Broken again, loosing faith
/ Broken again, loosing faith #303
In the owners manual on pages 5-26 and 5-27. As usual not the best explanation but its there enough I asked my salesman about it.
/ Broken again, loosing faith #304
Sure enough, it explains it and there is a side box labeled + Important:
Put the detent valve operating lever into the neutral position when the hydraulic implement is not in use. If the detent valve is kept in the operation position for an extended period of time the relief valve is kept open and the temperature of the hydraulic fluid rises leading to damage of various hydraulic parts such as the oil seals and O rings. When the detent valve is in operation, unnecessary load id applied to the engine. therefore the engine power decreased significantly and the noise and vibration by opening of the relief valve increase. It is hard to start the engine while the detent valve is in operation. This is especially true in winter and exhaust gas increases even after the engine is started.
James K0UA
/ Broken again, loosing faith #305
Ironhog,
I would agree with you EXCEPT, would you really use a 40HP CUT to do bailing, disking, etc.? I don't know if many people would or do those kind of tasks with CUTs in general- but from what I've seen; and taking to local farmers it seems not too likely.
We bale hay with our Kubota L3830 (did ~190 bales on Monday, have 2 more fields to go for another 400+ bales). I have also plowed the hayfields with it and a 3 bottom Oliver 4330 trailer plow, disced them with a 9' disc and planted them with a grain drill.
Works just fine for us on our ~20 acres of hayfields. Most farmers don't use that size machine because they are working 100s of acres, but for 20 acres it is big enough to get the job done.
Aaron Z
/ Broken again, loosing faith #306
James K0UA
Glad to hear it.
Aaron Z
/ Broken again, loosing faith #307
James K0UA
Aw, come on! We're GUYS, we don't need to read no stinking manual!:laughing:
/ Broken again, loosing faith #308
Aaron Z
What baler do you pull with your L3830?
/ Broken again, loosing faith #310
We have a NH "Hayliner" 273 with a kicker. We bale into basket wagons and get 100-150 bales per wagon.
Aaron Z
Thanks fo the info. Do you have any trouble pulling baler and wagon up hills?
/ Broken again, loosing faith #311
No. You can really tell that it is there (especially going downhill with a full wagon), but it doesn't have any trouble pulling it around the field.
Aaron Z
/ Broken again, loosing faith #312
Aaron Z
That gives me a little more confidence in my choice of a 5045E.
/ Broken again, loosing faith #313
This is just a conversation , and conversations are supposed to have different opinions. If your done with the conversation just don't make a comment. It's simple.
This was his thread to begin with. If you want to be a devils advocate, who enjoys throwing logs onto the fire just for laughs why don't you go start your own thread about how poorly the Kioti is engineered and see how many of the good owners here join you.
Now for everyone else I apologize as I am only a bronze member at this point but this thread has been crapped on big time. This was a great story of Kioti owners coming together now it is just a big friggin joke. KK sorry your thread was hijacked, I am still happy for your new tractor and hope to see more pics in the future. :mad:
/ Broken again, loosing faith #314
Same here.. Ken congratulations on your new tractor, and hope you are getting along well with it.
James K0UA
/ Broken again, loosing faith #315
James K0UA
x3 :D
/ Broken again, loosing faith #316
And times 4. Great Kioti story that goes from hearbreak and dispair to jubilation and the re-birth of the original dream, aided and abetted by a great dealer. Faith restored.
/ Broken again, loosing faith #317
And times 5. Great Kioti story that goes from hearbreak and dispair to jubilation and the re-birth of the original dream, aided and abetted by a great dealer ... and including a sub-plot diversion story about a guy living on an extremely remote island 1 mile from civilization :)
/ Broken again, loosing faith #318
Ironhog,
I would agree with you EXCEPT, would you really use a 40HP CUT to do bailing, disking, etc.? I don't know if many people would or do those kind of tasks with CUTs in general- but from what I've seen; and taking to local farmers it seems not too likely. I mention this NOT because Kioti is right in equipping their tractors with the first pair of rear remotes with detents and the second pair without, but because most Kiotis I've known use the 1st rear remote for hoes and such, and when removed its easy to install a short loop.
Should Kioti note the proper way to operate the rear detented remote in their owner's manual and service manuals, ABSOLUTELY! But then they wouldn't make as much off us dumb 'amerikans' as they can by not mentioning it anywhere EXCEPT to exclude any warranty coverage from misuse, YEAH!:confused2::mad:
Now there is a classic "Catch 22":thumbsup:
I wouldn't expect a CUT to be a primary baler tractor, but I can think of all sorts of things where those rear remotes would be handy or necessary. A 40 HP kioti would make a fine rake tractor on almost any hay/cattle farm.
If the detents are needed for a rear BH I understand....... but how many tractors have a BH vs. running a top link or small piston on something like a rake?
I grew up on tractors so I knew what was going on..... many CUT owners would have burned the pump up over the course of the afternoon.
/ Broken again, loosing faith #319
I'd say that a good rule of thumb is that the OP "owns" a thread for about four or five pages of comments max and less if he diverts from his original question/point himself. If the rest of us didn't jump in and bring up tangential points, these threads would be boring and the community would not develop. Don't be too sensitive about crashing someone's thread, if enough people join is just makes for better parties!:thumbsup::thumbsup::laughing:
/ Broken again, loosing faith #320
Wow I didn't know just cause you start a conversation no one else has the right to bring up other things, sound kind a picky to me .reminds me why I don't go to church. Didn't know you own a thread.and ken congrats on your new tractor , hope you have good luck. And dingo I never once said kioti is bad engineered just because I find fault in 1 area does not mean I'm not happy with my machine life is never perfect but to strive for perfection is how quality becomes quality and I don't feel the need to start another thread nor will I to speak an opinion and if you call a opinion throwing (logs on a fire) so be it.and goodbye.
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
5K Yale Forklift (A63688)
5K Yale Forklift...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
Yale 5K Forklift (A63688)
Yale 5K Forklift...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
