4900 hour service
/ 4900 hour service #1
repete
SW Washington
L2550DT IH584-4WD
4900 hours on the L2550DT. Changed the oil and filter every 100 hours as usual, changed the hydraulic filter and oil every 500 hours, last done at 4400 hours. Changed front differential grease, do every year due to the climate conditions and regular use around water.
No metal in anything with the exception of the hydraulic oil which had a VERY slight metallic color but you had to look in the sunlight to see it. Figured it was normal.
Impressive little tractor that keeps on running. Looks like ---- but earns its diesel.
/ 4900 hour service #2
That is an impressive number to hit. And I thought my 2620 was impressive today, hitting 75.7 hours (kidding)
Thanks for the report
/ 4900 hour service #3
Like Don says, that's an impressive number to reach. It shows what a good machine with proper maintenance can do. At the rate I'm using my Kubota, I should reach that mark in 94 years, give or take. :thumbsup:
/ 4900 hour service #4
Good job by you and the "L". Fluid and filters are so inexpensive compared to replacement parts. No substitue for proper PM.:thumbsup:
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2018 FREIGHTLINER CASCADIA CA125 DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2016 Ford Transit 250 Cargo Van (A61573)
2016 Ford Transit...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
