7' or 8' rotary cutter?
/ 7' or 8' rotary cutter? #11
yep.. 7'ers get way out there.. 8'ds is just (2) 4' mowers essentially..
/ 7' or 8' rotary cutter? #12
I have the M5040 witch is 46pto hp and it pulls the 8ft without a problem.
Check out the Landpride RCR3596 its the one I have been a really good mower,for the money.View attachment 267648View attachment 267649
Foreman,
How do those leveling rods work on the pull behind you have? I've never seen that before? Aside from the obvious answer "leveling", what are they for, and how do they work?
/ 7' or 8' rotary cutter? #13
The MX5100 is a pretty capable machine. I don't think you'll have a problem with an 8 foot dual spindle. Sort of wish I went with that instead of a 6'.
/ 7' or 8' rotary cutter? #14
at RULE OF THUMB FOR 5HP PTO POWER PER FOOT.. IT SEEMS LIKE IT SHOULD BE FINE FOR POWER ANYWAY.. ( darn capslock on this lil kb.. GRRRRR )
/ 7' or 8' rotary cutter? #15
Foreman,
If they wasnt on there then the tongue would swivel at the mower and not just the hitch,keeps the front were the back side of the deck is.I think thats how to answer your question aside leveling.
/ 7' or 8' rotary cutter? #16
About your mowing needs,
if you can afford a two spindle rotary cutter
perhaps you should also examine the Vrisimo line of
flailmowers ment for road side mowing as an
option as they have been made for many years.
The John Deere flail mowers of that size are less
expensive than the vrisimo mowers.
My dad used a John Deere 7 foot 25A mower with
a Ford Jubilee for many years to mow 10-12 foot
golden rod to knock down and reclaim 12 acres of
pastureland.
There are lot good used and new flail mowers for sale
on www.tractorhouse.com
/ 7' or 8' rotary cutter? #17
An odd consideration, as the 2 products differ by like twice the cost. (with the flail mower being the 2x more version)
/ 7' or 8' rotary cutter? #18
Foreman,
The tow "A frame" is pinned to the front of the deck. Like a hinge. If the level rods were not there the front would drag on the ground at the height of the sidebands. By connecting the the A frame to the rear tail wheels brackets the cylinder can lift the complete deck. The rods adjust so you can run the deck lower in the front, level or higher in the front than the rear.
At this point I'm leaning towards a RCR2596 or BH278. Don't need a 3008. May consider a SQ84T. Any guesses on otd price on these units....
/ 7' or 8' rotary cutter? #20
You can go on Tractorhouse and look up the shredders you are interested in and get an idea what cost you are looking at. http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5964665&
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6318795&
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6783781&
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5379151&
2011 FOREST RIVER SIERRA CAMPER TRAILER (A60736)
2011 FOREST RIVER...
2017 Ford F-250 (A55973)
2017 Ford F-250...
2018 Bobcat T650 (A60462)
2018 Bobcat T650...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2023 FORD F-150 (A60736)
2023 FORD F-150...
