the citroen it also works the hydraulic suspension as is a lot beefier and might work my hyd steering ram better
mean while l have sorted the gear change on the mower, l got a cable change from a toyota mr2 but it was to short unless l ran the cables up against the turbo which l saw as trouble for later so l found some bowden cables on ebay and fitted them with rose joints on the ends and with a bit of a mod to the linkage brackets it looks like it will work
also changed direction with the radiator, it was going to be fitted on the side but had a re think on that one to :rolleyes:
now its going to be forward facing under the seats, just so much easier to plumb up like that
made the fan mountings and the bottom fixing for the radiator today
/ Big ride on mower #60
I think you will be happier with a manual but a auto would be just about as easy to put in it. Is it a hydraulic clutch?
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
New Holland BR7090 Round Baler  5x6 Bales (A63688)
New Holland BR7090...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
17394SFL (A61568)
17394SFL (A61568)
