Broken again, loosing faith
/ Broken again, loosing faith #341
hmmm, they must be 65 gallon barrels then because when they're full of water, the CK30 struggled to lift them, I'd have to jump off, and give 50 - 100 lbs of extra lift. I was assuming the entire rig was about 1700 lbs since that's what the 3pt is rated at.
Some times you have to get old school on those really big rocks...
I could only lift one end with my 1100lb box blade on...
Well, I have 2 problems. 1, the rock is about 3 km from my house and 2, we still can't find the camera! We once lost the remote for 2 weeks when the kids dumped it in the bin with Christmas wrap which we then put back in storage, but this time with the camera is a record.
/ Broken again, loosing faith #343
Um Ken, you might just have to chalk that camera up on the missing list, and go get another one..
James K0UA
James K0UA
It would cause more trouble than the tractor upgrade, believe me, I've suggested it.
/ Broken again, loosing faith #345
rock sled!
problem moving large rocks that you can not really lift, is they will want to dig into the ground. and make it even harder to move them.
goto a local salvage yard / scrap yard. and see if you can get a old metal hood from a truck or like. flip the hood upside down. to have a nice smooth surface, like a snow sled, drill some holes. and toss some chains through holes and down low on the tractor and away you go. the front edge of hood normally have some curve. and helps keep the hood from digging in while dragging.
flip/roll rock over on to sled. hook sled back up to tractor and away you go.
side note, pending on old metal truck hood, you may need to tack weld some re-enforcement onto the hood. to keep from pulling chains off / through the metal.
you could always use a masonry drill bit, and a few wedges, and a hammer. to split the rock in half / smaller size chunks.
/ Broken again, loosing faith #346
You Greek and Roman guys are all the same, just break out the log rollers whenever you want to move something!:laughing:
Nice idea and nice job on the boulder. Nice pond too!
/ Broken again, loosing faith #347
Just what size rock are you trying to lift?
A tractor should be able to lift what you can fit in the bucket.
DK's are nice strong machines. CK's are manure movers/mowers like a Kubota L3400.
/ Broken again, loosing faith #348
Do you have your relief valve bumped up a bit? The specs on L39 and DKSE loaders seem to be identical. I guess the rocks look bigger when you pick them up!
From the pics posted so far, I'd say you'd be able to pick up that rock if you tried with pallet forks or a grapple from the side instead of from the end. It's just too long and sticks out to far to use the bucket.
/ Broken again, loosing faith #350
I'm guessing IndyIan's rock maybe a bit too heavy. Pretty easy to calculate a rough weight with dimensions.
The rock in that first pic you posted looks bigger to me, but they all look bigger than what I would have though you'd be able to lift. The L39 is holding a couple that surprise me too.
You guys are killing me, I'm going to have to bolt the zamboni back on, fillr up and give it one last shot. Might try a little later today or tomorrow, pictures to follow one way or another.
/ Broken again, loosing faith #352
I guesstimated it weighed about the same as my tractor, and I could only lift the big end when part was counter balanced on a roller. And even that put a permanent little dip in the middle of the bucket. 6'x4'x1.5'x168lb/ft^3 is 6048lbs.
Here's another picture
On the rollers though it was an easy push and the HST was nice for just inching along.
Anyways, I wouldn't go too crazy with big rocks until you get some serious ballast back there. I kind of worry about the front axle loading with the whole a tractor plus whatever is in the bucket balanced on those bearings... Not that I've heard of a problem but just the same.
/ Broken again, loosing faith #353
Think you could be right, most of the rock is a few feet in front of the bucket and so would the weight of it. :)
/ Broken again, loosing faith #354
I have always wondered what would happen if the bucket was dramatically overloaded. Would it just not lift the load or could the cylinders be damaged?
/ Broken again, loosing faith #355
Normally the relief valve goes into relief, and you quit yanking on the stick. End result nothing happens. Course without proper ballast on the rear, the tractor rear end goes in the air is another result. Try it sometime. If you have a rock ledge handy, or a really big rock or some other immovable object you can tie into. With apologies to Dirty Harry, Clint Eastwood " A man has got to know his limitations":)
James K0UA
/ Broken again, loosing faith #356
The hydraulics just go over the relief, do it all the time. I have alot of people wanting me to turn the reliefs up but they make a great safety valve so to speak. you go past the design limits and something WILL break sooner or later. CJ
/ Broken again, loosing faith #357
I have the hydralics less than 100 Psi over factory which is about 2800 psi. When I got the machine it was set at 2200! It could balely lift 1500 - 1600 Lbs. Kubota rates the lift to center bucket, not the pins.
Those rock are the max the machine could lift. I placed them in the bucket with my excavator. There is no other way to fit that big a rock in the bucket and not have it fal out trying to lift. Yes the L39 would lift the rocks to about midpoint.
The L39 is not real strong in the curl and has the Grand L front axle. The new L45 has an M series design front axle and they bumped the curl cylinders up in diameter to where it will curl 4300 Lbs vs 3550 on the L39.
I've got about 1,000 lbs in wheel weights and other stuff bringing the weight to over 8000 lbs. Kubota for some reason likes small front tires on their comercial machines. Sinks real good in soft conditions. The L39 & L 45 should be fitted with 16 x 20 rears (43" dia. vs. 40) and 10 x 16.5 fronts (29 " diameter vs 27") The M59 should have 12.5 X 16.5 fronts.
The M59 is over 5000 Lbs on the curl. Great tractors but problem is those tractors cost close to what I think full size industrial hoe with low hours cost. Central Valley Tractor is a good Kioti dealer up here. I wish Kioti would come out with a TLB with a dedicated real strong hoe.
/ Broken again, loosing faith #358
Loader specs eh! I wonder how Kioti measured the breakout force, it seems like they used the lift cylinders capacity? 3400lbs made sense with my rock as I could lift it up a little ways but the curl had no issues lifting either end up and down... So I think its significantly more using the curl even with the SSQA. I don't really want it any stronger anyways for my rookie skills atleast, its hard to get a feel for how much force it applies for tricky stuff like taking round bales of my trailer, or popping out a rock... I too have watched my front tires sink magically into the ground while waiting for a rock to move out of the ground.:confused2:
Well, if it ain't something, it's something else. I was going to give the rock one more try, but my water pump wouldn't go. I've never had to pull it more than twice to start it, but I forgot it out in the rain a couple days ago and I think the gas took in some water. Anyway, I'll try and get it working this afternoon and go for the rock tomorrow morning. Here's a couple pics of my Zamboni set up.
Well, I drained and changed the gas and still nothing. Fiddled with the switch (on/off) and off it went. So with the tanks full of water, I headed back down the road to try one last time. The rock is down off the side of the road so I put it in 4 wheel drive, low range. I can get under the rock no problem with the forks but, still no lift. I tried backing a little which started bringing the front wheels up to the road level, but also started raising the FEL. I very quickly ended up in a familiar position, with both rear (loaded) wheels, my box blade and two full barrels of water high and dry hanging in the air. The rock wins this one, I picked up a smaller one and headed home. Here's some pictures of the imovable rock plus a couple of the rock I took. My cell phone is in one pic for reference. Still can't find the camera, took the kids again :laughing:
John Deere 4300 32HP Loader Utility Tractor (A61572)
John Deere 4300...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
1000 GALLON NURSE TANK TRAILER (A64276)
1000 GALLON NURSE...
FORD 8340 POWERSTAR SL TRACTOR (A64280)
FORD 8340...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
