3pt Receiver hitch
/ 3pt Receiver hitch #1
3930dave
Super Star Member
Canada
Ford 3930
Needed to be able to shunt non-farm trailers with my tractor.
Picked up some forged eye bolts the right size, chopped the bolts off, and had my buddy (ace welder) weld 'em on to a standard bolt-on receiver housing.
Little bit of black rust paint to finish..... came in real handy last evening.
Rgds, D.
/ 3pt Receiver hitch #3
Does it move up and down ok?
^^^What he said. That looks scary to me. I could be wrong but it seems that if one inadvertently hit the 3pt control lever, something has to give and it may not be pretty!
Ken
Good Morning LJ.
The assembled mechanism moves up and down fine, it's just my thinking that needed some adjustment.
I have an adjust-by-hand toplink, nothing fancy. So, as you lift the 3pt the hitch ball moves through an arc. Not a problem, just different, and actually useful for the trailer hitch in the picture. Being able to rotate the ball through the arc helps to seat it in this trailer hitch, once you have the basic position right.
Worth doing ? Definitely in my case. (My tractor is 5x more flexible in tight quarters than my tow vehicle).
Learning curve for hitching up ? Yep, just a little one. I think most people with a little practice would find this easy to use.
I wouldn't try this maneuver for the first time if you where in an extreme hurry/panic to move something (ex. out of control grass fire heading for the valued travel trailer). But, given a bit of time (or in my case, at least 2 cups of coffee ) I think most people would find this easy to use.
Hi Ken - I understand your concern. It doesn't show in the pictures, but my heavy duty shield on the PTO would prevent the toplink from dropping too far, IF I happened to drop the 3pt hitch control lever accidentally. The toplink might get a little beat up, if I didn't notice right away, but in my case there is no significant safety issues for my application.
GENERAL DISCLAIMER - my application is for shunting on my property - I would NOT suggest that someone build this and haul their trailer down a public roadway with it. Safe or not, I have no idea if this contravenes any local (public roadway) transport regulations.
Build components:
Off the shelf bolt on receiver - rated for higher load (at highway speeds) than my trailers.
Eye bolts, to weld on - forged, each one can carry much more load than the tongue weight I have.
Welding: - not a novice level weld, just because of the safety aspect.
To re-state - in my application, the only safety risk would be from shoddy welding of the eye-bolt eyes, onto the receiver.
(My buddy that welded it for me came up building tube frame race cars. I would bet my life on anything he welds, as I know he has actually done that (bet his life), countless times).
To wrap up, the only other engineering consideration is that the 3pt has to have the lift capacity for the tongue weight you are dealing with. Huge safety margin, in my case.
But, yes, if you are not comfortable with these type of modifications, it is not a project I'd recommend.
Rgds, D.
/ 3pt Receiver hitch #5
Okay, yes, I can see now that it would rotate instead of breaking something.
BTW, I have bent/broken a couple of toplinks over the years including a heavy duty one.
Ken
I hear you Ken, I will be keeping an eye on the top-link.
I'm usually pretty easy on equipment, but I do have a old friend who wouldn't surprise me if he broke an anvil ! :confused2:
(You guessed right, he does not get to use my tractor).
Rgds, D.
/ 3pt Receiver hitch #7
Thats got to be a record for the LOWEST toplink mount U have ever seen:confused2:
With it mounted that low, As you mention, causes the hitch to rotate. With it that low, I bet it rotates a GOOD bit.
I have to ask, why did you not have your friend weld a vertical peice on there and raise that TL mount hole ~12" or so?? Not trying to critique the design, but the way you have it now alot more stress on the TL AND on those eyebolts. And whith the geometry of it, it looks like the eye-bolts will see more load than just tongue weight due to leverage. IE...1000lb tongue might be 1500lb on the TL mount. Still probabally okay if you sized them for the tongue weight, because there are 2:thumbsup:
But hey, if it works for you it works. Just havent seen it done before. Either way though, its better than just the drawbar:thumbsup:
/ 3pt Receiver hitch #8
Upon raising the hitch the ball end will rotate downward in an arc to the point where the receiver hitch comes in contact with the top link. THEN it will get ugly. While the hitch is a great idea and it is well made extra care will need to be used so the top link doesn't bend. The hitch will only rotate so far with the top link that long. Believe me I built something similar and later modified it to have the more conventional inverted "T".
As long as the lift isn't raised very high there is no problem. I found that I wanted to raise my hitch higher than my original design allowed. By doing the redesign I don't always have to raise the tongue jack to move a trailer.
