How hard should bearing buddies be to install?
/ How hard should bearing buddies be to install? #11
The ones I use have a small releif hole when you put the grease in the spring platee comes out and uncovers the hole and grease comes out. You need to check them several times the first few hundred miles until the hub is full. I pull trailers 90 % of the time and have never had a bearing go bad in 35 years I just check the bb on a regular basis.
/ How hard should bearing buddies be to install? #12
I have a set like that on my car haul trailer. Once again, rocking the pressure plate will tell you if it needs grease. The reason the hole is there is to prevent over pressurizing the BB and blowing out the rear seal when servicing.
Chris
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
Volvo L306 (A57148)
Volvo L306 (A57148)
5th Wheel Hitch (A59230)
5th Wheel Hitch...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
