Transporting brush-hog
/ Transporting brush-hog #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
I am going to brush-hog a nearby property tomorrow. The place is just a few miles down the road, and I'm going to just drive the tractor over, instead of putting it on the trailer. My question is, is it okay to ride like that with the brush-hog on the 3ph? It bounces up and down a lot. At first, I figured I would just let it ride on the tail-wheel, but then I thought probably the tail-wheel's bearings and such probably aren't made for miles of road at 10-12 mph. I figure the 3ph hydraulics are probably pretty tough, but then again, the brush-hog is a lot of weight hanging pretty far back, and the kinds of bounces and jounces it goes through when riding at road speed might wear on the hydraulics. So I thought, maybe I could take a 10k ratchet strap and run it back around the tail-wheel and up across the top of the ROPS or something, just to take some of the bounciness out of the trip.
Any thoughts? Am I over-thinking this?
/ Transporting brush-hog #2
I would keep the mower a foot or so off the ground and just drive! :thumbsup:
I have done it for years on all sizes of tractors and never had a problem.
/ Transporting brush-hog #3
My thoughts.... if you are that concerned about it just hook up the trailer and haul it to the job! That way, you save some wear on the tires and possible stress on the hydraulics.
/ Transporting brush-hog #4
image from....Double HH Quality Products - Don't Compromise... Demand Double HH
stay straps, would hold the 3pt hitch in a single position.
or get check chains, if you do not have position control on 3pt hitch.
"slow moving sign" on rear of tractor would be advised. to many folks are down right stupid, and gun it the first chance they think they can get.
/ Transporting brush-hog #5
There was a really long thread on this a year or so ago with concerns similar to yours.
I grew up farming and live in farm country and the only time anyone runs a rotary cutter with the wheel touching in transport is if it is a pull type.
I routinely run mine between farms in the raised position and it even addresses this in my manual.
I don't have stay straps, unfortunately, but thanks for pointing them out. The 3ph has position control, so I am fine there. I don't have a slow-moving sign, but I do have flashers and turn signals, and it's my understanding that the flashers cover me there (but I'm not 100% on that).
It sounds like there won't be any harm in moving the brush-hog on the 3ph. Thanks for the input, everybody!
I did some searching and couldn't find any such thread. If you happen to have a link to it, I'd appreciate it.
/ Transporting brush-hog #9
Thanks for the advice, everybody. I did the job today. The road trip was totally uneventful. Even though I was going much faster than I do in the field, the road was smooth enough that the mower barely bounced at all. Frankly, it gets a lot more bouncing up and down in the field than it does on the road, so there you go.
About the only thing that was notable about the trip was an odd left-to-right undulation that occurred at speed on the return trip. It was "phased" in nature, as if (and I'm not saying this is what was happening, but it is an example of what might cause the phenomenon) the rear wheels were slightly different sizes, and slightly out-of-round, so that at one point, they were out of sync and the tractor undulated left to right, and then they slowly moved into sync, and the tractor undulated up and down... and then back out of sync again. The undulation was coming from the rear wheels, or thereabouts--definitely not the front of the tractor, and 99% sure it wasn't the implement swinging around, because it was far too regular for that. I noticed that it only seemed to be happening when the engine was pulling (not 100% sure about this). When coasting down-hill (pedal down, but HST not pulling), it didn't seem to happen. Then, when pulling on a flat, it would happen. I speculated that maybe it had something to do with the diff--that maybe the tractor hadn't shifted out of 4wd for some reason when I took it out of 4wd after finishing mowing. I slowed down and put it into 4wd, which put me in a bit of a pickle. It wouldn't come out of 4wd, so I straightened the wheels and rolled slightly forward, which usually does it. Oops. Since I'm on asphalt, I'm only binding up the diff more. I wasn't sure what I was going to do, until I realized I could just raise the front wheels with the loader, tap the HST pedal slightly, and it freed up instantly. After that, the undulation seemed to go away... but I could have just been imagining it.
Anyway, I'm sure it's nothing, but it sure was interesting while it was happening.
Since I know y'all love photos, here's a photo of my tractor in the field after I finished mowing.
/ Transporting brush-hog #11
Grease it and go. 12 MPH does not do the harm as when dropping it fast on hard ground. After you have seen a tractor in the ditch from bouncing off the road (it was due to a three point hitch disk on a gravel road) keeping steering control is job one. Look a wheeled bushhog and see if many are not the same soild type tire/bearings set up? I do it both ways. The MF 265 will shimmy due to light front end with the super heavy duty 7' bush hog. I just tag the rear wheel with part of the load unlike when cutting in the field.
/ Transporting brush-hog #12
In my area, I have yet to see a laminated wheel on a pull type transported on the roadways, they all have aircraft type tires just like ours; rarely have I seen anything but a laminated wheel on a 3PH type.
My nephew didn't like to take the time to shorten the top link to transport, so the laminated wheels stayed on the ground on a 10' Woods and the laminated wheels wore pretty bad.
/ Transporting brush-hog #13
i'd let the tail wheel just ride.. it's made to roll! it's better than shock loading the hyds when you hit a bump and becoming a teeter totter.
/ Transporting brush-hog #14
If driving down the road or another smooth surface, I will lift it. If driving on the shoulder or some other bumpy surface, I will lower it to get some weight on the tailwheel. Do I need to? Perhaps not, but it makes me feel batter to do so.
Aaron Z
/ Transporting brush-hog #15
it kinda amazes me that people are afraid to use their equipment as designed. :) not running mowers at pto rpm. afraid to run tractor at pto rpm for extended times. afraid to let .. WHEELS roll.. LMAO!
why not leave the darned thing parked so it won't ever get any wear ! :) :) :)
soundguy
/ Transporting brush-hog #16
soundguy
Well put
/ Transporting brush-hog #17
Wonder why ballast boxes don't have wheels.
Just something I saw recently.
/ Transporting brush-hog #18
Id greese up the tail wheel and hold the 3pt so the tail wheel took some weight but not all of it.
/ Transporting brush-hog #19
due to the way a 3pt piece of equipment ( or semi-mount for that matter ) is constructed.. the tailwhell of , say, a mower isn't takinghte entire weight.. ever.. unless it's standing on end!! there always something else supporting the hitch side.. either.. earth.. or a tractor.. so the tailwheel NEVER really sees full implement weight...
/ Transporting brush-hog #20
I ment it as, not all the weight it would normally carry which would be half the weight of the deck if your 3pt link is "floating" while moveing.
I know my tail wheel is a bushing design, not a bearing and while i really dont worry about it when im brushhoging as im doing about 1.5mph .... thats a lot slower than say 5-7mph roading between jobs. so to keep some of the weight off of it to keep heat down in at the axle. (i could care less about the solid rubber tire)
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2011 Ford F750 Bucket Truck (A60352)
2011 Ford F750...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2021 Kubota RTV1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
