Jacking up triaxle question
/ Jacking up triaxle question #1
Newblue
Gold Member
Central Indiana
New Holland TC45DA SS
What would be the best way to go about doing this? Got a 48' enclosed gooseneck with living quarters that comes in at 16k lbs empty with three torsion axles. I need to take the wheels/tires off to go get new tires put on and will go through the brakes and bearings at the same time. I have heard of tweaking the frames on big enclosed trailers by jacking in the wrong spot. Where would I want to put the jacks when lifting and the stands to hold it? The trailer does have a double frame under it.
Thanks,
Mike
/ Jacking up triaxle question #2
I would use a bottle jack at point between each axle then place it on 6 jack stands under each axle to frame attach point.
Chris
/ Jacking up triaxle question #3
48 foot trailer... does this require a yearly inspection in your home state? Is it tagged commercially?
If so, then only a licensed tech is allowed to do the work.
No yearly inspection, tagged as a camper - 28' garage and 20' camper
/ Jacking up triaxle question #6
Its how I do my tandem and tri axle units. It does not take long, maybe 10 minutes to jack up each side and block it up safely.
He is talking serious weight here. Jacking just one axle up or not properly supporting it is asking for trouble.
Chris
/ Jacking up triaxle question #8
I would have just put a jack under the frame and lifted it onto a jack stand, ending up with 2 jack stands per side. Not kosher?
/ Jacking up triaxle question #9
Not saying it will not work. I can not see it. You seen like a very intelligent guy so I am sure it would be fine if you think it is. I was just giving you the safest answer.
Just make sure your jack and stands are up to the task.
Chris
2022 Mac Trailer T/A Walking Floor Trailer (A61568)
2022 Mac Trailer...
2020 DRAGON ESP...
2006 FREIGHTLINER M2 106 4X2 24FT BOX TRUCK (A59906)
2006 FREIGHTLINER...
2011 JOHN DEERE 544K WHEEL LOADER (A62129)
2011 JOHN DEERE...
2844 (A58376)
2844 (A58376)
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