/ 3pt Receiver hitch #9
I have used exactly the same bolt-on receiver to make trailer hitches for my Ford 8N & my Kubota B7100, only I did as another reply suggested & welded a vertical 2" sq. tube (Cat 1 height) with a top link attachment point that extends front & back. Works great & also makes a great log skidding attachment, & my home made gardening implements attach to the receiver also.
Right track, wrong direction guys.
"Gee Honey, see how much that moves - I really need one of those hydraulic top links". (Just kidding).
Points are well taken. I have no problem with well reasoned critique; that is one of the reasons I posted here. It can help me improve my design, and also highlight key points for other people considering this project.
I expected the rotation, and find the lift range is adequate for what I need. One of the things I wanted was a compact design, as this modified receiver will be stored most of the time and only pulled off the shelf as needed.
I will be careful with lift vs. interference. Presently the heaviest trailer I'm moving is about 5,000# - heavier than that and I will get a stronger top-link and monitor the forged eyes closely.
Nice job Ken, your pics illustrate well what the other guys are describing.
Rgds, D.
/ 3pt Receiver hitch #11
They actuall make ones just like ken posted.
They are still compact because they bolt to the drawbar. Adn if I recall They are fairly inexpensive.
But for the life of me I cant seem to find them online:confused: I checked TSC, northerntool, and everythingattachments.com and cant seem to find them. But I could swear I seen them at one of those places before. And I was thinking they were under $100.
/ 3pt Receiver hitch #13
Yep, like that. I saw those at northern listed as drawbar stabilizers but it didnt look right with the tuve not being enclosed on the bottom, so I didnt even pull up the big picture:confused2: I could have swore I saw some like that top one somewhere. Either way, $75 delivered for that top one aint bad at all:thumbsup:
/ 3pt Receiver hitch #14
i'm in agreement on adding a vertical post to mount the top link to.
on my tractor, the lower arms and the top link have their pivot points in a single vertical plane. i'm not familiar with all tractors, but i don't think this is the case with all of them. for mine i made the distance between my bottom pins and top link hole the same distance as on the tractor. that way everything remains level through the entire lift. this is handy because i can back up to a trailer and lift the 3ph to couple the trailer. for cases when i only need to move a short distance i don't even need to latch the coupler.
i made a 3ph splitter a few years back and i used the remains of another 3ph attachment for the link pins. the vertical height between them is not the same as my tractor, so when i raise or lower the splitter i have to adjust the top link to make it level again. this is something i need to fix because it's a big time waste when i need to roll big rounds on the splitter.
/ 3pt Receiver hitch #15
I built one a while back, T upside down welded up using a old class-5 receiver hitch off junk truck I had cut off. receiver part was cut down to about 24" if I remember right and I welded up some pins/plated to the cut out tube. I welded a 2" vert tube off the top with a reinforcing angle in it and a flat plate across the back. been banging around for a few years. I later welded a 2nd cut off receiver hitch to the top center of my FEL and no longer use the 3pt version as with the FEL mount I can see and move stuff around pretty easy...
Might be some pics in my photobucket but not sure. search for "wpspiker" username and look at farm/tractor pics.
Mark
/ 3pt Receiver hitch #16
In case anyone is interested on Ebay a company named ez fab offers very nice wellmade 3pt receiver hitches for 90 bucks with free shipping. available in most popular colors and powdercoated. 24 inchs wide and come with the lower seven eighths inch wide pins for cat.1 tractors. usa made in Chatfield minnesota. call 507-867-1635 or email cheryl@ezfab.net If you can use one these are worth a look.
Good links guys. I actually didn't go looking before assembling mine, as I needed it in a hurry.
You realize that you are pretty spoiled, eh ? :)
Free fast shipping is about as common as white rhinos in Canada, it would be $40+ to get that shipped to Ontario, Canada.
Those links will save somebody a lot of searching, good stuff !
Rgds, D.
/ 3pt Receiver hitch #18
Our steel suppliers (the Rent-all) can get us 2 1/2" seamless tubing that is used to make trailer hitch receivers. I bought a few feet of it some years ago and just cut off what I need whenever I need a receiver on the back of my snow blower, back blade, hoe, etc. Welder, drill press and instant receiver hitch.....
/ 3pt Receiver hitch #19
Here's the hitch i made to haul my dump trailer and other flatbeds around with. I run this with my dump and 4 face cord of wood on the road with no problems. works great! Sorry for the bad picture but you can get the idea. I run a safety chain from the hitch to the stationary drawbar hitch so the dump trailer can't raise the 3pt hitch when dumping . . .John
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
