what size rotary cutter ?
/ what size rotary cutter ? #41
think OP has 5' & looking for larger options
/ what size rotary cutter ? #42
Yes. I noted that the subject of covering the full tire track came up though. This introduces a problem with cut of the grass flattened on the righthand side. Bushog "suction" is not normally sufficient to bring this back up enough to get a full cut. You could say that the situation really sux!
/ what size rotary cutter ? #43
$3,500 for a 7 foot cutter that is near Kubota’s specs vs $6,500 for an 8 foot twin.
2manyrocks
3k is a steep additional price for an additional 12" cut
Cut quality is better with 8’ twin.
Over several years of cutting, having a 13% wider cut represents a lot of time saved.
An 8’ twin semi mount should have less rear overhang and be more maneuverable.
IMO, I’d buy a used 8’ twin, specifically a JD MX-8 with side shift feature. Awesome mowing machine for under trees, next to fences, etc.
/ what size rotary cutter ? #44
The r4 tires on my mx5200 are good for stability, but they flatten the grass and weeds. I wouldnt expect a pristine cut no matter what kind of mower I use. The grass is going to be flattened before the mower touches it.
I tend to suspect kubota stops at recommending a 7 foot cutter because they dont want to go too far and get sued when someone goes too big and overturns on a hill or ditch.
/ what size rotary cutter ? #45
Kubota’s recommendations don’t make a lot of sense when compared to the 3 pts lifting capability.
The owners manuals for both my MFs make no such recommendations. Nor does the manual for a previously owned David Brown.
/ what size rotary cutter ? #46
I struggle with making practical sense of it when it comes to the choice between a 7 foot rotary vs an 8 foot twin.
/ what size rotary cutter ? #47
I thought my l4630 could handle most anything with a 6 foot cutter. Used it last week to cut a field and it struggled. Weeds were about 5ft tall.
I have had my 8 ft on my m5-111 and it stalled the tractor down. Switched to a 10ft batwing and it never slowed down.
/ what size rotary cutter ? #48
Hay Dude: agree about quality of cut, etc w/8' twin. when i stepped up to one from single 6', marked difference in quality & smooth cut given the twin spindle.
in this case i highly question the OP's tractor to handle a 2000# 3ph. if the OP goes w/7' single, would prob work out for him.
but to step up to 8' for an additional 3k & questionable MX handling, i dunno know
regards
I found this 8' twin for a little less $. I messaged the seller and he claims the MX will handle it. Of course he's in the selling business.
IDK if you can see this photo or not. It's a J Bar brand cutter for $4500
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
Case International 21' Disk Harrow (A64127)
Case International...
Skid Steer Tree Boom (A65640)
Skid Steer Tree...
McCormick X6.55 (A64126)
McCormick X6.55...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2022 EZ-GO ELITE...
