7' or 8' rotary cutter?
/ 7' or 8' rotary cutter? #1
Peacock
Richmond, IN
Kubota MX5100
I've got a gear MX5100 with 44pto hp and am looking at a new cutter. Looking at Bush Hog, Landpride or Woods. Would prefer something over 6' as thats what I use now and I'd like to knock some time off. The 6' cutter is nearly worn out and is due for replacement. I cut mostly pasture and road sides. Some of it is thick fescue that can be tough going, but I don't mind making partial cuts or going slower in those instances.
I'd imagine that a dual splindle 7' or 8' would be easier on the tractor than a single spindle 7'er would be. I've got a loader on it and the tires are filled.
Curious if anyone has any experience with either of these size of cutters and could offer some insight.
/ 7' or 8' rotary cutter? #2
i'd go 8' dual spindle before I went 7' dual spindle with 44 pto hp.. I wouldn't think you have any problem with 8'... will this be a pull setup, or are you looking at 3pt? 3pt 8' is going to be heavy.. but possibly doable as you have a loader for counter ballance.
soundguy
Lift style.
Looks like 8' would still be easier than 7' single due to proximity of weight to back of tractor.
/ 7' or 8' rotary cutter? #4
do not put an 8ft 3pt shredder on the MX5100 to much weight tobe lifting.go with an 8 or 10ft pull type shredder.if we get a bigger shredder itll be a 10ft heavyduty brushhog shredder.
/ 7' or 8' rotary cutter? #5
I would not want to put an 8' 3PH on an MX5100.
/ 7' or 8' rotary cutter? #6
go with a 8 foot double spindle.
I had a 7 foot 3point cutter and it was a bear, so long and heavy. with the extra length it is hard to get the 3 point high enough to get the wheel of the ground when you have the hog set with play in the top link for cutting. I ran mine on a 5700 and it was all it wanted so I wouldnt suggest it on a 5100 unless you are taliking about a double spindle 7 foot.
/ 7' or 8' rotary cutter? #7
remember guys you can run a 3pt like a semi-mount. ;)
/ 7' or 8' rotary cutter? #8
I have the M5040 witch is 46pto hp and it pulls the 8ft without a problem.
Check out the Landpride RCR3596 its the one I have been a really good mower,for the money. LP3596.jpgtractor3.JPG
I'd think that an 8' dual spindle of equal weight to a single spindle 7'er would handle much better on the tractor. The center of the weight would be much closer to the tractor.
/ 7' or 8' rotary cutter? #11
yep.. 7'ers get way out there.. 8'ds is just (2) 4' mowers essentially..
/ 7' or 8' rotary cutter? #12
Check out the Landpride RCR3596 its the one I have been a really good mower,for the money.View attachment 267648View attachment 267649
Foreman,
How do those leveling rods work on the pull behind you have? I've never seen that before? Aside from the obvious answer "leveling", what are they for, and how do they work?
/ 7' or 8' rotary cutter? #13
The MX5100 is a pretty capable machine. I don't think you'll have a problem with an 8 foot dual spindle. Sort of wish I went with that instead of a 6'.
/ 7' or 8' rotary cutter? #14
at RULE OF THUMB FOR 5HP PTO POWER PER FOOT.. IT SEEMS LIKE IT SHOULD BE FINE FOR POWER ANYWAY.. ( darn capslock on this lil kb.. GRRRRR )
/ 7' or 8' rotary cutter? #15
Foreman,
If they wasnt on there then the tongue would swivel at the mower and not just the hitch,keeps the front were the back side of the deck is.I think thats how to answer your question aside leveling.
/ 7' or 8' rotary cutter? #16
About your mowing needs,
if you can afford a two spindle rotary cutter
perhaps you should also examine the Vrisimo line of
flailmowers ment for road side mowing as an
option as they have been made for many years.
The John Deere flail mowers of that size are less
expensive than the vrisimo mowers.
My dad used a John Deere 7 foot 25A mower with
a Ford Jubilee for many years to mow 10-12 foot
golden rod to knock down and reclaim 12 acres of
pastureland.
There are lot good used and new flail mowers for sale
on www.tractorhouse.com
/ 7' or 8' rotary cutter? #17
An odd consideration, as the 2 products differ by like twice the cost. (with the flail mower being the 2x more version)
/ 7' or 8' rotary cutter? #18
Foreman,
The tow "A frame" is pinned to the front of the deck. Like a hinge. If the level rods were not there the front would drag on the ground at the height of the sidebands. By connecting the the A frame to the rear tail wheels brackets the cylinder can lift the complete deck. The rods adjust so you can run the deck lower in the front, level or higher in the front than the rear.
At this point I'm leaning towards a RCR2596 or BH278. Don't need a 3008. May consider a SQ84T. Any guesses on otd price on these units....
/ 7' or 8' rotary cutter? #20
You can go on Tractorhouse and look up the shredders you are interested in and get an idea what cost you are looking at. http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5964665&
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6318795&
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6783781&
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5379151&
(INOP) CLUB CAR ELECTRIC GOLFCART (A62131)
(INOP) CLUB CAR...
Adams 5 T Fertilizer Spreader (A63118)
Adams 5 T...
Case SV280B (A62177)
UNUSED JCT HYD TRENCHER (A62131)
UNUSED JCT HYD...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2019 F-550 Bucket Truck (A63118)
2019 F-550 Bucket...
