4900 hour service
/ 4900 hour service #1
repete
SW Washington
L2550DT IH584-4WD
4900 hours on the L2550DT. Changed the oil and filter every 100 hours as usual, changed the hydraulic filter and oil every 500 hours, last done at 4400 hours. Changed front differential grease, do every year due to the climate conditions and regular use around water.
No metal in anything with the exception of the hydraulic oil which had a VERY slight metallic color but you had to look in the sunlight to see it. Figured it was normal.
Impressive little tractor that keeps on running. Looks like ---- but earns its diesel.
/ 4900 hour service #2
That is an impressive number to hit. And I thought my 2620 was impressive today, hitting 75.7 hours (kidding)
Thanks for the report
/ 4900 hour service #3
Like Don says, that's an impressive number to reach. It shows what a good machine with proper maintenance can do. At the rate I'm using my Kubota, I should reach that mark in 94 years, give or take. :thumbsup:
/ 4900 hour service #4
Good job by you and the "L". Fluid and filters are so inexpensive compared to replacement parts. No substitue for proper PM.:thumbsup:
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 John Deere 1770NT Planter (A63111)
2009 John Deere...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
