help with utv selection for some one with physicalissues
   / help with utv selection for some one with physicalissues
i did drive the Polaris 500 and I liked it but what bothered me was the floorboard. It is heavy duty plastic and the traction is not the best. I was worried about if the floor board became wet it could become a safety issue. I thought about taking my rubber floor mats out of my Nissan after I left the dealership to see if that made a difference. Also I noticed all utv's I tried had a handrail on the passenger side but not n the drivers side. This would make me feel safer getting in and out. I liked the Polaris and kabota 500 models because it was an easyslide in and out plus speed is nice but easy in and out is even better.
thanks because not having a hand hold on the drivers side was a problem for me on some models I tested. I am glad to know there is an easy fix. I will look into the inverter. I have an electric weedeater with a hundred foot cord. I am thinking I can use that cord, my utv, and electric branding just got easier but I need to check the voltage on the brand first.
   / help with utv selection for some one with physicalissues #13
We have a 6 x 4 gator here at the house and a kubota 900 at the farm. Gator has very low ground clearance and the Kubota, as reported, rides a little harder. My son was able to get the gator stuck 2nd day - the kubota not yet though maybe he is finally growing up (29) !!! and staying out of swamps.:D
Bob
   / help with utv selection for some one with physicalissues #14
Bob
Besides having more wheels... what is the selling feature of the 6 wheel gators?
Is it better payload and traction on uneven surfaces?
I've thought about getting one and there are times when it would be a lot of fun too.
For the last 15 years I use my Suzuki Samurai as my UTV/ATV... only paid $1050 for it and it is street legal... no dump bed... but it does haul firewood, move the trailers around and so far I've never been stuck... well stuck for long... that is.
I was using it today and I think what I'm saying is it would be hard to justify 5, 10 or even 12k for an ATV/UTV
   / help with utv selection for some one with physicalissues #15
These are the handholds
http://www.cabelas.com/product/Auto-ATV/ATV-UTV-Accessories/UTV-Accessories|/pc/104796180/c/104695380/sc/104666580/Quad-Gear-UTV-Handholds/717058.uts?destination=%2Fcatalog%2Fbrowse%2Fauto-atv-atv-utv-accessories-utv-accessories%2F_%2FN-1100821%2FNs-CATEGORY_SEQ_104666580%3FWTz_l%3DSBC%253BMMcat104796180%253Bcat104695380&WTz_l=SBC%3BMMcat104796180%3Bcat104695380%3Bcat104666580
this is my gun rack....one of them.
http://www.cabelas.com/product/Auto-ATV/ATV-UTV-Accessories/UTV-Accessories|/pc/104796180/c/104695380/sc/104666580/Big-Sky-Racks-UTV-Bar/1276538.uts?destination=%2Fcatalog%2Fbrowse%2Fauto-atv-atv-utv-accessories-utv-accessories%2F_%2FN-1100821%2FNs-CATEGORY_SEQ_104666580%3FWTz_l%3DSBC%253BMMcat104796180%253Bcat104695380&WTz_l=SBC%3BMMcat104796180%3Bcat104695380%3Bcat104666580
I recommend the above.
Lots of ideas here, not recommending the store particularly, it's good, but same stuff available in numerous places, including on line.
Cabela's: UTV Accessories
I recommend a hood rack and extra lights, fore, aft, side, cabin light, etc....if interested, let me know and I'll give you specifics.
Relative to the inverter, there are two kinds...pure sine wave and modified sine wave. Pure is quite a bit more expensive and necessary ONLY if you are going to run equipment that is sensitive to the electronic input....which you should NOT be doing from your UTV. You will have to decide what maximum wattage you need.... likely your electric branding iron pulls 1000 watts or more....you'll need to make sure your inverter can handle that...my inverter is 2500 watts, which is actually more than the battery/alternator can provide on a continuous basis. You might need an auxiliary battery for those branding occasions. Brand of inverter is not particularly important...but, carefully watch the watts it can provide.... you are going to need a lot of watts if you are thinking of using it for branding.
More questions?? Just ask, or PM me...glad to offer ideas. One idea would be to have a light weight step you could use to assist in getting into the front seat, then stow the step on rear seat or in hood rack. Wood or plastic...
When I track lots of mud into the RTV floor, I just get the power washer and wash it out....works for me. Have been in some terribly muddy situations...works for me.
   / help with utv selection for some one with physicalissues #16
I have a kubota rtv900 and am happy with my choice so far. I have drove others and work on neighbors polaris 4x6 and mule 2010. I installed a full cab and heater on the polaris and repaired the mule. Things I found out was the
4x6 steers hard and wears the front tires out quick. It will ride across rocky dry stream beds better than most 4x4s because of the extra tires. The mule is a early model that gets the crap beat out of it at a large horse farm.
