Oil & Fuel Mower oil issue
/ Mower oil issue #1
PioneerMan
So after sitting for the season my 6ft flail mower had milky oil. Drained it. Could I have just burned it off? Replaced with hydro transmission oil cause I am really low on oils right now. Ran it for a few minutes with the plan on draining it for something better, just wanted to get all the moisture out. A little wasteful, I know. Did I do the wrong thing? What should I put back in, or would that work? I am thinking the stuff in there is a little heavy. ?
/ Mower oil issue #2
What's the owners manual call for? Most of these type gearboxes use a GL-5 gear oil SAE 80W90 or 80W140, etc. The water gets in there from condensation( assuming you have the fill plug screwed on and the seals are good). It can vaporize off if used for long periods of time where the oil gets hot but it will come back if it's sits for a long period of time.
/ Mower oil issue #3
The milk is alot of water where water does not belong. Change it and make sure your vent is not taking in rain water.:thumbsup:
2024 14ft Pairboat Flat Bottom Mud Boat w/ Mudd Buddy HDR 5000EFI 40HP Mud Motor (A61574)
2024 14ft Pairboat...
2013 Ford Focus Sedan (A61574)
2013 Ford Focus...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
