b2400 on fire!
/ b2400 on fire! #1
bruski
rural Missouri
Kubota b2400HSD
Just got my b2400 back from the dealer after a near catastrophic fire. A few weeks ago while cutting a pasture puffs of smoke started coming out of the dashboard. I turned it off and walked to the barn to get a screwdriver to remove the dash to see what happened. Upon coming out of the barn I saw flames, so I quickly got a fire extinguisher and ran to the tractor to put out the fire.
Seemed to have started at the voltage regulator. Needed a new dash, a new wiring harness, a new hood and assorted electrical parts. Paid for by insurance fortunately (minus deductible).
Dealer service writer said he'd never seen a b2400 do that and thought it had to have been a critter nest.
Anyone else ever experienced this?
/ b2400 on fire! #2
Never had a fire but noticed that field mice liked the area behind the dash to nest on my B26 that was kept covered outside. After cleaning out a nest I had to electrical tape several wires going to the dash that the insulation had been chewed off. I even had one build a nest in the air cleaner - didn't find that one until I checked the filter element! Tractor is now in a barn that I just finished but with rolling front doors and a dirt floor it will never be mouse proof. I use plug in the wall hi-frequency repellers, throw down poison baits and even stuff a couple of "bounce" sheets in the dash area (saw that in an earlier post) when I'm gone for a while. So far no more porblems, but waiting to see what happens this fall when they get busy looking for winter nesting sites. There was an earlier post on a tractor fire that started while the tractor was just sitting out in the open - so I also disconnect the battery when I'm out of town. I'd agree with your dealer that field mice could be a suspect if they're prevalent in your area
/ b2400 on fire! #3
Had a farmall A catch fire after a bird built a nest on the exhaust manifold. Burnt hand was about all the damage as it had little paint on it. was lucky as it was against the gas tank as well. Hope you have no more trouble. Ed
/ b2400 on fire! #4
mice, i hate the little flippieded floppes. one reason, for newer folks if i think of it at the time. of stating make sure you heave easy to remove panels around everything. to check for mice nests. and chewed wires errr insulation removed from the wires.
/ b2400 on fire! #5
I have had mice problems in the past on my L118 JD. In fact this morning i was looking at my L118 and noticed that someone packed my ignition switch full of dirt! :mad: Nobody knows who did it so my assumption is someone was poking around and decided to disable my L118 as a cruel joke or something. I defiantly will check all the fluids after this incidence to be sure nothing else was messed with. So I flipped my hook open and saw a mouse nest on top of the battery (again). Them mice are awful, i have had two mouse nests on my battery and one that was up past the air filter between the plastic engine covering and the cooling fins on the engine. At the time i did take pictures of cleaning out the mouse nest under the plastic covering, I gotta check that area frequently which is fine since it is right under the air filter which I check frequently. :)
/ b2400 on fire! #6
We need barn cats to protect our tractors!! haha!!!
/ b2400 on fire! #7
I used to have a B2400 and it was a great tractor. Over all the years I've hung around here, the only problem I recall them having was a finicky starter solenoid. I don't ever recall anyone here ever reporting having a fire with one. The rodent prblem sounds plausible.
/ b2400 on fire! #9
Never really thought about it but- I'm going to take a closer look under my dash (B7510).
Rodents usually prefer the car and van to nest in, never seen evidence in/around the engine of the tractor. But I guess the potential is always there.
/ b2400 on fire! #10
Mice like motorbikes, too. One climbed up the air intake and chewed holes in the paper filter element. I took some screening and wrapped it around the replacement element to deny the next visitor his snack.
Another mouse built a nest under the gas tank, above the cylinder head, and chewed up the spark plug boots and some nylon tank bag straps.
This all happened inside a garage.
/ b2400 on fire! #11
I had a 60KW Generator that always started and ran like a swiss clock. One day I pulled it up next to the building stated it up and POOF, it caught fire. No one could ever give me a reason why.
One of the few time in my life I LOVED the insurance company.
/ b2400 on fire!
On the plus side, with a new wiring harness the little mule starts hotter and quicker than ever. Nice job by Mordt Tractor in Troy, MO, doing the repairs. They even beat the dents (not from the fire) out of the hood before repainting and put on new decals as well as a putting on a new fuel filter when they went thru the fuel system to make sure no fire extinguisher powder got inside. Looks like new. Runs like new. Good job by a reputable dealer.
It was a challenge with the insurance company. They were quizzing me like they thought I started the fire and seemed to have trouble relating to this type of situation, in fact the adjuster admitted as much, her first tractor fire. In the end they followed through and took care of it (farm/homeowners personal property coverage).
After getting the tractor back I sat down with the five barn cats to remind them why we allow them to live in the barn . . . . .
/ b2400 on fire! #13
perhaps the original cause of first fire was never fixed when parts were replaced?
/ b2400 on fire! #15
Just put the tractor in the shed and saw the first chipmunk on the place. I saw what they did to a house I worked on a few years ago, hope the little pest stays away from my tractor.
RIDGID AIR COMPRESSOR (A63569)
RIDGID AIR...
2013 Polaris Ranger 800 Utility Vehicle (A64047)
2013 Polaris...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
Cub Cadet Ultima ZT1 Zero Turn Mower (A64047)
Cub Cadet Ultima...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
iDrive TDS-2010H...
