what size rotary cutter ?
   / what size rotary cutter ? #41
think OP has 5' & looking for larger options
   / what size rotary cutter ? #42
Yes. I noted that the subject of covering the full tire track came up though. This introduces a problem with cut of the grass flattened on the righthand side. Bushog "suction" is not normally sufficient to bring this back up enough to get a full cut. You could say that the situation really sux!
   / what size rotary cutter ? #43
$3,500 for a 7 foot cutter that is near Kubota’s specs vs $6,500 for an 8 foot twin.
2manyrocks
3k is a steep additional price for an additional 12" cut
Cut quality is better with 8’ twin.
Over several years of cutting, having a 13% wider cut represents a lot of time saved.
An 8’ twin semi mount should have less rear overhang and be more maneuverable.
IMO, I’d buy a used 8’ twin, specifically a JD MX-8 with side shift feature. Awesome mowing machine for under trees, next to fences, etc.
   / what size rotary cutter ? #44
The r4 tires on my mx5200 are good for stability, but they flatten the grass and weeds. I wouldnt expect a pristine cut no matter what kind of mower I use. The grass is going to be flattened before the mower touches it.
I tend to suspect kubota stops at recommending a 7 foot cutter because they dont want to go too far and get sued when someone goes too big and overturns on a hill or ditch.
   / what size rotary cutter ? #45
Kubota’s recommendations don’t make a lot of sense when compared to the 3 pts lifting capability.
The owners manuals for both my MFs make no such recommendations. Nor does the manual for a previously owned David Brown.
   / what size rotary cutter ? #46
I struggle with making practical sense of it when it comes to the choice between a 7 foot rotary vs an 8 foot twin.
   / what size rotary cutter ? #47
I thought my l4630 could handle most anything with a 6 foot cutter. Used it last week to cut a field and it struggled. Weeds were about 5ft tall.
I have had my 8 ft on my m5-111 and it stalled the tractor down. Switched to a 10ft batwing and it never slowed down.
   / what size rotary cutter ? #48
Hay Dude: agree about quality of cut, etc w/8' twin. when i stepped up to one from single 6', marked difference in quality & smooth cut given the twin spindle.
in this case i highly question the OP's tractor to handle a 2000# 3ph. if the OP goes w/7' single, would prob work out for him.
but to step up to 8' for an additional 3k & questionable MX handling, i dunno know
regards
I found this 8' twin for a little less $. I messaged the seller and he claims the MX will handle it. Of course he's in the selling business.
IDK if you can see this photo or not. It's a J Bar brand cutter for $4500
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2014 K-Z RV STONERIDGE 38FT RV TRAILER (A58214)
2014 K-Z RV...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
NEW Landhonor Diamond Dry Drill Set (A59000)
NEW Landhonor...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A55973)
2015 Freightliner...
