7' or 8' rotary cutter?
   / 7' or 8' rotary cutter? #1
Peacock
Platinum Member
Richmond, IN
Kubota MX5100
I've got a gear MX5100 with 44pto hp and am looking at a new cutter. Looking at Bush Hog, Landpride or Woods. Would prefer something over 6' as thats what I use now and I'd like to knock some time off. The 6' cutter is nearly worn out and is due for replacement. I cut mostly pasture and road sides. Some of it is thick fescue that can be tough going, but I don't mind making partial cuts or going slower in those instances.
I'd imagine that a dual splindle 7' or 8' would be easier on the tractor than a single spindle 7'er would be. I've got a loader on it and the tires are filled.
Curious if anyone has any experience with either of these size of cutters and could offer some insight.
   / 7' or 8' rotary cutter? #2
i'd go 8' dual spindle before I went 7' dual spindle with 44 pto hp.. I wouldn't think you have any problem with 8'... will this be a pull setup, or are you looking at 3pt? 3pt 8' is going to be heavy.. but possibly doable as you have a loader for counter ballance.
soundguy
Lift style.
Looks like 8' would still be easier than 7' single due to proximity of weight to back of tractor.
   / 7' or 8' rotary cutter? #4
do not put an 8ft 3pt shredder on the MX5100 to much weight tobe lifting.go with an 8 or 10ft pull type shredder.if we get a bigger shredder itll be a 10ft heavyduty brushhog shredder.
   / 7' or 8' rotary cutter? #5
I would not want to put an 8' 3PH on an MX5100.
   / 7' or 8' rotary cutter? #6
go with a 8 foot double spindle.
I had a 7 foot 3point cutter and it was a bear, so long and heavy. with the extra length it is hard to get the 3 point high enough to get the wheel of the ground when you have the hog set with play in the top link for cutting. I ran mine on a 5700 and it was all it wanted so I wouldnt suggest it on a 5100 unless you are taliking about a double spindle 7 foot.
   / 7' or 8' rotary cutter? #7
remember guys you can run a 3pt like a semi-mount. ;)
   / 7' or 8' rotary cutter? #8
I have the M5040 witch is 46pto hp and it pulls the 8ft without a problem.
Check out the Landpride RCR3596 its the one I have been a really good mower,for the money. LP3596.jpgtractor3.JPG
I'd think that an 8' dual spindle of equal weight to a single spindle 7'er would handle much better on the tractor. The center of the weight would be much closer to the tractor.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
CAT 973 (A47384)
CAT 973 (A47384)
