Torque values for front end loader frame mount bolts
/ Torque values for front end loader frame mount bolts #1
lilranch2001
Super Member
Bobcat CT 235
I was torquing bolts on my CT235 tonight, and for the life of me I cannot find where I wrote down the specs for the frame bolts, and I cannot find them in the service manual.
Does anyone happen to know what they are?
/ Torque values for front end loader frame mount bolts #2
The rear five are 120-146 ft lbs and the front four are 75-91 ft lbs
/ Torque values for front end loader frame mount bolts #3
The rear bolts (i.e. near loader valve area) are 120-146 ft lbs. The fronts are 75-91. I have a label maker and I've noted torques, capacities, filter numbers, etc. Works out well as I cant remember anything either.
Wow, you both were typing at the same time
Thanks a million!
I have a new fancy label maker at work. Supposed to hold up under water, I guess I will try that out
/ Torque values for front end loader frame mount bolts #5
Thanks a million!
Amazon had a blow out deal on these label makers and I picked one up for $9 bucks. They've gone up since then to about $35. Great plastic labels in white, yellow or clear. Works great for the Bobcat... matches the paint too.
http://www.amazon.com/Brother-PT129...F8&qid=1343872306&sr=8-2&keywords=label+maker
Amazon.com: Brother PT1290 Home and Office Labeler: Office Products
I am sure they get ya on the label stock, like most printers, they sell them as a lost leader to get you to buy the supplies.
But sometimes ya just have to have something, I may order one myself
Thanks
/ Torque values for front end loader frame mount bolts #7
we got the pTouch Cube desktop version, you can then edit the labels on an android portable deveice and send to the label printer via bluetooth or on a PC and sent over USB, this way your not restricted to the handhelds library of characters/graphics and can print literally any image to the labels.
Cat CB24B (A60462)
Cat CB24B (A60462)
Alliance Rear 16.9/14-38 Clamp On Rims (A64119)
Alliance Rear...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2014 INTERNATIONAL DURASTAR 4300 EXT CAB DUMP TRK (A64280)
2014 INTERNATIONAL...