The things that I liked with the rtv900 that sold me is how good it does things slow. With the hydro transmission, I have total control on even the steepest hills. Another item is the glass windshield that stays clear while plastic ones soon get so scratched and hazy that you can't see out of them. Another item was the hydraulic dump. I can load as much firewood in the back as I can and it only takes one finger to move the lever to dump. The last item is the power steering. It is such a treat to be able to steer it with one finger even when loaded.
The rtv900 only tops out at 25mph which is fine for my jobs. Shifting the transmission can be clunky until you learn the technique. It has great power and control so I can move the full hay wagons in and out of the shed and get them right next to the hay elevator.
My tip for you....test drive the (many) different units out exactly the way you would use them. If you will haul and dump weight in the bed, do it before you buy. Be realistic with your expectations and you will buy the right unit.:thumbsup:
   / help with utv selection for some one with physicalissues #17
My gator is an older diesel so maybe the new ones are different but...
I think the original idea was to get more payload, however, when loaded heavy it does not steer well - I often keep the rear wheels at a higher inflation than the first rear set. Also in 2 wheel drive 2 rear wheels on one side drive. In 4 wheel all four rear wheels are locked up and driving making steering more difficult. Not good when the kid is making runs through the woods. Plastic is to expensive!
Bob
   / help with utv selection for some one with physicalissues #18
I am leaning toward a kobata 500 rtv and mule 610. Both of these are easy to get into and four wheel drive. .... Please let me know your likes or dislikes with your utv. Thank you and God Bless:)
I'll give you my thoughts on a Mule 610 which I bought new about 6 years ago. In short I love it!
It's been totally reliable never missing a beat. Both I and my wife find it so easy to slide in and out of (the roll bar is handy to hold on to) that our ATV's end up just sitting in the garage anymore. I let my neighbor take it for a spin and he came back grinning so I knew he was hooked. A few weeks later he bought one.:D
I appreciate simplicity in a vehicle like this. It's sealed, fan cooled CV transmission is efficient, quiet, and well proven. It operates just as smoothly as when new. The steering is light w/o needing to be power assisted and there's no bump steer. In other words when it hits a hole the wheel doesn't try to spin the steering wheel. The carbureted engine starts quickly usually w/o needing the choke. Sometimes in cooler temps I'll pull the choke but it can be pushed back in almost immediately. This little Mule just sips gas. It must hold around 4 gallons and we can run it for days on a tank.
The 610 has an open differential like a car so when turning it around the yard it doesn't chew up the grass like our ATV's can. Additionally there is a "diff-lock" position which locks both rear wheels together but I've only needed to use this feature a few times. It goes pretty darn well in 2WD but ours gets it's share of use in 4WD for steep hills, snow, stream crossing, mud, etc. The front differential is a limited slip.
There is a nice glove box and the "hood" lifts up to reveal a large storage trunk. (The engine is under the front of the bed.) The seat tips up and there is a place for an optional storage container.
Ours, nor my neighbor's, have ever been back to the dealer. In fact nothing has gone wrong with them. I bought the shop manual so what little maintenance is required I just do myself since it's so easy to work on. Basically once a year I change the oil and filter, drain the carburetor float bowl, and top up the battery water. Two years ago I adjusted the valves, changed the brake fluid, and changed the oil in both differentials.
Dislikes? I honestly can't think of much. I guess the 25 mph top speed would be for some but for the way we use it in the woods, fields and dirt roads it's probably seldom over 15 mph. It seems quieter than most UTV's I've been around, I notice a little more noise when I have the top on. The bed is steel so I had ours lined with a spray-in bed liner. The factory hard top is easy to put on and it looks nice but it was almost $200. If I can think of anything else I'll edit and add it here.
   / help with utv selection for some one with physicalissues #19
I went to a local dealer yesterday that has mules, polaris, honda and can-am... probably 50+
They were really pushing polaris and can-am...
They do look like a lot of fun if that's the goal... I liked the mule the best because it seemed less to go wrong...
No Gator Dealers anywhere near here... so I only know the one Gator CX an elderly friend has... totally reliable for him and it has made him a kid again by being able to get around.
I get the feeling the SF Bay Area isn't exactly the hot bed for UTV's... almost never any used for sale locally.
   / help with utv selection for some one with physicalissues #20
I would look at a Jd 825i with bench seat also the rebates are the highest intill may 31 get the best deal then apply the rebates 800.00
Generac XG8000E Generator (A55973)
Generac XG8000E...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
2006 USH BOAT & 2012 TL (A56859)
2006 USH BOAT &...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
