fill tires or not?
/ fill tires or not? #61
I don't think it moves it very much though. It's equivalent to "unsprung weight" on cars, which has minimal effect.
That post is wrong on a couple of levels.
Since a tractor typically has no suspension in the rear at all, any weight added into the tire - or with wheel weights for that matter - is effectively fixed in location relative to the rest of the tractor just as suitcase weights would be. In other words, the entire tractor is "unsprung weight," and acts like a rigid instrument regardless of where you add weight. The only exception is the front axle which pivots.
Even if the rear axle was "sprung," the weight would still have the same effect. It just wouldn't take effect until after the suspension bump travel was reached, that's the only difference.
xtn
/ fill tires or not? #62
I realize that there is no suspension. That's why I quoted the phrase.
On cars, unsprung weight is anything added to the wheels, axles, or other points that do not float on the suspension. This is added in the same area, but can't be considered unsprung for the exact reasons you cited. Again, the reason for the quotes.
I wasn't stating that this is the term to use. I was using a phrase that many people know that would help them gain a better understanding of what I was trying to describe.
/ fill tires or not? #63
Gotcha. But then why state that adding such weight will have minimal effect? If you add weight to any rigid structure, it will change the CG directly and exactly in proportion to its distance from the previous CG and its weight relationship with the existing total weight. It's simple math and it's true for any added weight, be it suitcase weights, liquid tire ballast, an implement, or a few hundred pounds of used chewing gum stuck on the underside.
Moving the CG rearwards helps counterbalance a loader. Moving it downwards - the most effective method of which would be loading the bottoms of the tires - helps reduce the tipping angle of the machine.
/ fill tires or not? #64
I jumped to the end...
FILL THEM!
My dealer uses "RV Anti-Freeze" it is potable and completely non-toxic in the event of a leak.
FILL THE REAR TIRES!
Enjoy the new tractor!
Be well,
David
/ fill tires or not? #65
I was thinking that you're adding weight both above AND below the center of the axle, so the effect on moving the center of gravity is not "profound". At the same time, by adding the raw weight to the outboard portion of the axle, you are increasing the moment arm on the outer edges and requiring more counterforce to tip the machine. If you were to hang an equal amount of weight directly under the machine's current COG, so that it almost touched the ground, it would have more impact on moving the COG but much LESS impact on reducing tip.
/ fill tires or not? #66
This is a interesting statics problem but it has been thirty five years sense I sat in a classroom so I'm a bit rusty. If you look at the point where the axle enters the rim of the tire and resolve the forces there. You have the weight of the machine ,cab and operator as a force down and an equal reaction force coming up from the ground through the tire sidewalls and the rim. Add liquid ballast in the tire and it is a force down that reacts through the tire sidewalls and tread contact patch. The only extra load to the axle is the few square inches that are directly over the axle so perhaps 95 % directly down not felt in any way by the axle. Try to tip the tractor over and the whole weight of the tire ,rim and ballast becomes a weight hung on the end of the axle that has a lever arm equal to the distance to the point the tractor is rotating around. That would be the tire that fell into a hole. So you have weight that doesn't load the tractors axles in normal operation that comes into play automatically anytime a tire tries to lift.
Then consider a ballast box on the 3PH. That weight hangs off the draft links and levers against the rear end trying to raise the front end. The load resolves as a force down at the end of the axles that the bearings and rim has to resist. Going over rough ground it will magnify the impact of every bounce. So from the point of view of you rear end and axle bearings I'd say that fluid filled tires are less stressful then a ballast box or bolt on wheel weights for that matter.
/ fill tires or not? #67
True.
/ fill tires or not? #68
Water is the way to go for the southern states. Do it at home ... convenient as air. Here in Virginia I use it in my 7520 -- a ton of weight for about 25 cents. Long about Christmas I start parking it in the manure pile, but this year wasnt cold enuf to require that even.
larry
/ fill tires or not? #69
larry
Larry,
REALLY!?!?!?!
My place just south of Fredericksburg gets down into the TEENS for most of the day, more than few days each winter.
I know it takes longer for a large volume of water to freeze than a small volume, but I'm amazed you don't have issues...
My tires are full of RV Antifreeze...
David
/ fill tires or not? #70
It all comes down to what the temp of the *water* is. Even though the air drops to well below freezing, the water temp could remain at 35 or so as a result of heat entering the water from the tire, which came from the ground (which possibly isn't frozen).
I believe he also said he parks it in the manure piles when it's that cold, and that's likely how that extra tiny little bit of warmth is keeping the water from freezing.
/ fill tires or not? #71
:cool:I don"t have to worry about that here, Over the course of a tractors thirty year+/- life time it is bound to go to -40 more then once and that is once too many. No manure pile can deal with that though it might work fine for an owner in Dixie. I keep all my water cooled engines protected to -45F. It is relatively cheap and the rust inhibitors they add to the antifreeze seem to be worth the money.
/ fill tires or not? #72
Larry,
REALLY!?!?!?!
David
Yep. When its that cold for any real time its in the pile. Excavate a little trench and the tires are setting on 100+ heat. The surface rapidly cools but close under the surface its warm. Its enuf. I dont even bother till the tires start crusting inside too hard to break by pushing against the tire with my hand. This winter it never got that bad.
larry
/ fill tires or not? #73
My dealer filled mine prior to delivery no questions asked. Yep, you need a better dealer.
/ fill tires or not? #74
For all you folks that have to deal with a lot of thorns I would think you would just fill them with foam.
/ fill tires or not? #75
Self defeating... Foam would be too light... By definition...
I like the idea of the skidsteer tires that never need air...
Go old school with a GIANT metal rim and just 3" of rubber on the outside (Like the old tractors with metal wheels & no tires). Add weight to the rims when needed...
Hmmm....
David
/ fill tires or not? #76
Hmmm....
David
David tire "foam" is a misnomer, It is very heavy and dense, think more like almost solid rubber. It adds a lot of weight to a tire, and solves the nail/thorn/glass problem once and for all. downsides: It is very expensive to have done, The ride becomes more harsh, and replacing tires is done with a a sawzall. Takes some time and effort to replace tires.
James K0UA
/ fill tires or not? #77
Although I am sure most foamed products we have manufactured are lighter than water, it isn't "by definition." Heck, you could foam lead if you wanted to.
Hmmm. Spend a few extra bucks on RV antifreeze, or park in piles of poo. That's a tough call.
/ fill tires or not? #78
We should all have a poo pile to park our tractors in:laughing: (sniff, sniff)
Just kidding Larry, whatever works for you.!
James K0UA
/ fill tires or not? #79
[/B]
James K0UA
Well, if you push a pucker event too far, you will!
/ fill tires or not? #80
Its not the money. Its the convenience of water. Absolutely no issues ... ever, if you have the wherewithal to control excessive phase change.
larry
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
PALLET OF ARMSTRONG CEILINGTILE (A62131)
PALLET OF...
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2018 VOLVO VNL670 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2018 VOLVO VNL670...
